[TX] FS - Stealth Ram complete setup - like new
Old Mar 4, 2015 | 09:06 AM
bigbird89's Avatar
Car: 86 Firebird
I'm selling a complete Stealth Ram setup which includes:
Manifold Base and polished plenum by Speedmaster
Small cap style distributor with remote high output coil
27 lb injectors
Holley fuel rails with adjustable fpr
wiring harness from 1985 corvette if you want it
This system was installed, started, and run around the block ONCE. It turned out I have some kind of problem with my computer which won't allow me to tune it so I am going a different direction.
Looking for $500 for everything - or best reasonable offer.
I can get pics uploaded later...
Old Mar 4, 2015 | 09:26 AM
jh_shady01's Avatar
Car: 82 Z28
Engine: Vortec headed 350, lightly worked
Axle/Gears: LS style 7.5, torsen 3.42 disc
Re: FS - Stealth Ram complete setup - like new
Vortec heads?
Old Mar 4, 2015 | 09:47 AM
bigbird89's Avatar
Car: 86 Firebird
SBC gen 1 style, but could probably be drilled for Vortech heads
Old Mar 4, 2015 | 03:31 PM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
27 lb injectors
I'd be interested in the chinese upper/lower, and the fuel rail kit for around $300. I don't need the injectors, distributor, coil, or harness.
-- Joe
Old Mar 4, 2015 | 03:46 PM
bigbird89's Avatar
Car: 86 Firebird
pm sent.
Old Mar 4, 2015 | 03:57 PM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
pm sent.
Replied. Deal in progress.
-- Joe
Old Mar 4, 2015 | 04:30 PM
crossrush's Avatar
Car: 1986 Iroc z
Axle/Gears: 3:42
Whats left?
Old Mar 4, 2015 | 07:01 PM
bigbird89's Avatar
Car: 86 Firebird
I still have the distributor, coil, and injectors I'm willing to make a deal on. The harness still needs to be removed from the car.
I also have a 95% complete TPI system I will be selling, pm me if interested.
Old Mar 4, 2015 | 07:03 PM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Payment sent
Thanks!
-- Joe
Old Mar 5, 2015 | 08:49 PM
bigbird89's Avatar
Car: 86 Firebird
All accounted for except the 27lb injectors. Rebuilt and tested by Southbay injectors - $120 if anyone is interested. I will post a separate ad soon.
Thanks!
Old Mar 5, 2015 | 10:17 PM
aliceempire's Avatar
Transmission: T-5, TH350, T-5
Interested, what brand are the injectors?
Old Mar 6, 2015 | 06:34 AM
bigbird89's Avatar
Car: 86 Firebird
Bosch III for ls1 &ls6
bosch III 27 lb injectors flow tested by South Bay
Old Mar 6, 2015 | 10:28 AM
1BADZ28SD's Avatar
Car: 1991 Camaro Z28
Engine: 5.7Liter HSR
pictures of the tpi intake?
Old Mar 6, 2015 | 11:37 AM
bigbird89's Avatar
Car: 86 Firebird
It may be this weekend before I can get pics - Things are still a little scattered around the garage.
Old Mar 6, 2015 | 11:38 AM
Is that 27lb rating at 43 psi or 58?
Old Mar 6, 2015 | 12:02 PM
bigbird89's Avatar
Car: 86 Firebird
That's at 43.5 PSI
Old Mar 6, 2015 | 02:09 PM
pm sent
Old Mar 6, 2015 | 07:07 PM
1BADZ28SD's Avatar
cool let me know
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Stangski09
Nov 14, 2015 01:27 PM
TheExaminer
Sep 6, 2015 11:40 PM
Vassago
Convertibles
Sep 4, 2015 09:37 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
