Suspention on 82 camaro
I have a 1982 camaro that I'm going to put a 383 and th400 in for a temporary build. It's going to be a street strip car so I was wondering what are yalls opinion on the stock suspension. Eventually it's getting a full tube chassis with 4 link but for now it's stock with aftermarket shocks. What's the ups and downs of stock suspension and how "good" is it?
Car: 1990 Firebird Drag car build
Engine: 355 being rebuilt
Axle/Gears: 4.56 LDS
Re: Suspention on 82 camaro
You at least need sub-frame connectors these cars can twist pretty easily otherwise if you actually hook up and everything else holds together. Depending on how tricked out your 383 is you may need a different rear end also. Strong 383's are taking these cars under 12 seconds pretty easily and at that point a roll bar and other mods become mandatory at any NHRA track.
How easy is easy? What kind of power numbers can twist a frame? And eventually I want a ford 9"
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Stock power only can distort these cars. Sub Frame connectors are the #1 first mod that should be done on these cars. It is recommended that you upgrade the stock platform on these cars prior to adding a bunch of power. That means suspension upgrades/repairs (worn bushings shocks etc), sub frame connectors, brake upgrades, etc.
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
These cars have two main structural areas from the factory, one is located in the front and the other around the rear. The middle of the car is a twizler and can twist about these two frame areas. Sub frame connectors connect the front to the rear and make it one big subframe taking the twist out of the middle of the car.
They have bolt in and weld in versions. Most of the top brands will require floor pan modifications. I prefer weld in. Heidts makes a bolt in that supposedly contours to existing floor, but have not heard much about how good they are.
T top cars twist worse than hard top cars. Seen a T top car twist so much going down the track that one of the tops ejected itself.
once one of these bodies twist past the point of springing back the body is pretty well gone. Frame straightener can bring it back to stock, but it will be even more prone to twisting from then on.
REVLIMIT
11-18-2001 03:56 PM
Christos
05-12-2001 07:32 PM
