AC + Smog delete without pulleys?
Old Dec 8, 2019 | 07:24 PM
RandyNJ's Avatar
Is it possible to just get a shorter belt and reroute it instead of buying the delete pulleys? If so what would the belt size be? I've searched, but everything I seem to find leads to posts describing steps using the delete pulleys. Preferably would like to free up space which would mean not adding a delete pulley.
Old Dec 8, 2019 | 09:19 PM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
Re: AC + Smog delete without pulleys?
Assuming serpentine setup; unless you put in the AC delete pulley there is no way to run the belt. I think someone was able to make the tensioner work the opposite direction, but you would have to do some searching. Otherwise you need to go to an aftermarket brackets setup to keep the serpentine belt.
I know what you mean though, I have a TPI serp setup and I would like to use it on an old car but I don't need the AC or air injection pump and it seems illogical to run the AC delete pulley just to run a serp belt
Old Dec 8, 2019 | 09:57 PM
Drew's Avatar
You can reroute the belt to eliminate the smog pump, but you still need something is place of the A/C.
At that point, a person might be further ahead to fabricate something to hold the alt and steering pump, or look into a different bracket setup.
From the Tech articles... https://www.thirdgen.org/serpentine/
Old Dec 9, 2019 | 10:53 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
https://www.thirdgen.org/forums/tpi/...without-c.html There's one way to do it with the stock stuff + a pulley swap.
There are tensioners on lots and lots of vehicles. Some Gen V engines are getting spring-loaded piston strut style tensioners down low.
The main thing forgotten with accessories is triangulation. (I'm mostly thinking of aftermarket LS stuff, but I digress.). If you can build that into what you're doing to locate a tensioner, you can do a lot of different stuff.
Old Dec 9, 2019 | 11:02 PM
427seven's Avatar
Car: 1989 Firebird GTA
Engine: Motown Aluminum 427
Transmission: TH400/GVO
I did a lot of experimenting with different setups, ended up going to a full system because - especially - with the TPI style setup the cold air and rad hoses use up the same space needed by the belt and pulleys. When you change things around remember that lots of these systems use revers water pumps as well.
Old Dec 16, 2019 | 08:14 PM
FRMULA88's Avatar
Car: 1988 Formula
Engine: 421 Little M block
Transmission: TH400 w/brake
Axle/Gears: 9" 4.30s, Wilwood discs, 28X10.5-15
possible if you get a standard rotation water pump...
I have (2) belts.
(1) for water pump and Alternator
(1) for vacuum pump
water pump is standard rotation
Old Jan 10, 2020 | 10:45 AM
91banditt2's Avatar
Car: 1991 BandittII Firebird
Engine: 5.7 HSR
Axle/Gears: 3.27 9 bolt
I'm currently modifying an alternator and power steering pump brackets from ICT to work with a serpentine belt and a reverse rotation water pump. Check out Alan Groves web site there is a ton of good info for working on OEM and custom applications with alternator and power steering pumps
SBC Alternator & Power Steering Pump Accessory Drive Brackets Kit for Electric Water Pump
ALAN GROVE COMPONENTS, INC
Third Gen Thread - New belt routing. (with diagrams!)
Impaqt
Oct 6, 2011 11:30 PM
SKYNOVERYA550
Sep 5, 2008 02:41 AM
nightryder
Nov 7, 2007 05:17 PM
Orinackra
Apr 16, 2006 10:13 PM
zzghy
Mar 5, 2003 12:06 PM
