Skoons Subframe
Old Apr 24, 2026 | 08:43 PM
85Z28NOS's Avatar
Car: 85 Camaro
Engine: 454 RamJet
Transmission: LT1/T56
Axle/Gears: 8.8w/4.10
Skoons Subframe
I recently picked up a Skoons subframe designed to work with C5 suspension, 5thgen center section for our cars. This looks very well built and thought out to work with factory components
Old Apr 25, 2026 | 06:16 AM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Skoons Subframe
Thats interesting. Im having difficulties visualizing how that would fit
I found the site, I get it, lots of cutting and welding
Old Apr 25, 2026 | 08:04 AM
Airwolfe's Avatar
Car: 1992 Pontiac Firebird
Engine: 5.0L L03 TBI
Re: Skoons Subframe
Let me get this right.
It's $2,800.00 for the Skoons IRS subframe kit, you have to source and buy a used C5 Vette rear suspension setup and a 5th gen Camaro differential, then buy a $2,000.00 set of custom CV axels from The Drive Shaft Shop.
Then you have to do all the work needed to install this kit or pay a professional to do the work to install it or you can pay the guys that make this conversion kit $2,900.00 to do the installation.
Then you got to do something for a fuel tank it looks like and a custom exhaust system adding even more money to the total.
A guy wouldn't be to far away money wise to just buy a C5 Vette.
Old May 14, 2026 | 01:22 AM
Rich92 RS's Avatar
Car: 86 IROC-Z, 98 Z28
Engine: 370 LSx, LS1
Transmission: T56's
Axle/Gears: 3.73, 3.42
Re: Skoons Subframe
Can’t wait to hear your thoughts on the install and how it feels. Debating on going this route or the Quadralink from DSE.
Old May 14, 2026 | 05:54 PM
soloc4's Avatar
Car: 84 Z28, 92 C4 suspension F&R, ABS
Engine: 408 LS2, CNC LS3 heads, Comp Cam
Transmission: Magnum F, RTX clutch, Tick shifter
Axle/Gears: DANA 44 IRS, Tru Trac, 3:73 gears
Re: Skoons Subframe
Do you have any plans on upgrading the front suspension? Maybe a C5 front conversion to compliment the C5 rear? Something to think about.
Old Yesterday | 04:34 PM
85Z28NOS's Avatar
Car: 85 Camaro
Engine: 454 RamJet
Re: Skoons Subframe
the front is sporting a UMI front K-memeber, arms, and Hawks C7 front spindles and the C7 brakes
Old Yesterday | 04:41 PM
85Z28NOS's Avatar
Car: 85 Camaro
Engine: 454 RamJet
Re: Skoons Subframe
I will add this is alot of work to drill out all the spot welds and remove the factory plates that hold all the original suspension in. I also purchased a rear mini tub kit that was not required to do this install but i figured while i was in there try to clear the max wheel tire possible
72buickgs
Oct 13, 2021 06:52 PM
dixiebandit69
Mar 19, 2016 08:28 PM
Sinister Z
25
Jun 5, 2010 12:10 PM
z28z34man
Fabrication
25
Oct 18, 2006 12:16 AM
Spdfrk1990
May 30, 2003 07:42 AM
