Would this dual exhaust work on my 1982 firebird?
Car: 1982 Firebird
Engine: 5.0 LG4
Transmission: 200C
Axle/Gears: 2.73 open diff
https://www.jegs.com/i/JEGS/555/3055...CABEgKBjvD_BwE
it says from 1967-1981 firebird/camaro I’m not sure if it could be adapted
Re: Would this dual exhaust work on my 1982 firebird?
"Could"? Sure, if you're into masochism. Otherwise stick to something designed to fit. Thirdgens don't really have room for duals. People can and have done it, but generally they're a compromise in one way or another, often in ground clearance - or rather the lack there of.
The following 2 users liked this post by Drew:
82Firebird5.0 (12-05-2019), T.L. (12-05-2019)
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
You can buy the Holley true duals for our car for like $500 more than that kit.
Car: 1986 IROC Z
Engine: 5.0 TPI
Axle/Gears: 3.23 Posi
If you do decide to go the Holley route, please document the install with photos.
Well, there's that Dynomax header-back dual setup... But it's intended to bolt up to their junk headers, and uses restrictive piping, and isn't emissions friendly (no cats). Just overall there's a reason it's not a popular kit. By design it should fit, it'd probably perform just marginally worse than a stock style single 3" exhaust.
https://www.summitracing.com/parts/wlk-89009
WildCard600 (12-05-2019)
Car: 1982 Firebird
Engine: 5.0 LG4
Transmission: 200C
Car: 1982 Firebird
Engine: 5.0 LG4
Transmission: 200C
No; there's no room under a 3rd gen for that or any system like it.
^^^^This is the only system of which I'm aware that might fit. The issue is trying to squeeze two exhaust pipes down a pathway only intended for one while still maintaining adequate clearance from not only the ground, but also from the transmission, driveshaft, the underbody, and the rear axle/suspension, all the while not creating a handful of rattle problems.
Car: 1982 Firebird
Engine: 5.0 LG4
Transmission: 200C
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
y-pipe is specific to the headers
the 3" dynomax cat back system for the fourth gen can be fairly easily modified to fit our vehicles. Search for it under Dyno Don. There's a thread that covers it.
Car: 1982 Firebird
Engine: 5.0 LG4
Transmission: 200C
couldn’t seem to find it, could you link the exhaust you’re referring to? I need headers, y pipe and exhaust as I’m considering a 3” single
82Firebird5.0 (12-08-2019)
I haven't looked lately, but Dynomax/Walker has been systematically discontinuing their third and fourthgen exhaust systems over the past few years. The last time I looked into the 2 piece 3" intermediate pipe, one piece or the other was no longer available from most sources. FWIW.
Car: 1982 Firebird
Engine: 5.0 LG4
Transmission: 200C
It's no big deal. The 3" Dynomax pipe was just a pick and choose alternative to buying a cat-back exhaust kit, or settling for a 2.5" or 2.75" intermediate pipe that necks down to 2.5" at the muffler. It's potentially no longer relevant because Walker/Dynomax discontinued the 4th gen kit those parts were made for. Someone thought they needed to have a bullet muffler in the middle of the intermediate pipe, so the 54064 pipe isn't available anymore.
The new Dynomax 4th gen setup -
Summit sells the AP Exhaust APH-X5500, which they say is a 3" intermediate pipe alternative to the Dynomax numbers. Might be a decent substitute.
There should still be plenty of nearly bolt-on aftermarket setups to choose from. Magnaflow, Flowmaster, Dynomax, Hooker, Borla, etc or stock replacement type parts from Walker (parent company of Dynomax), AP Exhaust, etc. The harder part is finding EXACTLY what you want. The options for picking and choosing this piece or that piece of an aftermarket kit are just about gone, but complete cat-back exhausts are still out there, and stock replacement stuff is still out there.
Magnaflow
Flowmaster
Hooker
Summit
Borla
Hooker
Most of the aftermarket stuff for a 87-89 350 thirdgen will be a 2.75-3.00" intermediate pipe design that will fit any 82-92 with a little work. Some of the 4th gen setups will fit with some changes to the hangers. Just gotta look around a bit. Avoid the mix and match approach, because a lot of times the individual parts aren't available separately, and they aren't designed to fit together.
Magnaflow
Flowmaster
Hooker
Summit
Borla
Hooker
Car: 1982 Firebird
Engine: 5.0 LG4
Transmission: 200C
Magnaflow
Flowmaster
Hooker
Summit
Borla
Hooker
Magnaflow
Flowmaster
Hooker
Summit
Borla
Hooker
Car: 1986 IROC Z
Engine: 5.0 TPI
There just isn't much room under there for two pipes.
82Firebird5.0 (12-09-2019)
Or you could just go bigger pipe rather than dual pipes
https://mufflex-performance.com/6-f-body-catalog
Car: 1982 Firebird
Engine: 5.0 LG4
Transmission: 200C
Many years ago---against my advice---a friend bought a similar setup for his '84 (?) Z28 (305 HO, IIRC) and under protest, I installed it for him. It was a mess from the git-go, requiring some welding, re-bending, much tweaking of hangers, etc. Not only did he not realize any performance gain, but he was constantly under the car fixing rattles. A few months later, we pulled it off, tossed it in the trash, and put the factory system back on.
i just can’t find anything and I’m not good at fabrication and don’t know anybody who is. Also none of the muffler shops in my area will bend exhaust either
Car: 1982 Firebird
Engine: 5.0 LG4
Transmission: 200C
Car: 1986 IROC Z
Engine: 5.0 TPI
"Bolt-on" systems rarely are; welding equipment is expensive, and the learning curve to acquire fabrication skills is steep.
Headers are yet another topic. Back up to the exhaust forum and there's a sticky that covers what was/is available. https://www.thirdgen.org/forums/exha...ion-chart.html
Read the stickies. Just keep in mind that they're somewhat dated, and what was available when they were written may no longer apply.
