DFI and ECM Discuss all aspects of DFI (Digital Fuel Injection), ECMs (Electronic Control Module), scanners, and diagnostic equipment. Fine tune your Third Gen computer system for top performance.
ECM capacitor identification pls 👉👈
Old Today | 02:16 PM
Lost_Arts's Avatar
I have a 92 Camaro 305 tbi with a 1228746 ecm. Yesterday I had a bunch of symptoms that pointed to a bad ecm. Cracked it open and found capacitor "C14" to be bad. It has continuity and does not increase resistance to infinity when tested with a multimeter (tested with one leg disconnected). If possible I'd like to just replace this capacitor but I can't find any information on it, the codes on it seem to be internal GM stuff or something. Can anyone tell me what the capacitance would be or point me in the right direction to search further? Thanks!
Old Today | 02:52 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: ECM capacitor identification pls 👉👈
Old Today | 02:55 PM
Engine: Lb9
Transmission: M20
Capacitance: The code "7152" typically indicates a capacitance value in picofarads (pF),
7.15nF
7.15nF
or
7100pF
7100pF
depending on the manufacturer's specific coding convention.
Old Today | 04:15 PM
Lost_Arts's Avatar
Thanks! I'll wait a bit to see if anyone else wants to add anything, if not I'll put an order in and see if that works
Old Today | 05:04 PM
Engine: Lb9
Transmission: M20
Murata DEHR33D152KA3B should probably work.Also, the capacitor in your photo looks thermally damaged, so inspect nearby parts—especially:
  • driver transistors
  • flyback diodes
  • ignition/injector drivers
Old Today | 05:47 PM
Buccaneer's Avatar
Car: 82 Corvette - CFI
Engine: 383 - Renegade, AFR 195, Bullet cam
Transmission: 700R4 - 3,200 Yank TC
Axle/Gears: 3.31
Interesting! My bet is on the injector driver circuit or devices near it OR because of the age, it just gave up the ghost. After 30+ years of absorbing inductive kickback from injector firing, it simply reached end of life. Does C12 look just like C14, minus the blown look? If so, you could find what the value is of C12, then you could then go to either Digikey or Mouser and purchase the part. Have you tried using AI yet? GL
Old Today | 06:14 PM
Lost_Arts's Avatar
Unfortunately C12 looks different, I don't see anything else that looks similar to C14. I just checked the RT1 thermistor and it does increase resistance when I hit it with the heat gun so I think that's good. Multimeter seems to be reading Q1and Q3 transistors normally too. I think those are the only components that would be at risk when the capacitor blew.
Old Today | 06:18 PM
Lost_Arts's Avatar
Hey Tuned, I noticed you mentioned it's likely a 7100pF capacitor in the first message but the part number you sent is one that's 1500pF. I was looking at one on digikey that's 7500pF part # C317C752F2G5TA
Old Today | 10:04 PM
Engine: Lb9
Transmission: M20
I tried to search the pn like you probably did as well. I tried a few cross references and came up with the second pn. So I’m honestly not sure the rating. Check enough to try the second pn/n and worse case get an ecm off Rockauto or eBay .
bucs_gators_fan
Jun 9, 2014 05:21 PM
bluechevy194
May 5, 2006 02:28 AM
92blue
Aug 9, 2005 03:19 PM
Drew
Jul 7, 2004 12:25 PM
