92 , 3.1 valve cover thread size ?
Old Apr 1, 2026 | 06:37 AM
Bradsdad's Avatar
I don't know if these valve cover studs are standard, .. do you know the thread size ?? Much appreciated
Old Apr 1, 2026 | 08:45 AM
johnyromt's Avatar
Re: 92 , 3.1 valve cover thread size ?
For a 1992 3.1L engine, the valve cover bolts typically use M6 x 1.0 thread size. It’s important to check the thread pitch and length before purchasing replacements to avoid stripping the aluminum covers. Using the correct size ensures a proper seal and prevents oil leaks, which is common if the wrong bolts are used.
Old Apr 1, 2026 | 08:29 PM
86blackiroc's Avatar
Car: basic third gens
Engine: that I like
Transmission: to restore
Axle/Gears: and enjoy
Those studs will either be 6mm x1.0, or 8mm x1.25... I don't remember for certain and I'm too lazy to walk out to the shop. 98% sure they are 6mm though.
Old Apr 2, 2026 | 06:42 AM
LLCooLM495's Avatar
Car: 1992 Firebird
Engine: 3.1L LH0
Transmission: Tremec TKX
Axle/Gears: 3.23 Torsen
Yep, 6mm x 1.0, according to the Fiero forums. I run Fiero valve covers on my car with a mix of the Fiero bolts and 3.1 studs (which are standard btw), so I can confirm they fit.
Old Apr 2, 2026 | 09:10 AM
Engine: that I like
Are you saying the 3.1 heads are drilled for standard thread? I don't remember that at all. The 60° v6 was designed pretty much as all metric, aside from NPT ports.
Don't worry about proving me wrong, I'll just do that myself when curiosity gets the better of me, lol.
Old Apr 2, 2026 | 09:21 AM
LLCooLM495's Avatar
Car: 1992 Firebird
Engine: 3.1L LH0
Sorry if there was some confusion, when I say "standard", I mean the 3.1 came with the studs from factory. They are indeed metric, M6 x 1.0
Old Apr 2, 2026 | 09:38 AM
Engine: that I like
Ah, OK. I definitely had read that wrong, lol.
Old Yesterday | 10:26 AM
Bradsdad's Avatar
A big thank you ,
goliath88
Jul 19, 2020 09:47 AM
littlesister99
Nov 26, 2012 05:02 PM
transamice
Jul 14, 2008 12:09 AM
firebirdjosh
Nov 24, 2005 06:33 PM
9D1BURD
Apr 16, 2004 10:22 AM
