LSX and LTX Parts Looking to buy or sell LSX or LTX parts? Post it here.
[For Sale] Getting Out of the LT1 Game - LT1 Engine Parts
Old Jan 28, 2015 | 06:18 PM
HectorM52's Avatar
ALL ITEMS $10 OR LESS. ANYTHING LISTED AS $FREE PAY SHIPPING ONLY WITH PURCHASE OF $10 PART OR TWO $5 PARTS.
Guys, my garage is basically full due to having too many projects going on and hoarding too many parts. I've got to get rid of stuff. I'm going to slash prices hoping to get SOMETHING out of these parts. If I have anything in 60 days, it's all going to the scrapper.
ALL PRICES NEED SHIPPING ADDED!
MULTIPLE ITEMS ARE PRICED PER EACH!
BOLTS NOT INCLUDED!
F-body oil pressure sender - $10
OBD2 Reluctor ring - $10
Stock oil pumps - $5
(2) stock crankshafts that both need turned - mileage unknown - $10
(2) sets of stock bore pistons - one with 75k, one with 175k - $10
Water pump w/ ECT sensor - $10
Bad stock head (some valvetrain parts?) - $5
Full valvetrain set (valves, retainers, locks, rockers, studs, etc.) - $10
TPS throttle position sensor - $5
IAC solenoid - $10
(2) kinda banged up oil pans - $10
Set of lifters (if I can find retainer clips) - $10
Water Pump Temp Sensor - $5
Head Temp Sensor - $5
Crank Balancer - $5
Windage Tray - $Free
Camaro A/C Hard Lines - $5
EVAP Solenoid - $Free
'94 Impala SS Cam - $5
Rear Main Seal Holder Plate - $5
AIR Bracket and Pump - $5
AIR Hard Piping That Goes Under Motor - $Free
Oil Pan Rails - $Free
Oil Pan Bolts - $5
Opti Vent Tubing - $10 (I might be out of these)
EGR Solenoid - $Free
OBD2 Crank Position Sensor - $5
PCV Tube (needs new rubber hose) - $Free
Oil Pump Driveshaft - $Free
MAP Sensor (no grommet) - $5
4L60E Flexplate - $5
Oil Pressure Sensor Elbow - $5
B-Body Oil Pressure Sensor - $Free
Stock Timing Set - $5
Stock Hardened Pushrods - $5
Oil Filler Tube - $10
Ask me about bolts for longblock parts, I may have them (oil pan, timing cover, opti, motor mounts, TB, etc.)
SOLD
Water pump gear drive
Lifters & dog bones
Cam retainer w/ bolts
Rockers
Set of pushrods
OBDI F-body balancer hub
Rear main seal holder
Valve covers
Windage tray
Timing set
Throttle body w/ sensors
AIR pump w/ bracket
EGR diaphragm, solenoid, tube
EVAP solenoid
MAP sensor
IAT sensor
IAC solenoid
Opti vent tubing
Good stock head w/ valvesprings only
Intake w/ MAP sensor, NO fuel rails
(2) power steering pumps
B-body OBD2 hub for Balancer
'93 22# Injectors
'94 Timing Cover
Valve Covers
T56 Slave Cylinder
Oil Filter Adapter for Cooling Lines
B-Body Offset Oil Filter Adapter w/ Oil Line Port
Tensioner Pulley
Tensioner Pulley
Pair of OBD2 Knock Sensors
Oil Dipstick w/ Tube
Camaro accessory bracket
Rear Main Seal Plate
(2) OBD1 PCM's
F-body starter
Recycled:
Frame Mounts
Motor Mounts
Old Feb 1, 2015 | 07:50 PM
HectorM52's Avatar
Re: Getting Out of the LT1 Game - LT1 Engine Parts
Updated list.
Old Feb 1, 2015 | 09:56 PM
jakemussman's Avatar
Car: 1990 Camaro RS
Axle/Gears: 10 bolt, 3.73 Ratio, Torsen LSD
Price with shipping to 99163 on the water pump?
Old Feb 6, 2015 | 01:09 PM
Mr.K's Avatar
Car: 1982' camaro Z/28
Engine: lt-1 out of a 95' impala ss
Transmission: viper spec t-56
Axle/Gears: Ford 9in 3.90 gears
I need bolts for the intake, timing cover and waterpump also need the windage tray, how much shipped to 92509
Old Feb 6, 2015 | 01:50 PM
HectorM52's Avatar
The windage tray is connected to the main cap bolt/studs. You need just those 3 or all 10?
I don't have intake bolts, but do have timing cover/opti and water pump (except I don't have the long stud for the water pump, I only have a bolt).
I'll do $21 shipped for all of them via USPS. That's $6 shipping, $1 paypal, $15 bolts.
paypal = hectormoore52@hotmail.com
Old Feb 20, 2015 | 01:18 PM
MPax's Avatar
I'd like the camaro accessory bracket, f-body starter, and the camaro ac lines please. I can do paypal.
Old Mar 12, 2015 | 10:40 PM
Uncle Skeletor's Avatar
Car: 1991 Camaro RS
Engine: 350, Edelbrock Pro Flo efi
Axle/Gears: 4.10 on a torsen diff
Interested in the Impala SS cam, how much shipped to 99336?
Old Jun 21, 2015 | 10:08 PM
sreZ28's Avatar
Car: 1983 Z28
Engine: 355 Doorstop
Hey boss, how much for both sets of Pistons shipped to 06480?
Old Jun 21, 2015 | 10:24 PM
HectorM52's Avatar
I'm out of town until Wednesday. I will let you know Wednesday night.
Old Jun 29, 2015 | 04:20 PM
xrgoose's Avatar
Car: 88 Trans Am
Transmission: 4 speed auto
I was wondering do you happen to have a non vented opti and if so how much shipped to 61701
Old Jul 9, 2015 | 08:46 AM
HectorM52's Avatar
I have an UNKNOWN CONDITION non-vented opti. If you're interested, PM me. I assume you're looking for one that works! But if you were just needing parts/pieces, let me know!
HectorM52's Avatar
Longest few days ever. But I'm back. Hit me up if still interested.
Old Jul 19, 2015 | 09:20 PM
HectorM52's Avatar
Back up. Trying to get garage cleaned out!!
Old Aug 5, 2015 | 05:59 AM
vtwinsroc's Avatar
Car: 86 iroc,89iroc,98z28
Engine: 305,305,ls1
Transmission: 700r4/4l60e
Axle/Gears: 2.77/3.23
Hi im looking for a roller cam set up doggbones spider bolts cam retainer....is the ss cam bigger then the lt1 cam ?
Old Aug 6, 2015 | 04:51 PM
HectorM52's Avatar
Hey, the SS cam is the Impala SS version of the cam. It was made for lower-end torque rather than horsepower. It had less lift than the F-body cams.
I actually do not have the spider or dogbones anymore. I sold the last one I had.
Sorry.
Old Aug 17, 2015 | 07:03 AM
HectorM52's Avatar
List edited and back up.
midge54
Dec 27, 2019 04:14 PM
midge54
Jan 29, 2017 07:00 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
1nastygta
Aug 8, 2015 07:38 PM
