[MA] Need seat belts, ttop headliner and seat track(drivers sd)
Car: 82 Trans AM Firebird
Engine: JASPER 350
Transmission: Swapped WC T5
Hi folks,
I need some parts for my 1982 firebird. both front seat belts do not retract correctly (worst case i need the drivers side). i do not have a headliner, and one mount to the body on my drivers side seat rusted out. I need a manual seat track on the drivers side. These parts are needed in MA.
I could also use a working instrument cluster. NONE of my gauges are accurate. I get volts and gas level, everything else is completely off. i feel like the right move is aftermarket gauges as i have heard that this is a common problem.
i probably need acouple more things, i will post them when i figure it out. And thank you in advanced for the help.
Car: 1988 Camaro
Re: Need seat belts, ttop headliner and seat track(drivers sd)
I'm parting out a 84 z28, 85 z28, and 87 firebird. I know I have the seat track. I have a stock gauge cluster out of the 87 firebird but it will have an elec. speedo and yours will be cable driven.
I have seat belts but I think the '82 was diff than rest. IIRC the 82 does not have the belt reel on the door sill.
Let me know what other parts you may need
Engine: JASPER 350
i found a thread saying that 4th gen seat belts work in the 82's. so i think i will this route. i have found a number of track bars, so the best price wins. PM's are going out for offers.
https://www.thirdgen.org/forums/inte...ts-1982-a.html
Engine: JASPER 350
I no longer need the drivers seat track. I need 4th gen seat belts next. I just tested my rear seatbelts. they do not retract. so i need a full set.
Car: 86 Z28
Engine: 385 HSR
Transmission: T56 stage 2
Axle/Gears: Moser 9" 3.70 locker
i have third gen belts all around, black. rears are lap only, retract, fronts sometimes lock and stay loose, but retract always. i will also be picking up a 98 parts car. pm me
Engine: JASPER 350
1992 Trans Am
May 10, 2023 07:19 PM
TRANSAM82-92
Interior Parts Wanted
Aug 15, 2015 01:26 PM
