How to wire a 4th gen F-body fuel tank into a 3rd gen F-body
Old Jul 30, 2022 | 08:10 PM
Seen a lot of threads recently with people confused how to wire a 4th gen fuel tank into a 3rd gen. I'm going to post a few tips that will help people get through it.
The information presented here is aimed at cars equipped with factory in-tank electric pumps. I am not familiar with earlier 3rd gens with mechanical fuel pumps. Somebody else can add information for those earlier cars if they want, but I assume the entire fuel system has to be built from scratch.
Overview of Stock 3rd Gen Wiring
Cars with a factory in-tank electric fuel pump have a fuel pump relay located on driver side firewall near the brake booster. The electrical design of the fuel system varies slightly depending what engine is in the car (V6, TBI V8, TPI V8) but all have common wire colors at the relay,
The two thin wires,
DK GRN / WHT: Relay Control
BLK / WHT: Chassis Ground for relay control
The two thick wires,
ORG: Fused power from Battery B+
TAN / WHT: Fuel pump (14 AWG)
After the TAN/WHT wire leaves the fuel pump relay, it goes to a firewall pass-thru (C100) into the interior of the car, travels under the rocker cover next to driver seat, and goes to another firewall pass-thru (C313) located behind the rear seat. Wire colors and functions at C313 are,
Interior Side (hard wired):
BLK: Chassis ground (14 AWG)
PNK: Fuel gauge
TAN / WHT: Fuel pump power (14 AWG)
Exterior Side with Weather-Pack connector:
Pin A: BLK, Fuel Pump & Fuel Gauge ground (14 AWG)
Pin B: PNK, Fuel Gauge
Pin C: TAN, Fuel Pump power (14 AWG)
The C313 pass-thru is a custom low-profile Weather-Pack connector and there is no aftermarket replacement part. Wires on the interior side of the car are permanently attached to the connector and cannot be de-pinned or removed. Do not cut the wires unless you have a really good plan up your sleeve because you cannot replace it unless you pull another out of a junkyard. The connector is also riveted to the sheet metal of the car.
Below is a picture of C313 pass-thru bulkhead removed from car. Rivets have been popped and wires cut to remove it from car. I was stupid and removed mine when I didn't know what else to do trying to run a Hotwire kit. Don't be like me, be smarter and leave it in the car.
The mating connector on the outside is a Weather-Pack style, part number 12020829. Compatible terminals and seals are listed below. Maximum continuous current rating of a Weather-Pack terminal is 20 Amp which is higher than the rating of the stock 14 AWG wire at 14 Amp maximum continuous.
How Much Pump Will Stock Wiring Support?
The stock fuel system has a variety of components and connectors, each with its own current rating.
Fuel pump relay: 30 Amp rating (Pack-Con series)
C100 connector: 46 Amp rating (Metri-Pack 630 series)
C313 connector: 20 Amp rating (Weather-Pack series)
Fuel pump wire 3rd gen: 14 Amp rating (14 AWG wire size)
Fuel pump wire 4th gen: 10 Amp rating (16 AWG wire size)
4th gen fuel tank bulkhead: 14 Amp rating (Metri-Pack 150 series)
The stock wiring is designed for a Walbro 190 L/hr pump and can operate up to a 255 L/hr pump. However, the system design results in a lot of voltage drop due to the many connections in system, and those voltage losses cause the pump to operate at a lower flow rate. I don't know how much voltage drop is in the system, never measured it. But I do know the 255 pump will support more horsepower if that voltage drop is eliminated and that's what a Hotwire kit does. More about Hotwire kits later.
Prepping a 4th Gen Fuel Tank
The 4th gen fuel tank is not plug and play with 3rd gen body harness, and the fuel sender is not compatible with the stock fuel gauge. Some preparation is needed to make the fuel tank usable.
Swapping Fuel Sender: The 4th gen tank has a 40-250 Ohm fuel level sender that is incompatible with the stock fuel gauge. It causes the gauge needle sweep to move out of range of what the gauge can display. The fuel gauge will spend a lot of time above the Full mark as fuel is used up, and then the needle will drop quickly and you will run out of gas when the gauge reads somewhere between 1/4 to 1/2 tank. The fuel gauge will never read Empty unless the sender goes to 0 Ohm. And the sender has to be 0-90 Ohm if you want the full range of sweep from Empty to Full.
The solution is to change out the resistor card inside the fuel tank with a 0-90 Ohm version, AC Delco part number 25319676 (also sold as SK1083). All you want is the resistor board, the rest of the kit will be discarded. No wires need to be cut, no soldering is involved, no zip ties to hold anything, and you keep the 4th gen float and rod. This is a direct parts swap as if GM built it that way.
Step 1: Take your new AC Delco 25319676 out of the box and confirm with a multi-meter that the resistor is actually 0-90 Ohm. Sometimes the wrong parts are shipped in the box and you want to make sure your time is not wasted.
Step 2: Separate the purple wires from the connector. Remove the terminal keeper from back of connector and remove the wires with a Metri-Pack 150 terminal removal tool.
Step 3: Check to see if the float assembly mounts up to your fuel bucket. It might, or it might not depending what generation of design you have. If it does fit then slap the pump assembly together and you're done. If it doesn't fit then go on to the next step.
Step 4: If the new float assembly didn't fit, then remove the resistor card itself and move it over to the stock 4th gen float assembly that does fit. Remove the retainer that keeps the resistor card located, and then slip the card out of the holder. Do the same with the stock float assembly and then install the new 0-90 Ohm resistor card. Finish re-assembling the pump assembly and you're done.
Vent Valve: Eliminating wiring to the solenoid vent valve will cause the valve to remain open at all times and the tank will vent through the charcoal canister. Strip all these wires out of the harness.
Pressure Sensor: No wiring is needed to the air pressure sensor after disabling the solenoid vent valve. Strip all these wires out of the harness. Although the sensor could be used to monitor tank pressure if your ECM has inputs to read the sensor, such as Holley EFI.
Fuel Module: The remaining wires are for the fuel pump assembly that houses the fuel pump and fuel level sender. The tank bulkhead uses a Metri-Pack 150 style connector rated at 14A maximum continuous. This handles up to a Walbro 255 L/hr pump typical with most LS swaps. Wire pinouts are,
Pin A: PPL, Fuel Sender (gauges)
Pin B: GRY, Fuel Pump Power
Pin C: BLK, Fuel Pump Ground
Pin D: BLK / WHT, Fuel Sender (Ground)
Fuel systems with larger 340 L/hr pump should change out the bulkhead connector to a GT 280 style connector rated at 25A maximum continuous. Pinouts are not standardized as this was not a factory option. Racetronix sells a pump module and Hotwire kit specifically for the 340 pump. If you want to try to swap out the bulkhead connector on your own then part numbers are shown in this thread, https://www.thirdgen.org/forums/ltx-...lectrical.html
The connector that plugs into the 4th gen body harness is the wrong style to plug into the 3rd gen body harness. You'll need to remove it and replace with an appropriate connector based on how you choose to power your fuel pump. And that is the next topic matter to discuss...
Old Jul 30, 2022 | 08:11 PM
Re: How to wire a 4th gen F-body fuel tank into a 3rd gen F-body
Mating To Stock 3rd Gen Wiring
If you want to mate a 4th gen fuel tank to stock 3rd gen body wiring then just match like function with like function. Reference pinouts and connector part number given earlier in this thread. The 3rd gen body harness has 3 wires while the 4th gen tank has 4 wires. This is also the case with stock 3rd gen fuel tank but the solution is hidden inside the tank where you can't see it. To go from 4 wires to 3 wires,
Method A: Splice together the Fuel Pump Ground and Fuel Sender Ground wires and run the wire to 'Pin A' of the C313 connector. This is how it's done in a stock 3rd gen.
Method B: Run the Fuel Sender Ground wire into the factory location at 'Pin A' of the C313 connector. Ground the Fuel Pump Ground wire to the body of the car behind the rear seat. Make sure this is a really good metal to metal ground, cleaned of all paint and dirt. Most people will put a ring terminal directly to the body of the car. The better method is to weld a stainless threaded boss to the body and attach the ring terminal to the boss. You can get a boss from Caterpillar, part number 175-1540 (stainless, M10 thread, 1" tall).
Method C: See Post #4. This method will double the current capacity that can be fed through the C313 connector.
Custom harness built using Method A. If you want one like this then PM me and I can set you up.
Example of stainless ground boss welded to firewall behind rear seat, used with Method B.
Fuel Pump Relay: The other thing you need to do is control the fuel pump relay with your engine ECM. This is very simple. If your ECM has a +12V source that is used to turn the fuel pump on/off (GM and Holley ECM's operate this way), then run that wire to the GRN/WHT wire location in the stock relay. Make sure the stock BLK/WHT wire still has a path to ground. If you are even more adventurous, then you can remove the stock relay entirely from the car and use your ECM to directly operate the Racetronix relay by tying into the stock TAN/WHT wire that passes into the interior of the car.
If your ECM has a sinking driver that switches to ground to turn fuel pump on/off, then run that wire to the BLK/WHT wire location in the stock relay. And you'll need to change the GRN/WHT wire so that it gets +12V from a fused power source when the key switch is turned on. I'm not sure what ECM would be configured this way but it's maybe a possibility with lower cost platforms since sinking drivers are less expensive than +12V sourcing drivers.
Racetronix Hotwire Kit
The Racetronix Hotwire kits for '99 - '02 F-body are made specifically for those cars and need some minor modification to become plug and play into a 3rd gen. The following instructions explain how to make those modifications. These modifications will void your warranty, but it is a cleaner install and will appear to be made for your car.
Note: If you don't want to go through the hassle of finding all the parts for this job then PM me and I can set you up with a harness.
You will not need the stock 4th gen wiring harness. Just toss it to the side because the Hotwire kit has the same connections to fuel tank only better. Although be aware that Hotwire kits are different than in the past and now come with the higher current GT 280 connector. You will need an adapter harness to bridge between that and the stock 4th gen bulkhead connector if you wish to keep the stock bulkhead.
All the wires you will be modifying are 18 AWG wire size. Part numbers of connector components you will need are,
C313 Weather-Pack connector
Connector: 12020829
Terminals: 12089040
Seals: 15324985
Fuel Pump GT 280 connector
Terminals: 15304719
Seals: 15366066
These instructions will get you "Option 1" in the wiring schematics at bottom of this post. "Option 2" is identical except it lays an extra wire for fuel sender ground to the C313 connector.
Step 1: Begin tear-down by removing the square body connector that is intended to interface with stock 4th gen wiring harness. Discard the connector, you will not use it again. De-pin the small wires at fuel pump connector and discard the short 4-inch pigtails.
Step 2: Cut away the terminals from the small Black and Gray wires. These wires will be re-fitted later with different kind of terminals. Pull the Gray wire out of the loom back to the relay. This is the end of the tear-down.
Step 3: Now the reconstruction begins. Turn your attention back to the fuel pump connector. You should have 3 wires remaining in the bundle: The two large wires still tied into the fuel pump connector; and the small Black wire hanging free. Slip another 18 AWG wire into the harness (Purple is most desirable). Finish off the wires with GT 280 terminals and wire seals and fit the Black wire into Pin 1, and the Purple wire into Pin 3 of the Fuel Pump connector. Purple will serve as Fuel Sender signal, and Black will serve as Fuel Sender ground.
Step 4: Run the new Purple wire through the harness past the Relay. Take the Gray wire you fished out of the harness earlier and run it in a bundle with the purple wire to the C313 body connector behind the rear seat. Finish off the wires with Weather-Pack male terminals and seals and fit the Purple wire into Pin B, and the Gray wire into Pin C of the C313 connector.
Step 5: Plug the hole located at Pin A with a dummy wire and store the excess out of sight inside the wire loom. If you choose to do "Option 2" wiring schematic with Fuel Sender ground going to C313 connector, then fit that wire into Pin A. All you've got to do now is tidy things up and you're done!
Schematics
Old Jul 30, 2022 | 09:30 PM
Build Your Own and Pass It Thru The Interior
Build your own and pass through interior as if it was meant to be that way. More explanation coming....
C100 example for 1988 Firebird identifying Metri-Pack 630-series terminals capable of supporting 10 AWG fuel pump wire.
Old Jul 31, 2022 | 08:21 AM
mwfrels's Avatar
Car: '86 Z28
Engine: SDPC TPI 350
Transmission: WC T5
Axle/Gears: 3.23 posi
I just pulled my binder with coffee stained notes from mid-2000s and you have just detailed almost the exact same process and configuration I did to my car. My saved notes have that ACDelco 25319676 as a Grand Prix p/n. My only real difference was for the fuel pump ground to body method. I set a rivnut an inch or two next to the passthru and secured a ground lug with a #10 UNC screw and star washers.
M
Old Jul 31, 2022 | 10:38 AM
battmann's Avatar
Engine: LG4 / turbo LQ4
Transmission: 700R4 / 4L80E
Would probably be helpful to address the tank venting in here too so all the information is in one thread.
Old Jul 31, 2022 | 09:33 PM
Can you be more specific?
I did talk about the vent valve. It's open by default so just leave it alone and tank will vent.
Old Jul 31, 2022 | 09:51 PM
punkmaster98's Avatar
Car: 1984 T/A
Engine: LQ4
This is an excellent write up. I see so many ppl on the pages upgrading to the plastic tanks with their swaps.
Old Jul 31, 2022 | 10:04 PM
battmann's Avatar
QwkTrip - I have a thread about not being able to add gas to my 4th gen tank. A couple members replied with some items to check. You replied about the vent valve possibly being closed and maybe it can be opened by hooking up a battery to it. Another member replied stating the roll over vent might be closed. I’m planning to look into my issue this Friday to try and fix it. I’ll report the solution in my thread. Just thought some info on possible venting issues might be helpful to mention here since this thread is very informative and will hopefully be made into a sticky.
Old Aug 1, 2022 | 05:45 PM
I need to have a Racetronix Hotwire kit in order to take pictures to make instructions for this thread. Does anybody want to buy a new F99 kit (RFPK-001) and send it to me and I'll prep it for you and send it back?
Update: Ah, never mind, I bought a harness. I'll just sell it when I'm done.
Old Aug 2, 2022 | 02:10 PM
vorteciroc's Avatar
Top Answer: 1
Looking GREAT!
The Sealed style Metri-Pack 630/ 280 Relays (45A) have been a great replacement for the older UnSealed style Pack-Con Relays.
Shown below:
Now discontinued by GM, but I have had good luck with Standard Motors #RY109
PigTail shown Below:
ACDelco #PT1115.
Old Aug 2, 2022 | 02:21 PM
vorteciroc's Avatar
Top Answer: 1
Connector: #12052287.
TPA: #12052290.
Metri-Pack 280 and 630 Push to Seat Terminals.
Here is a nice Image of everything:
Old Aug 2, 2022 | 05:21 PM
Good suggestion. My stock Pack-Con relay (rectangle shape) shorted out and melted down. Many people have experienced the same thing.
Old Aug 2, 2022 | 06:03 PM
vorteciroc's Avatar
Top Answer: 1
GM does not produce the Sealed Relay (in Post above) anymore...
I have heard that the Aftermarket replacements are not so great.
These were for MAF, Burn-Off, Fuel, Fan, AC, Etc...
But the Originals were AWESOME!
I used them for everything up to 45A (then I go to a Metri-Pack 800 Series 60A Relay).
I am out of New-Old-Stock, so I am testing some replacement Relays from Standard Motors.
Hopefully they will be decent.
Old Aug 2, 2022 | 06:59 PM
My stock fuel pump relay was different, it was a rectangle, not the more oval shape like the one you showed. Both styles shown in picture below.
Old Aug 3, 2022 | 12:53 AM
vorteciroc's Avatar
Top Answer: 1
Note: GM/ Packard Electric created the Pack-Con I/ Pack-Con II/ Pack-Con III/ Pack-Con HD Series (30A/ 40A)...
at the time for the newly created Blade Fuses (ATO/ ATC) that would replace the Glass Cylinder Fuses previously implemented.
Old Aug 3, 2022 | 05:52 PM
vorteciroc's Avatar
Top Answer: 1
The Male Terminal for this Connection Series was an afterthought...
Male Metri-Pack 280 Terminals replaced them in some situations, like the C207 and C208 Connections.
Old Aug 6, 2022 | 01:30 PM
Leon82's Avatar
I have the hot wire kit with Terminator x. Is this the connection I have to splice into?
Old Aug 6, 2022 | 01:40 PM
I haven't covered that yet in this thread. How much of a hurry are you in? I have a harness coming that I'm going to modify and take pictures to finish that part of the write up.
Old Aug 6, 2022 | 02:56 PM
Leon82's Avatar
Not in a rush. My care hasn't had an access cut yet so I need to figure it out before I put the axle in. I still have to pull the old engine and trans so I have lots to do.
Old Aug 14, 2022 | 09:28 PM
@Leon82 , I still don't have all the parts needed to do a complete rework of the Racetronix harness. I posted up schematics so you can see how the wires change. It may be a little while though before I update with detailed instructions.
Old Aug 14, 2022 | 10:31 PM
MAKE ANOTHER BEAUTIFUL DIAGRAM OF THIS, TO GO ALONG WITH THE OTHER TWO YOU MADE.
Please ( I like them )...
Added to Post #4. I'll update Post #2 too, thanks.
Old Aug 14, 2022 | 11:53 PM
vorteciroc's Avatar
Top Answer: 1
Looks great!!!
Let me know if you find Part #12191389 anywhere in stock please.
Thanks!!!
Old Aug 18, 2022 | 03:47 PM
vorteciroc's Avatar
Top Answer: 1
As usual... another Amazing Thread!!!
Old Aug 18, 2022 | 06:59 PM
Yep, I've been tweaking some posts too. Nice pictures you added!
Old Aug 25, 2022 | 04:26 PM
Leon82's Avatar
Thanks,
I will look at them.
What fitting do you use for the fuel sender to go to an an line? The sender has a retaining clip on it.
Old Aug 26, 2022 | 12:37 AM
Russell 611253 644123 if you're using -6 hose. It's a little shorter in length to give the hose enough room to make the turn away to the side of the tank.
I updated post #3 with the rework instructions.
Old Aug 26, 2022 | 03:32 PM
Leon82's Avatar
Russell 611253 if you're using -6 hose. It's a little shorter in length to give the hose enough room to make the turn away to the side of the tank.
Awesome thank you
Old Aug 26, 2022 | 10:34 PM
vorteciroc's Avatar
Top Answer: 1
That is PERFECT!
It is the "VortecIROC" Patented Design, that I started doing for all my Customer's Third-Gen Builds over 25 Years ago!
I am very happy to see it here!
Thank you @QwkTrip
Old Aug 26, 2022 | 10:51 PM
vorteciroc's Avatar
Top Answer: 1
@QwkTrip Your Post #3 looks AMAZING!
For Harness/ Connector Assemblies that do not incorporate an Oxygen-Sensor/ or require additional "Strain-Relief"...
I highly recommend replacing the Delphi TPA #12160826, with Delphi TPA #12176368 instead.
See Image below:
Old Aug 27, 2022 | 02:48 AM
@vorteciroc , Thanks!
Couldn't have done much of this without your expert help in the LS electrical connectors part numbers thread. That's really the key material needed to enable anyone to do all this stuff.
Old Aug 29, 2022 | 10:41 PM
@vorteciroc , got any suggestions what to use for splicing wires for harness build with Post #4 ?
That splice of 10 AWG wire with 2 x 14 AWG wires is a bigger job than what AMPLIVAR crimps were made for. I found the TE Connectivity catalog for wire to wire splices but so many choices.... so much to learn....
Old Aug 30, 2022 | 12:00 AM
vorteciroc's Avatar
Top Answer: 1
For what you described... this is what I would use:
Often Racing rules/ tech inspection tells us not to use the outside Shrink tube (obviously you can for your own car)...
they want Raychem SCL instead.
Product Hyperlink below from the Retailer that I would recommend for you:
Hyperlink
Old Aug 30, 2022 | 12:08 AM
Thanks. I was looking at that Mini-Seal product lineup too but it only goes to 12 AWG wire size. I'm guessing you don't bother with 10 AWG to feed a 340 L/hr pump? At 20 foot length, there is only 0.2V loss difference between 10 and 12 AWG @ 20 Amps.
I saw the SolderSleeve lineup and it goes bigger but I'm skeptical whether solder is a good idea for this kind of application.
Old Aug 30, 2022 | 01:46 AM
vorteciroc's Avatar
Top Answer: 1
If I find a 12 AWG or 10 AWG Wire that does not fit (warning the Product line I posted above runs Smaller than most Butt-Splices from other Brands)...
Grab any Brand heat-shrink Butt Splice and remove (Cut and peel off) the Yellow outer layer:
The Perma-Seal Product line is what I have the most experience with.
Sometimes the heat shrink tube that came with the TE/ Raychem Butt Splice will fit over the Butt Splice that you removed the outside layer from.
Old Aug 30, 2022 | 01:57 PM
vorteciroc's Avatar
Top Answer: 1
Every update that you do, I just love more and more!!!
Here is a secret (Not really LOL)!
I rewrote the instructions for the PLR removal on the GT Series.
GM did not want to spend the $$$ to republish (big surprise).
Do not remove the PLR the way in which you did in your Images...
Repeating the process will eventually damage the mating-face of the PLR.
Instead pry from each side of the PLR where there is a locking-tang on each side.
Old Aug 30, 2022 | 02:53 PM
Good to know, thanks! I'll take a new photo and update the slide sometime this week.
Old Sep 1, 2022 | 01:12 AM
vorteciroc's Avatar
Top Answer: 1
@QwkTrip Who had Delphi #12191398 in stock?
(GT Series Purple Tethered CPA Lock).
I actually use those on Motorsports and MilSpec Harnesses that I do NOT want anyone taking apart.
The Center Locking Tang of that CPA is actually much shorter than the other Versions of the GT Series CPA Locks.
Shown in Image below:
The other Versions have a longer Center Locking Tang, so that the CPA Lock can be slid back and forth to separate the Connector halves...
and NOT have to take the CPA Lock off of the Female Connector half.
The #12191398 Purple CPA Lock can NOT slide back and forth (it can ONLY be removed completely... making it very unpopular compared to the other Versions).
I cut the Tether off of the Purple CPA Lock, and use it on Motorsports and MilSpec Connections.
(Almost like a permanent CPA Lock).
Old Sep 1, 2022 | 01:38 AM
It came with the Racetronix harness. They don't list it individually on their website but they'll sell you almost anything if you call. You'll have to talk to the owner though, don't work with the help staff. Honestly, a lot of the connector kits they sell are better price than Mouser, it's the shipping cost that'll get ya.
EFI Connection has it on their website but I don't know if they actually have inventory. Maybe worth a phone call too.
Old Sep 1, 2022 | 12:57 PM
vorteciroc's Avatar
Top Answer: 1
And now you have:
-The GT-280 Connector (25A Max. Cont. Ampacity) for the Fuel Pump/ Sending Unit Assembly
-The Weather-Pack C313 Connector using 2 Terminals in Parallel (40A Max. Cont. Ampacity).
-The Metri-Pack 280-630 Mixed Relay (46A Max. Cont. Ampacity).
Note for People not very familiar with GT Series Ampacity:
-Metri-Pack 150 is rated to 14A... where GT-150 is 15A.
-Metri-Pack 280 is rated to 30A... where GT-280 is 25A.
Old Sep 1, 2022 | 01:05 PM
vorteciroc's Avatar
Top Answer: 1
Mouser is far from having the best Retail Pricing...
But they will sell One of any Component (Most Businesses do NOT, and will require that you purchase a large quantity of each Component).
Also they usually have great Stock/ Inventory/ Selection.
I do not usually buy from Mouser, unless I need One of something (or a small quantity of something).
Thanks, I will give Racetronix a call (they are only in Canada, I believe).
Old Sep 1, 2022 | 01:43 PM
Komet's Avatar
Car: 1989 IROC-Z
Engine: L98 350 TPI
Really appreciate the time investment and quality of this writeup. It was an enjoyable and educational read and I'm not even doing a tank swap right now.
Old Sep 1, 2022 | 09:57 PM
Thanks for the kind words.
I'm kind of struggling to make an example of the harness for post #4. Still trying to figure out part number for grounding ring terminal. I found a Delphi TAXI for open barrel ring terminals but it doesn't go big enough wire size. I'm guessing other pages of that TAXI have the info I need but I can't get to it.
That's a lot of wire that has to be laid in that terminal, and it's getting hairy on the edge of violating guidelines for too much difference in wire sizes with a splice. Thinking maybe grounds have to be spliced further back in the harness and then terminate with single 10 AWG wire at ring terminal. Honestly thinking 12 AWG would be enough and that would solve some of my issues.
Old Sep 2, 2022 | 02:18 AM
vorteciroc's Avatar
Top Answer: 1
Delphi made Ring-Terminals for up to 3/8" stud/ bolt... and up to Zero Gauge cable.
(but most of the Ring-Terminals are discontinued).
What size hole, and Wire/ Cable Gauge would you like?
Old Sep 2, 2022 | 10:54 AM
In my case I have an M10 ground boss on the body. This is for grounds, 10 AWG pump + 18 AWG fuel sender.
Problem is the splicing guidelines I'm reading in the TE Connectivity tech documents recommends no more than 2 wire sizes different, so smallest would be 14 AWG spliced with 10 AWG. That's getting to be a pretty thick stack of wires for the tools I have. Anything larger than CMA equivalent for 10 AWG becomes a problem for me.
Old Sep 2, 2022 | 11:56 AM
vorteciroc's Avatar
Top Answer: 1
You are not yet set-up to crimp a Terminal for 8AWG or larger yet... correct?
Old Sep 2, 2022 | 12:42 PM
I think I can deal with an 8 AWG closed barrel terminal but it's on the small side of what the tool can do and I never tried. I have a Tool Aid 18840, https://toolaid.com/product/18840
Old Sep 2, 2022 | 03:08 PM
vorteciroc's Avatar
Top Answer: 1
What I normally recommend for a NonMotorsports grade DIY solution is:
Strip/ prep the 10AWG Wire Conductors for the 8AWG Ring Terminal...
Strip a good 3" or so of the 18AWG Wire Conductors, and wrap them diagonally around the 10AWG Wire Conductors.
If not sufficient, a Copper Wire Ferrule can also be used in addition between the Wire Conductors and the Ring Terminal:
Sorry, I forgot to say...
Do not use a Wire Ferrule Crimper to crimp the Ferrule on to the Conductors.
Just Crimp the Terminal on to everything together.
Old Sep 5, 2022 | 10:40 AM
Leon82's Avatar
I measured the bucket fittings and they are 3/8 so I'm going to get the 611203
Thanks for all the write-up work
Old Sep 5, 2022 | 11:38 AM
Sorry, my apologies. Somehow I carried that error through all my build documentation for many years and 2 different fuel systems. Not sure how I did that.
I do use 611203 on the hose drop from tank to my hard lines. I had a different part number of shorter length at the fuel tank bulkhead to get the hose to route nicely. Now I don't know what is that part number if my old documentation is wrong but looks like it was a non-swivel, maybe 644123 (I do have that p/n on a purchase receipt in my notebook).
