[WI] parting out 87 Iroc 305TPI auto hardtop
just as the title says car was a 305 TPI auto black interior hardtop if you need something just ask I stock thousands of parts if its not on this car it could have been on another I had the wiring harness is gone but most other parts are still here
Car: 87 Formula, 91 Trans Am
Engine: 355 tpi, 305tpi
Transmission: 700r4, 700r4
Re: parting out 87 Iroc 305TPI auto hardtop
I may be looking for a cluster and a good chin spoiler. Whatcha got?
I know I got a 115 mph cluster I do have a chin spoiler that needs some work im probly all of 2 hours north of you if you wanted we could figure out a time and you can come look at what I all got
Car: 88 IROC Z/28-under re-construction
Engine: 5.7 Tuned Port
Transmission: It's in there....
Axle/Gears: 9 bolt Borg-Warner
Tpi engine/battery harness please....
Car: 1988 IROC-Z
Transmission: T56 swap ongoing
Axle/Gears: 2.77 9-bolt Posi
Got the support brackets for the air conditioner compressor? Looking for the rods that go from the exhaust manifold to the main bracket, and a second rod that goes from the intake manifold to the main compressor bracket.
Engine: 305 TBI/305 TPI
Transmission: World Class T5/missing
Axle/Gears: 3.08/G92 3.45 posi
Are you looking for v belt or serpentine belt setup? I'm switching my 87 over to serpentine belt when I get it running so I have those 2 braces that came on the motor I pulled from it. it was from the stock v belt setup though.
Don't suppose you would sell just the heads? and if you would, how much would it be to ship those if you are willing?
Car: 1988 IROC-Z
I have a V-belt setup, so it sounds as if you have exactly what I'm looking for.
Indeed I think it is. I don't think I will be able to sell it for much so you can just have them. I hope you are not in a super big hurry for them though because I am pretty busy the next few days. Send me a PM and we can try and figure it out.
Car: 1988 IROC-Z
PM sent.
I don't know how the people on eBay ship them for free. I don't want to spend $300 on used heads but that's the only place I can find 081 heads.
you looking for IROC hood or any hood? I have a decent IROC hood needs paint only problem in it has no louvers I also have flat ones
Do you have the bolt plate that holds the front lip to the bottom of the fender for both sides I lost mine in the process of redoing it
89irocz355
101
Sep 19, 2016 04:05 AM
[PA] 305 TPI long block
dpmalibu
Jan 25, 2016 12:14 PM
