How much is a new LT1 engine cost, for a 1987 IROC?
Old 01-22-2018, 02:26 AM
Want a title? Post!
Mauricez3's Avatar
Old 01-22-2018, 05:56 AM
86LG4Bird's Avatar
Car: '86 Bird, 96 ImpalaSS, 98 C1500XCab
Engine: LG4, LT1, L31
Transmission: 700R4, 4L60E, 4L60E
Axle/Gears: 3.73 Tors, 4.88 spool, 3.73 Eaton
Re: How much is a new LT1 engine cost, for a 1987 IROC?
your left nut
Old 01-22-2018, 01:57 PM
navy02ws6's Avatar
Engine: LS1, LB9, L03
If you're talking about a Gen I or Gen II LT1, they've been out of production for quite some time.
If you're talking about a Gen V LT1, they're about $10,000 plus countless other necessary parts and modifications that you'll need to put it in a third gen.
http://www.karlperformanceparts.com/...4aAv8LEALw_wcB
Old 01-22-2018, 02:34 PM
Abubaca's Avatar
Car: 1988 Iroc
Engine: L98 350
Axle/Gears: Hawks 8.8 - 3.73
The original Gen1 LT1 was an early 70's carb'd performance engine.
The Gen2 LT1 was an early to mid 90's EFI engine.
Neither are currently sold new, and there's no real benefit to swapping in either of them if you came across one even for free.
The Gen4 LT1 is currently sold in Camaros and Corvettes (I believe) and I'd assume it's available as a crate engine. It would make a heck of an upgrade but there is a LOT of work needed to do this, as has been mentioned.
NONE of these ever came in a thirdgen F-body.
A stock/re-manufactured 305 or 350 originally from an 87 Iroc could probably be had for a bit under $2000 as a long block. You just put your intake and accessories back on it.
Old 01-27-2018, 10:34 AM
Vanilla Ice's Avatar
Car: 92 Trans Am Conv
Engine: LB9
Axle/Gears: 3.08
I definitely disagree. The 90s LT1 may be a redheaded stepchild, but it's still far better than what came from the 80s. Having driven many of both and owned a few I'd take an LT1 every single time.
Old 01-27-2018, 10:46 AM
Drew's Avatar
I can refute LT1 superiority claims with a single term. Optispark.
/thread.
Old 01-27-2018, 11:23 AM
Engine: LB9
Axle/Gears: 3.08
/thread.
Blown way out of proportion by LS1 nut huggers trying to claim superiority. I never had an issue.
Every new generation likes to berate the previous to feel better about themselves.
They’re all SBCs and have enough aftermarket to fix any issue, factual or fabricated.
Old 01-27-2018, 11:30 AM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
Reverse cooling is the only benefit that an LT has over a typical SBC. Optispark has it's issues well documented. The LT is a foot note engine.
Old 01-27-2018, 11:31 AM
Bow_Tied's Avatar
Car: 1987 IROC-Z
Engine: L98 5.7L
Transmission: MD8 700R4
Axle/Gears: G80 GW6 3.27:1
Well the optispark can have issues, if you already have an LT1 with one though you can now ditch the optispark with a bolt on LSx kit from Torqhead. Sorry for the hijack.
Old 01-27-2018, 11:36 AM
BizJetTech's Avatar
Car: 87 Trans Am
Engine: 5.0
/thread.
I can attest to that !!
Jay_rich
04-20-2021 08:37 AM
bk92rs
06-12-2017 04:01 PM
gcj280
04-25-2017 04:43 PM
T-IROC87
10-19-2016 10:40 AM
raychappell
09-11-2016 06:16 PM
Quick Reply: How much is a new LT1 engine cost, for a 1987 IROC?
