88 L98 not starting when warm
Old Feb 5, 2026 | 01:17 PM
snackstick's Avatar
First let me say this is an engine swap using a 1988 L98 engine and a Painless wiring harness. My car will start fine and runs fine when cold Will not start back up warm unless I use starting fluid.The injectors is not firing when warm (using a noid light). What I want to know is what would send the ECM a signal not to fire the injectors when warm? Or what information is the ECM not getting. I have change or checked all of the things listed below. Plus I have checked everything that anyone on the fourm has suggested. I have been working on the swap since April of 2025. I desperately need some help!
NO CODES
Fuel pressure 45 psi starting 40 psi running
Injectors, I sent the original injectors and had the refurbished, Ohms reading 16.7 cold, and 16.0-16.5 hot. Holds pressure with only a slight drop, it takes over 30 min to go from 40 psi to 0
Cold start injector – resistance 3.3 cold, 4.3 hot
Rebuilt fuel pressure regulator and added an adjustable fuel pressure regulator top
MAF replaced with 2 new, voltage correct– seems to be working fine, engine changes and code 34 when unplugged.
TPS, voltage correct
New coolant temp sensor - checked resistance hot and cold - good
New MAF burn off relay
New fuel pressure relay
New electric spark module
New ICM – 3 new, checked good at part store
New coil
New rotary button
New distributor cap.
Distributor coil pick up resistance 782 when cold 862 when hot
Pulled spark plugs and check gap (good) and for being fouled out ( none fouled)
Changed ECM and prom
Old Feb 5, 2026 | 01:43 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: 88 L98 not starting when warm
Does it start with a sprits of starting fluid ? What’s base timing set to ?
Old Feb 5, 2026 | 02:15 PM
snackstick's Avatar
Yes.
Old Feb 5, 2026 | 02:20 PM
Engine: Lb9
Transmission: M20
Originally Posted by snackstick
Yes.
have you disabled coil power pipes up the csi see if it sprays when engine is cranked ?
Old Feb 5, 2026 | 04:21 PM
snackstick's Avatar
yes it starts with a small squirt of starting fluid.
Old Feb 5, 2026 | 04:22 PM
snackstick's Avatar
if the resistance is correct on the injectors can they still be bleeding? if so how would I find the one that is bleeding
Old Feb 5, 2026 | 05:45 PM
Engine: Lb9
Transmission: M20
ohms just tells you state of coil condition. If pressure hold hot and cold at 40-45 for 10 minutes or more nothing is bleeding down.
Old Feb 6, 2026 | 01:24 PM
snackstick's Avatar
just check the fuel pressure goes from 45 psi to 0 in about 5 sec. I assume that something is bleeding. but how do I find the injector that is. I smelled the vacuum line to the fuel pressure regulator and didn't smell any gas. I'm going to change fuel pumps again to make sure it's not the check valve.
question. I know that the injectors are not pulsing. the truck is not getting any gas. So what is causing that
Old Feb 6, 2026 | 01:27 PM
Engine: Lb9
Transmission: M20
As mentioned pull up the csi to see if it’s it causing the flooding. If not you can tear down the tpi and raise the rail or prime multiple times and check plugs for being wet.
Old Feb 6, 2026 | 02:06 PM
snackstick's Avatar
I have already checked the plugs to see if they were wet, none was. do you really think it's flooded sense it starts so quick with just a small squirt of starting fluid and if I wait 10 to fifteen min it will start. I want to thank you for all your help
Old Feb 6, 2026 | 02:30 PM
Engine: Lb9
Transmission: M20
One question not asked was does pressure hold with the return pinched or can you pinch the return in your application? I’m really not sure where the fuel is going when the pressure drops .
Old Feb 6, 2026 | 03:25 PM
snackstick's Avatar
What color wire and pin number is the ground on the ECM? I want to run a ground directly to the battery
Old Feb 6, 2026 | 04:16 PM
Engine: Lb9
Transmission: M20
? Kinda off in left field . You want to know all the ground wires of the 1227165 ?
Old Feb 7, 2026 | 08:41 AM
snackstick's Avatar
I want to make sure that my ECM is grounded properly. I see that they are 3 different systems ground. D1 D3 D10
Old Feb 7, 2026 | 05:32 PM
Engine: Lb9
Transmission: M20
A12 as well
Old Feb 7, 2026 | 06:04 PM
Can't be that. If it was, a shot of pure oxygen would start it up, NOT a shot of fuel.
Can't be that. Grounding the ECM is important for sure; butt it won't be poorly grounded during starting, then magically repair itself after a shot of ether.
​​​​​​​I want to run a ground directly to the battery
Great. Won't hurt. Also won't help. That ground doesn't change in between starting and running.
​​​​​​​the flooding
THERE IS NO "the flooding". If there was, flooding it with YET MORE FUEL, wouldn't make it start RIGHT UP.
Put aside the "maybe it's this maybe it's that maybe the aliens are testing the humans' problem solving skills" and EMPLOY SOME LOGIC. That logic is, if it won't start "normally", butt if you squirt in some ether it starts, then IT LACKS FUEL AT STARTUP. C'mon d00d, it's just a car, it's NOT THAT HARD. Use logic, reason, and common sense (which I fully realize, its name is a bit ... misleading ...) to get to the root of the problem. Which is, NOT ENOUGH FUEL AT STARTUP. Logic. Reason. Observation. See my signature.
Ignore all that s*** about leaking injectors. That's NOT the problem if it starts up by adding more fuel. The Problem is, fuel is GOING AWAY at that time, not that it's appearing in excess. Screw your head on straight and look in the right direction.
Old Feb 7, 2026 | 06:50 PM
NoEmissions84TA's Avatar
I know nearly nothing about TPI.
Does the following fit his condition? OP said,
  • My car will start fine and runs fine when cold. Will not start back up warm unless I use starting fluid.
  • yes it starts with a small squirt of starting fluid
  • the fuel pressure goes from 45 psi to 0 in about 5 sec
  • if I wait 10 to fifteen min it will start
Again, I know nothing. But to me, what fits this condition is that a leaky injector(s) is putting fuel into the intake when he shuts the engine off WARM. It won't restart because it is flooded. The warm engine takes about 10-15 minutes to evaporate that fuel and then he is able to restart the engine. Liquid fuel does not ignite, therefore a small shot of starting fluid (very well atomized) allows the engine to start.
Right or wrong?
Old Feb 8, 2026 | 08:51 AM
snackstick's Avatar
Right or wrong?
I figured it was a leaky injector but I pulled the plugs and they were dry. How do I find the one or ones that is leaking. to expensive to replace all of them.
Old Feb 8, 2026 | 03:22 PM
Go back to #9.
Old Feb 10, 2026 | 03:10 PM
snackstick's Avatar
OK Sofakingdom. I have been looking this probem head on for 10 months.I have changed everthing that would cause it to not start when warm. I have done everything that was told to me to do on this fourm and I'm no closer than I was 10 months ago.I just drove the truck and it ran like she i t. I have a 40 chevy with a l98 tpi that I've had for 30 + years and never had a problem with it.
Old Feb 11, 2026 | 11:39 AM
snackstick's Avatar
# 9 what?
fuel pressure is holding for 30 min before it starts to drop from 40 psi.
can the distrubutor pickup be bad even though the restistance reads good hot and cold. that is the only thing I haven't changed
Old Feb 11, 2026 | 11:41 AM
Engine: Lb9
Transmission: M20
# 9 what?
what changed from
the fuel pressure drop ? He was referring to post #9
Old Feb 11, 2026 | 01:53 PM
snackstick's Avatar
I don't know
Old Feb 11, 2026 | 08:16 PM
Engine: Lb9
Transmission: M20
# 9 what?
are you missing injector pulse or spark or both when warm engine?
Old Feb 12, 2026 | 08:37 AM
snackstick's Avatar
I have spark but no injector pulse when warm. If I drive the truck and get it up to 180 then it takes longer to restart
Old Feb 12, 2026 | 09:16 AM
Engine: Lb9
Transmission: M20
Any pulse with a noid with all injector plugs pulled from
the injectors ?
Old Yesterday | 01:19 PM
snackstick's Avatar
when the engine is cold and the 9th injector fires should there be a ref signal from dist? when cranking and running I tried to read a ref signal using a multimeter and got no voltage even when running. Am I doing it correctly
Old Yesterday | 01:27 PM
Engine: Lb9
Transmission: M20
the csi is not ecm controlled, to see the reference signal easiest to use a scanner and see cranking rpm. Or could use a scope to see the tach like signal on the ppl/white wire.
Old Yesterday | 03:29 PM
snackstick's Avatar
Thank you for your help, I'm trying to understand the way this system operates.When I say it starts and runs cold, is it possible that when cold it starts with the csi and runs but when warm the the csi don't fire and it don't start except with a squart of starting fluid. meaning that the injectors are not firing at any time until it starts running. if so why. I have someone coming with an OBD1 scanner and hopeful he will be able to tell me what is wrong.
Old Yesterday | 04:29 PM
Yes it certainly is. Not sure how or why, butt this seems to be a more accurate way to attack the problem than "leaking injector". Since after all, a leaking injector would be putting fuel into the intake on its own; adding YET MORE fuel (starting fluid) wouldn't "overcome" or "fix" that.
EFI engines in general are supposed to shoot a shot of fuel with the injectors whenever the ignition is first turned on. Sounds rather like, for whyever, yours is not doing that. Since this is an engine swap, as opposed to a totally stock situation, my guess would be, something is mis-wired, such that the ECM isn't seeing the ignition being turned off and back on again, for whatever reason. The problem is most likely upstream of the ECM; something like, some connection to it that should be getting switched ignition, is getting constant battery instead.
I kinda doubt that a "scanner" will be of much help. Rather, check each connection in the schematic that Tuned posted, that says "Ign"; and make sure it goes to 0V when you turn off the key. Wouldn't surprise me if, for example, you have the "Ign" and "Batt" reversed.
Old Yesterday | 05:39 PM
Engine: Lb9
Transmission: M20
check ecm
A6 for power key on and cranking
Old Today | 09:24 AM
snackstick's Avatar
the Ign and Batt are correct. I can get a chip that eliminates the VATS and CSI. Do you think that would let the ECM fire the injectors. This chip is not a replacement for the prom but attaches to the prom.
https://fbodyecmprogramming.square.site/
Old Today | 02:55 PM
Engine: Lb9
Transmission: M20
You asked for the same advice on corvetteforum!
Old Today | 05:10 PM
BHR's Avatar
BHR
https://www.youtube.com/watch?v=ycOOnFUsTmw
Yes its how most ALL tuners do tunes for the GM OBD1, the chip is rewritable and the G1 adapter is used to piggy back off the stock memcal. Good investment if you ever want to adjust your tune yourself in the future you would then only need the moates burn 2 as you already have the rewritable chip and adapter
Old Today | 05:13 PM
BHR's Avatar
BHR
Tuner cats has the adapter for cheaper go the left of the site and click Adapters/Flash
http://www.tunercat.com/
Old Today | 06:50 PM
snackstick's Avatar
did I. I'm sorry but I don't remember. I will look and see what the answer was. I know I was sent the information from someone.
Old Today | 07:57 PM
BHR's Avatar
BHR
Checking off the flag in the chip is the same as when bypassing with a hz modulator
https://www.corvetteforum.com/forums...985-ecm-2.html
99xtreme
Today 09:36 PM
Gen-2/4
Jul 1, 2010 09:03 PM
tsram
Jun 8, 2010 12:34 PM
joebeagle
Mar 31, 2010 07:33 AM
WhiteFormula350
Mar 24, 2010 07:19 AM
