Door window tracks, paint before shaved door popper install
Old Apr 24, 2026 | 01:40 PM
dennisbernal91z's Avatar
Car: Building LS3, T56 Z28
Engine: LS3
Axle/Gears: Moser/ 4.11
I am shaving my door handles and finaly got everything primed, as I get ready to fit the window tracks back into the doors, I noticed the tracks have some slight surface rust.
What would you guys paint this stuff with?
I use Eastwood products. I have rust encapsulator, as well as 2k epoxy primer. Open to any suggestions.
Old Apr 24, 2026 | 02:56 PM
Bald_eagle_machine's Avatar
Car: 1988 Trans am GTA
Engine: L98 350 TPI
Axle/Gears: Factory 9 bolt w/disc brakes
Re: Door window tracks, paint before shaved door popper install
They all look like that. I've never seen one truly rust apart. They are some sort of galvanized metal. My 0.02 is to leave it alone. It won't rot out sitting in your door.
Old Apr 24, 2026 | 03:15 PM
Engine: LS3
Yeah. They are for sure galvanized, but it just seems like poor practice to toss this back in without doing anything.
But I also agree that tossing it back in would be totally fine.
Think I will just lightly scuff any discolored areas with 180 or something like that, and use a sponge and apply a coat of rust encapsulator and call it good.
Slowly cleaning each piece with carb cleaner to get the 35 year old grease out before replacing it with new stuff.
Old Apr 24, 2026 | 04:05 PM
soloc4's Avatar
Car: 84 Z28, 92 C4 suspension F&R, ABS
Engine: 408 LS2, CNC LS3 heads, Comp Cam
Transmission: Magnum F, RTX clutch, Tick shifter
Axle/Gears: DANA 44, Tru Trac, 3:73 gears
Crown Cold Galvanized primer
I’ve used this on a lot of things, even bare steel outside and it doesn’t need a top coat.
omnipotentgoku
Aug 31, 2016 10:38 AM
wgripp
Mar 10, 2013 11:50 AM
omnipotentgoku
Apr 13, 2009 12:16 AM
firebirdta84
Sep 25, 2007 07:57 AM
Camarogeddon
Feb 25, 2007 10:44 PM
