Completed: Power Steering Pump Replacement
Old 05-24-2019, 07:48 PM
92RS-HeritageEd's Avatar
Car: 92 RS / 90 IROC-Z
Engine: 305 / 350
Axle/Gears: Non-Posi / Posi - Both GU2 - 2.73
Up next on the list of things that will make a person swear... the power steering pump pulley. I have the pulley removal tool, but it isn't coming off. Is this a pressed fit like the balancer, Any tips?
Old 05-24-2019, 08:07 PM
Received 1,672 Likes on 1,269 Posts
Re: Power Steering Pump Pulley Removal
Yes it is a press fit.
Yes it will come off. Always does. I've never even had to swear in more than 3 or 4 languages before I found the one it responds to. (yes I can swear in LOTS...)
Old 05-25-2019, 11:24 AM
Engine: 305 / 350
I traded swearing for elbow grease and wouldn't you know... it's off. It's a shame pulling a pulley felt like it took everything out of me.
Old 05-25-2019, 12:03 PM
Engine: 305 / 350
I've only located 2 bolts on the face of the PS Pump, removed them but the PS Pump isn't budging. Isn't it supposed to slide right out?
EDIT: Found a 3rd bolt thanks to a ThirdGen YouTube vid. Found it hidden behind some dirt and cobwebs. Once removed it did slide right out.
Old 05-25-2019, 01:02 PM
Engine: 305 / 350
Anyone know if it's sate to use a torch on the area around that pressure fitting? Tried some PB Blaster but I can't get it to break loose...
Old 05-25-2019, 01:50 PM
rburrow87's Avatar
Car: 1975 Pontiac Firebird Formula 400
Engine: SBC 350 w/Pro-Flo 4
Transmission: M29 T56
Axle/Gears: Stock 10 bolt w/3.42 and new Auburn
Re: Power Steering Pump Replacement
Not sure about torching that.
Can you get the other end of the line off? Might be easier to break that end loose since it's on the steering box and attached to the car.
You should seriously consider replacing that line (power steering pressure line) anyways with how old and crusty it looks. It should be readily available at a local parts store. Would be wise to replace the rubber return line as well. I think I see a power steering pressure switch/sensor on the pressure line, so make sure the new hose has a fitting for it. I think AC equipped TBI cars got that setup.
Old 05-25-2019, 02:09 PM
Engine: 305 / 350
I didn't try the other end as I was trying to reuse the existing line. The first 2 of 4 parts stores in my area sell a replacement but it doesn't have the space for the pressure switch, checked before digging in. I'll check the others. Checked the others and they don't have it either.
Update: The bolt broke loose on the rear of the PS Pump however it's not spinning around the line as it's sludged up. Made a attempt at the other end and no-go.
Old 05-25-2019, 03:51 PM
I don't believe I'd torch that.
Looking at the condition of that line, if you're replacing the pump, just replace the lines too. It's right about $20 IIRC. The return line is just a piece of hose, special hose, but still just a piece of hose. Not worth trying to preserve old wore out stuff that the VERY FIRST THING it's gonna do after you put on a new pump, is to start leaking and need replacement ANYWAY. (Murphy's Law and all that... which the REAL Murphy's Law is, if it can go wrong, it already has, and you just haven't found out about it yet and won't until it's too late to do anything about it)
I wouldn't worry too much about the pressure switch. All it does is break the AC compressor coil circuit when the wheels go to full lock. Trivial at best.
Old 05-25-2019, 04:49 PM
rburrow87's Avatar
Yeah if you just want to get the car back together, I don't see any harm in leaving that switch out for now and using the standard line.
And I agree, it's probably best that you do what you need to do to replace the soft lines. They're clearly old or original with how much they're fighting, and they'll probably blow out now that they've been disturbed this much.
What kind of wrenches are you using? For the power steering gear side, you could try some crowfoot flare nut wrenches which would let you get some torque on them with a 3/8 ratchet. Harbor Freight sells some, not sure if they typically stock them though. Normally you don't want to skimp on flare nut wrenches, but they're only $12 for a set.
Old 05-25-2019, 05:29 PM
Engine: 305 / 350
I didn't torch it. Your explanation of the pressure switch provides clarity on why NO parts store in my area has a line w/ that built in. I don't even recall seeing a setup like that on any other TBI car/truck at the jy. Then again, may not have been looking for it. Thanks.
I'll replace the little hose too and I'm using the HF Crowfoot wrench set. I'll continue soaking it & trying to free it. Thanks.
Update: Found I wasn't using the correct size wrench. Had this "Power Steering Line Flare Wrench" delivered and it still wouldn't budge.
Old 05-25-2019, 07:44 PM
rburrow87's Avatar
You could also try "shocking" the flare nut with a hammer and punch (or socket extension) positioned like this in a few spots around the nut to try to help it break free
Completed: Power Steering Pump Replacement-1x4akxx.jpg
Old 05-25-2019, 08:50 PM
Engine: 305 / 350
More PB Blaster overnight and trying that in the morning. Are there any other products better at freeing seized bolts?
Old 05-25-2019, 08:55 PM
rburrow87's Avatar
Since you're replacing the line the only other thing I can think of is just cut the tube so you can slip a 6-point socket on it and really give'er, maybe even throw a few ugga-duggas at it if you have an impact.
Old 05-26-2019, 08:05 AM
Engine: 305 / 350
Got the the line free w/out damage! Maybe I was expecting PB Blaster to undo 30 years of crud in 2 or 3 minutes which wasn't realistic lol
Also found that parts store may have the replacement I need, I think if it's specified "With A/C" then it'll have the port for the pressure switch.
Old 05-26-2019, 05:48 PM
Engine: 305 / 350
With all forward progress comes some kind of minor setback... My HF Pulley Puller / Installer pulled the pulley per the instructions but the set screw now doesn't screw into the installer bolt like the threads were smashed while removing the pulley so i'm stuck.
But at lease I'm almost done....
Old 05-26-2019, 06:39 PM
blacksunshine'91's Avatar
Transmission: Pro-built 700R4
If your pulley puller/install kit broke, just borrow one from Autozone or whatever local parts store you have. In the end, it doesn't cost you anything but the gas going to/from the store.
In the future, I recommend popping the pressure line off the pump before removing the pump from the bracket. If you go at it from under the car, the nut is pretty accessible and the bracket keeps the pump from moving around.
Oh, and ALWAYS replace that pressure line if you are removing the pump or gearbox. Easy insurance since you already are breaking the integrity of the system.
Old 05-26-2019, 07:57 PM
rburrow87's Avatar
I'm fairly sure the threads in the pump are a commonly available 3/8-16. You could get a long bolt, bottom it out in the pump, and use a nut and some washers to push it on. I've had new pumps that included those for installing the pulley.
I've rented the AutoZone one a few times and it works great. I ended up just keeping it the last time I did.
Old 05-27-2019, 07:42 PM
Engine: 305 / 350
Re: Completed: Power Steering Pump Replacement
Ran back to HF for a Lifetime Warranty swap on the installer tool, installation of the pulley was easy. All done now and turning the corner in this ThirdGen never felt smoother.
Old 05-27-2019, 07:43 PM
rburrow87's Avatar
Glad you were able to get this all sorted!
Old 05-27-2019, 08:58 PM
Chopski's Avatar
Car: 1989 IROC
Axle/Gears: 3:42
What type of issues did you have? Mine when I have not drove it in awhile acts like it is stuck in place and then comes free. It also moans a little and not in a good way.
Old 05-27-2019, 09:20 PM
Engine: 305 / 350
I really don't know, I think the pump was shot, you pour fluid in and as soon as the car was started it'd drain from somewhere in the rear of the pump like a faucet.
Old 05-27-2019, 10:40 PM
Chopski's Avatar
Car: 1989 IROC
Axle/Gears: 3:42
LOL. I don't have that issue.
Old 05-28-2019, 10:45 AM
For any future issues with your pump or gearbox, I've had great experiences with Marty at Powersteering.com when he rebuilt my box and pump.
Old 05-28-2019, 05:46 PM
J.C. Denton's Avatar
Car: 85 Iron Duke, 88 GTA and 92 TA
Very interesting... I installed a new / reman Cardone pump last year and have the exact same problem. It is also stuck and breaks free and it moans. Found a nice used original pump from a 91 donor but interesting you are having the same issue. Do you also have a new pump?
Old 05-28-2019, 07:34 PM
Chopski's Avatar
Car: 1989 IROC
Axle/Gears: 3:42
Nope looks to be original equipment.
91RSCamaroSteve
LSX and LTX Parts
02-02-2013 05:30 PM
Grizzlybear226
09-24-2011 03:57 PM
ThommyDee's86Z
09-08-2008 09:36 PM
roughskinjrz
09-08-2005 02:19 PM
Daz
08-01-2004 12:51 AM
Quick Reply: Completed: Power Steering Pump Replacement
