GM {Astro} Steering Shaft Upgrade
Old Mar 5, 2015 | 03:18 PM
MC87SS's Avatar
Car: 85 & 87 Monte Carlo SS/80 El Camino
Engine: 305/350/454
Transmission: 2004R, 2004R, TH400
Axle/Gears: 3:42, 3:73, 3:23
I have available a GM steering shaft upgrade. This shaft replaces your stock shaft and replaces the worn out rag joint with u-joints to provide a much tighter steering feel, as an added bonus they give extra clearance required for most headers. These are pulled from late model Astro vans and modified so they are a direct bolt-in, all that is required is a small notch on your steering column end to allow clearance for the pinch bolt to slide through. These are cleaned, modified and painted gloss black then greased before shipping. If you are looking for the popular Jeep Shaft Upgrade this Astro Shaft works the same but is actually a nicer unit. It has 2 metal bushing where the shafts join as apposed to mostly cracked plastic bushing found on Jeep Shafts as well as a small set screw to help eliminate play between the shafts. These GM Shafts are a "Solid" unit so they do not have the rubber isolator to wear out like is found on the Jeep Shaft. I do have a GM {Astro} unit with a rubber isolator in limited quantities if you want one (Ask BEFORE Payment). These units are collapsible in case of a front end collision unlike some of the other Rag Joint Eliminators on the market. Maximum installed length is 20 1/2".
$75 shipped to the states.
PM me if you want one!
This is the end that attaches to the steering column:
This is the steering box end, note how nice the u-joint is:
Set screw in the center:
Metal bushing in lieu of plastic:
The one on the top is the Shaft with Rubber Isolator, the bottom one is the Solid Shaft
The theory is the rubber helps to reduce the road vibration in the steering wheel but if that was the case then why would some have it and some not. From what i can tell only 1 year came with the rubber, all the rest were solid.
NOTE: Anytime you change any steering components and Alignment is recommended and may be required to center your steering wheel!
FOR OFF ROAD USE ONLY!
THE PURCHASER IS RESPONSIBLE FOR DETERMINING THE SUITABILITY OF THIS PRODUCT.
Purchaser understands and recognizes and agrees that suitability of any part sold or manufactured for a particular application is the purchaser’s decision and that the purchaser is not relying on the skill or judgment of manufactured and/or Distributor regarding suitability of any product or service. Manufacturer and Distributor make no warranties whatsoever, expressed or implied, oral or written to purchasers with regard to this product. The right to make changes in design or add to or improve on product without incurring any obligations to install the same on products previously manufactured is expressly reserved. Buyer agrees to indemnity and hold seller harmless from any claim, action or demand arising out of or incident to the buyer’s installation or use of products purchased from Manufacturer and/or Distributor. All parts are modified used parts. No implication is made that these parts are the original car manufacturers or from the original suppliers, or are approved by them. Before operating vehicle, always utilize safety restraint systems while operating vehicle. Please note all products are designed for off road use only. It is up to the user and/or installer to determine fitness for any other application. Seller can't control the use, your driving habits, and the quality of your installation and offers no warranty as to fitness or performance for a particular application. These products require fabrication skills to install and should only be installed by a qualified fabricator or mechanic. WARNING Installation of this product should only be performed by persons experienced in the installation and proper operating of vehicle systems. It is also the responsibility of the person installing any component to determine the suitability of this product for their particular application. Products are intended for off road use only. The manufacturer and distributor are not responsible for any misuse of these products. Check with your local authorities for highway laws in your area because highway laws and the enforcement of those laws vary widely. Please check with your local DMV or vehicle department for regulations and information, manufacturer and distributor is not responsible for any legal issues regarding of any product you purchase here.
Old Mar 5, 2015 | 03:25 PM
MC87SS's Avatar
Engine: 305/350/454
Re: GM {Astro} Steering Shaft Upgrade
Installation Instructions:
This is how the shaft is supposed to be installed with the set screw in the groove.
Before you notch your steering column install the lower end on the steering box, then with the shaft positioned as shown mark the steering column for the bolt.
These are the instructions for notching the column. I used a Jeep shaft in the pictures however its the same for the GM {Astro} Shaft.
I have had many questions about the notching of the shaft so i thought some more instruction may be in order.
The notch required for the bolt has to be made on your steering column shaft NOT the Shaft.
To make things easier i used an extra steering column for the pictures. The area you are seeing is the part of the steering column that comes thru the firewall.
This is what it looks like once you remove your stock shaft.
Slide the Jeep shaft on as shown.
If you look thru the bolt hole you can see where the column shaft sticks out into the opening.
Mark the center of the bolt hole with a marker.
I got carried away with my die grinder so the notch is larger then it needs to be.
Now you can see the bolt hole is clear straight thru.
Bolt installed and shaft locked in from sliding off.
Hopefully this helps.
Old Mar 6, 2015 | 09:42 PM
MC87SS's Avatar
Engine: 305/350/454
I have plenty in stock ready to ship.
Old Mar 6, 2015 | 11:20 PM
dhirocz's Avatar
Car: '86 IROC-Z/'94 Z28
Engine: 350 LT1/382 LT1
Transmission: 4L60-E/T-56
Axle/Gears: 3.45/3.42 (soon 4.10)
How about if I just picked one up from you in person? I'll be back in Tallahassee next weekend and wouldn't mind giving one of these a go. I'm down for tighter steering.
Old Mar 7, 2015 | 05:24 AM
MC87SS's Avatar
Engine: 305/350/454
Normally that would be fine however i will be in Orlando next weekend.
I will be back Sunday afternoon.
PM me your schedule and i will see if we can meet up.
Old Mar 10, 2015 | 08:46 PM
MC87SS's Avatar
Engine: 305/350/454
I have 1 with the rubber isolator in stock and ready to ship.
PM me if you want it.
Old Mar 16, 2015 | 07:21 PM
MC87SS's Avatar
Engine: 305/350/454
Plenty of Solid Shafts in stock and ready to ship.
PM me if you want one.
Old Mar 21, 2015 | 09:00 PM
Cale Sahl's Avatar
Car: 1992 Z28 Z03
Engine: LB9
Got mine in a couple days ago and it looks great. Can't wait to put it in as soon as I get my other projects on the car done.
Old Mar 28, 2015 | 08:32 PM
MC87SS's Avatar
Engine: 305/350/454
Thanks Cale, glad your happy with it.
I have 1 Solid and 1 with Rubber Isolator ready to ship.
Old Apr 3, 2015 | 07:31 AM
MC87SS's Avatar
Engine: 305/350/454
Sold out of this batch but have more on the way.
PM me to get on the list.
Old Apr 4, 2015 | 02:57 PM
kauboy's Avatar
Car: 83 Z28 Crossfire
Thanks got the Astro steering shaft good quality. I found a source for a new bearing.
http://www.kirbanperformance.com/pro...submit_button=
Old May 26, 2015 | 09:22 AM
MC87SS's Avatar
Engine: 305/350/454
Finally got a few more in stock.
I have a few with rubber isolator and 2 Solids ready to ship.
I also have plenty of Solids on the way.
$70 shipped to the states.
Old May 31, 2015 | 08:20 PM
MC87SS's Avatar
Engine: 305/350/454
Have plenty in stock.
This how they look when the come from the yard.
This is after all the prep, ready for prime and paint.
Old Jun 5, 2015 | 03:39 PM
MC87SS's Avatar
Engine: 305/350/454
Just a few left.
Old Jun 6, 2015 | 07:15 AM
AkDrifted's Avatar
Car: 1989 RS Camaro
Axle/Gears: 3.73 Posi
Just got mine yesterday with the bearing upgrade and it looks great! Very clean and well done. I can't wait to put it in along with my 2-1/4 ws6 box. Thank you mc87ss!
Old Jun 10, 2015 | 05:55 AM
MC87SS's Avatar
Engine: 305/350/454
Thanks, Glad your happy.
I still have a few ready to ship.
Old Jun 15, 2015 | 04:26 PM
MC87SS's Avatar
Engine: 305/350/454
Just a couple solids left and 1 with rubber isolator.
Old Jun 25, 2015 | 09:26 PM
MC87SS's Avatar
Engine: 305/350/454
Got plenty in stock.
Old Jul 19, 2015 | 07:15 PM
MC87SS's Avatar
Engine: 305/350/454
I have 2 shafts with rubber isolator in stock and ready to ship.
I have 25 solid shafts on the way that will be ready to ship next Monday.
PM me if you want to get on the list for one.
Old Jul 24, 2015 | 09:41 PM
MC87SS's Avatar
Engine: 305/350/454
I got 21 Solids & 4 with Rubber Isolator in stock and ready to ship Monday.
$115 shipped to Canada.
Old Jul 24, 2015 | 11:26 PM
thewizard's Avatar
Car: LT4 C4, LT1 CE, 95' Dyno Air
Transmission: ZF S6-40, 4L60E, sprockets
Axle/Gears: 3.45, 3.07
Post edited; disregard.
Old Jul 27, 2015 | 09:50 AM
MC87SS's Avatar
Engine: 305/350/454
I have another batch ready to ship.
I took a few pics during the prep process, figured i would share so you can see the work i put into these.
Old Jul 27, 2015 | 03:15 PM
MC87SS's Avatar
Engine: 305/350/454
Originally Posted by ydnar417
Still selling these?
Yes,
I have plenty in stock.
PM Sent.
Old Jul 28, 2015 | 07:05 PM
MC87SS's Avatar
Engine: 305/350/454
Down to 8 solids ready to ship.
I have another 9 to prep that will be ready this weekend.
Old Jul 29, 2015 | 05:44 PM
Lurbie's Avatar
Car: 89 Camaro
Engine: Dart SHP 400-Holley Terminator EFI
Transmission: Tremec T56 Magnum F
Axle/Gears: Strange S60 3.55:1
My shaft arrived today. Thanks for the fast shipping and the great packaging. It was well protected.
Old Aug 2, 2015 | 11:54 AM
MC87SS's Avatar
Engine: 305/350/454
Glad your happy with it.
Enjoy.
Have another batch ready, $70 shipped to the states.
Old Aug 10, 2015 | 03:02 PM
MC87SS's Avatar
Engine: 305/350/454
Still have a few left.
Old Aug 11, 2015 | 07:10 PM
MC87SS's Avatar
Engine: 305/350/454
2 Solids
1 Rubber Isolator
Ready to ship.
Old Aug 15, 2015 | 09:59 PM
MC87SS's Avatar
Engine: 305/350/454
Another batch fresh off the workbench.
Old Aug 17, 2015 | 09:16 PM
ray jr's Avatar
im interested in one of these .. do i need to replace anything else when i do this or just put the shaft in and go ?
Old Aug 18, 2015 | 05:46 AM
MC87SS's Avatar
Engine: 305/350/454
Pretty much just bolt and go.
Old Aug 19, 2015 | 08:34 PM
MC87SS's Avatar
Engine: 305/350/454
2 Solids & 2 Rubbers left.
Old Aug 20, 2015 | 02:29 PM
MC87SS's Avatar
Engine: 305/350/454
For those of you that want to replace the bearings Mikes Montes has them.
Here is the link.
http://www.mikesmontes.com/Reproduct...it_p_1159.html
Old Aug 21, 2015 | 07:10 PM
MC87SS's Avatar
Engine: 305/350/454
Just got another 15 in stock.
Old Sep 6, 2015 | 08:18 PM
Lurbie's Avatar
Car: 89 Camaro
Install was super easy today and it looks great. Took the opportunity to move my brake lines to the other side of the shaft as well.
Old Sep 8, 2015 | 09:12 PM
MC87SS's Avatar
Engine: 305/350/454
Glad your happy with it!
I have plenty more in stock and ready to ship.
Old Sep 10, 2015 | 09:51 PM
Metalizer's Avatar
I definitely need one of these. My crap rubber one is shot. PM sent
Old Sep 16, 2015 | 03:15 PM
MC87SS's Avatar
Engine: 305/350/454
Still have a couple left in this batch.
Old Sep 18, 2015 | 01:37 PM
obeymybird's Avatar
Car: 92 camaro RS
Engine: LSA
Transmission: Magnum F
Axle/Gears: TNT 8.8 wavetrac 3.31
I think I need one of these I have a crap load of steering wheel play that goes to the shaft.
Old Sep 27, 2015 | 06:03 PM
MC87SS's Avatar
Engine: 305/350/454
Sorry for the delay, been super busy.
PM Sent.
Anyone else wanting one please PM me, i get an e-mail notification and usually answer right away or at least in a couple hours (except overnight). LOL
Old Oct 4, 2015 | 04:38 PM
MC87SS's Avatar
Engine: 305/350/454
Have a few more boxed up and ready to ship.
Old Oct 12, 2015 | 07:02 PM
MC87SS's Avatar
Engine: 305/350/454
I have a couple left and more on the way.
Old Oct 14, 2015 | 05:18 PM
marco33's Avatar
Car: 85 camaro sport coupe
Engine: 350 sbc
Transmission: th350
I am interested.
Old Oct 16, 2015 | 08:23 PM
MC87SS's Avatar
Engine: 305/350/454
PM Replied to.
Just got another batch, will be ready to ship Monday.
Old Oct 17, 2015 | 12:19 PM
thirdchance's Avatar
Car: 1991 R7U Z28 1LE
Engine: LB9
Axle/Gears: G92 3.42 Truetrac
Hi MC87SS: I have an original 1986
1. Do we discard the plastic shroud that is covering the shaft now.
2. Is there an advantage to move the brake lines towards the fender as in earlier posts?
Will PM you. Do you take PayPal? Thanks
Old Oct 18, 2015 | 05:36 AM
MC87SS's Avatar
Engine: 305/350/454
The plastic cover is not used, there may be a way to use it but most people like the cleaner look without it.
I am not sure about the brake lines, i no longer have my IROC to look at.
Yes i only take PayPal.
PM me when your ready and i will send payment instructions. Unfortunately shipping to Canada adds $45 to the cost.
Old Oct 18, 2015 | 11:13 AM
Engine: LB9
Hey Lurbie: that looks good. Engine in yet?
Was it easy to pull the hard lines towards the fender without kinking?
Anyone else done this??
Old Oct 18, 2015 | 11:43 AM
Scorpner's Avatar
Car: 85 SC, 86 Berlinetta
Engine: V6, V8
Transmission: 700r4, 700r4
The spring around the lines are there to help keep them from kinking, you can also make sure to make the bends gradual as well. They can rust from the inside out so don't be surprised if they do break which would be good in the long run if they do.
Old Oct 20, 2015 | 08:04 PM
MC87SS's Avatar
Engine: 305/350/454
Have more ready to go.
Old Oct 27, 2015 | 06:06 PM
89mulletbird's Avatar
Car: 89 GTA
Engine: 6.0L Procharged
Axle/Gears: 4.10
I already have the new shaft, but I need to replace the plastic bushing with the metal bearing. The websites listed above were for G-body cars, does their bearing also fit the F-body?
