Jeep cherokee and Astro van steering shafts
Car: 1988 camaro "SS"/ 1991 305/T5
Engine: 383 LT1 in progress/LT1TBI 355 soon
Transmission: Probuilt 700R4 3600 stall/ T5
Axle/Gears: Moser axles, 3.42 Eaton Posi
Up for sale is a fully cleaned, prepped, painted and welded jeep cherokee steering shaft and Astro Van steering shafts . I have plenty available. The are ready to rock. I'm asking $ 50 shipped for the cherokee shafts and $60 for the Astro shafts to the lower 48. I do accept paypal.
Re: Jeep cherokee steering shafts
Bump
Again...wow
Bump
To replace the stock rag joint with a "solid" setup. Adds stiffness and response to your steering
Car: 1988 Trans am GTA
Engine: L98 350 TPI
Axle/Gears: Factory 9 bolt w/disc brakes
Very simple, the only thing needed to do is to grind a little of the top part of the steering wheel connector so the bolt slides through
I haven't received one
Car: 86 Trans AM
Engine: LS1 (not stock...)
Transmission: Built T56
Axle/Gears: Strange 12-bolt w/ 3.73
What exactly did you need to weld on the XJ shaft? Those are basically bolt in as is. Just curious...
Justin
Justin
Typically I'll throw a bead on the upper part of the shaft that "turns" to create a more solid connection. Basically weld the middle upper shaft to the coupler. If I feel it needs it, I do if the middle shaft is good and tight, I'll leave it be
Car: 1989 GTA
Engine: 5.7 TPI
Axle/Gears: 3.27 (Stock)
Received mine yesterday. Looks good to go. Probably install this weekend. (Ordered through FB listing on 3rd gen swap group.)
Awesome, glad you got it
Still have one available and I should have more this weekend
Bump
I do indeed
Car: 1991 Camaro RS
Transmission: WC T5
Axle/Gears: Torsen 3.73
I'll take one then. I'm located in Madison ct, 06443, pm me your paypal info and I'll get the money to you today or tomorrow
Pm sent
Bump, I have a few more available
Awesome, glad it got to you. Thank you for your business
I have a few available
Yes sir. I just ask you cover the paypal fee
Car: 1986 Pontiac Firebird
Engine: 383 SBC
Axle/Gears: Hawks 8.8 with 4.10’s
Awesome! Glad these are being offered again! You'll be getting payment from me very soon (as long as you still have stock) and Happy Thanksgiving!
Bump
Pm replied. I also have a few more in stock
Bump
I can yes
Car: 1989 formula
Axle/Gears: 9-bolt & 3:45 gears
I'm very interested in a modified astro shaft from a non AWD astro. How long does it normally take for you to get one and get it ready for a plug and play? And how much?
I can have one ready in a few days, I can let them go for $60 shipped
Car: 1989 formula
Great! Get one ready and snap a few pics. I'm sure it will look good. I'll take it when your ready.
Shaft difference video
Bump
Sure do
Car: 1991 Camaro
Engine: 5.3L LS
Ok I picked up a few astro shafts for those who wants them instead. I'll get them cleaned up and pics taken later
Car: 86 Trans Am WS6
Engine: 383 stroker
what are the odds, I just bought a cherokee and the joint is pretty corroded and concerns me.
Would this still work in a xj or does the mod prevent it?
Do you mean the cherokee shaft is going in a jeep?
