The mystery bolt thread.
Old May 6, 2026 | 11:36 AM
goldandblue's Avatar
Car: 1988 GTA
So I pulled my intake and accessories off over a year ago with plans to do a quick cam install. In the middle of the process my son’s truck dropped a cylinder and all extra time and money went to that.
I now have the cam installed and have some mystery bolts that I’m hoping you guys can help me place as I am putting everything back together. Here are the first two. They go in or around the fuel rail. I appreciate any and all help.
thanks,
Joey.
Old May 6, 2026 | 12:11 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: The mystery bolt thread.
TPS
Old May 6, 2026 | 03:38 PM
Car: 1988 GTA
TPS
Awesome. Thank you. I'll have some knew bolts listed soon. These are torx head bolts but they are flat instead of kind of rounded. I have 4 of them I believe. I can send a picture when I get home.
Old May 6, 2026 | 09:26 PM
Car: 1988 GTA
I said I had 4 of these but I actually have 5. Any ideas?
Old May 6, 2026 | 09:30 PM
Engine: Lb9
Transmission: M20
I don’t recognize those, engine parts that use torx on tpi. Fuel rail, tps ,intake to head, plenum
and runners, front accessory brackets on 89-92 tpi
Old May 7, 2026 | 02:12 AM
LAFireboyd's Avatar
Axle/Gears: 9-bolt/3.45
I've looked all over my engine and engine bay, and I don't see any bolts like those. They look kind of hefty in your hand, not small like the fuel rail and TPS bolts. Are the seat belts installed in the car? They look like seat belt bolts that bolt into the floor.
Old May 7, 2026 | 03:51 PM
Car: 1988 GTA
maybe top bolts for the runners to plenum? Seatbelts are in car. The only things removed were front brackets, plenum, runners, fuel rail, intake, valve covers.
Old May 7, 2026 | 05:36 PM
LAFireboyd's Avatar
The runner/plenum bolts were originally black oxide button cap torx bolts, like the valve cover bolts, and there would be more than 5 of them. The head on those look like they might be the right size, and if you're not the original owner, then someone could've changed them in the past. Have you tried to screw them into the plenum to see if they fit?
Old May 7, 2026 | 08:56 PM
Airwolfe's Avatar
Car: 1992 Pontiac Firebird
Engine: 5.0L L03 TBI
What size Torx bit fits in the head?
Old May 9, 2026 | 06:01 PM
Mikos_89's Avatar
Car: '89 GTA, '15 Camaro LS 6sp.
Engine: L98, LFX.
Transmission: 4L60, AY6.
Axle/Gears: 3.27's.
From the size, they look like the runner to plenum bolts. However, like mentioned above, the original bolts were cap head torx, not square head. The previous owner changed them out for some reason. If they were a lot smaller, I’d say they are the TPS and TB top plate bolts. Unless, that is you have very very very small hands…lol!
Old May 9, 2026 | 11:04 PM
Car: 1988 GTA
They are bigger than the plenum/runner bolts. They are the same size as the intake and bracket bolts.
Old May 10, 2026 | 10:50 PM
Fred SS's Avatar
Car: 87 Monte Carlo SS
Engine: 89 350TPI Transplant
Transmission: 2004r
Could the bolts in question be for the intake manifold to cyl head? They look to be the right size. Of course, you need more than five.
Fred
Old May 11, 2026 | 10:58 AM
86blackiroc's Avatar
Car: basic third gens
Engine: that I like
Transmission: to restore
Axle/Gears: and enjoy
Metric or SAE thread?
Old May 14, 2026 | 08:02 PM
Car: 1988 GTA
Throttle cable bracket?
Old May 14, 2026 | 08:34 PM
Mikos_89's Avatar
Engine: L98, LFX.
Axle/Gears: 3.27's.
Yep, but you’re missing one bolt. Throttle cable bracket takes 3 bolts.
Old May 14, 2026 | 10:03 PM
Car: 1988 GTA
Found it. Thank you. I’m missing something here. lol.
Old May 14, 2026 | 10:07 PM
Engine: Lb9
Transmission: M20
Cold start injector timer switch, just plug with npt 3/8 plug iirc
Old May 14, 2026 | 10:12 PM
Car: 1988 GTA
any ideas on the two threaded holes above that?
Old May 14, 2026 | 10:14 PM
Engine: Lb9
Transmission: M20
For a corvette fuel rail
Old May 14, 2026 | 11:08 PM
LAFireboyd's Avatar
Cold Start Injector switch. If you'll be deleting the CSI with a custom tune, then just plug the hole. Another option for that hole if you're deleting the CSI switch could be to relocate the fan switch from the passenger side cylinder head, where it will always be easy to access in the future, being right in front.
Old May 15, 2026 | 08:36 AM
Engine: Lb9
Transmission: M20
It has a updated 89 based tune
Old May 15, 2026 | 07:25 PM
Vader's Avatar
...Just like my '86, but that it also still has the CSI installed and active. It always starts, and never floods. IIRC, I set the cold enrichment light but not to zero. It's semi- psuedo- nearly- almost original that way, a little.
Old May 20, 2026 | 08:38 AM
Car: 1988 GTA
Ok, This is probably a dumb question but where in the hell does the brake booster vacuum line connect to? 1988 Pontiac GTA LB9.
Old May 20, 2026 | 08:49 AM
Engine: Lb9
Transmission: M20
Drivers rear of plenum there is a nipple there.
Old May 20, 2026 | 06:23 PM
Car: 1988 GTA
Ok fellas I have no spark. Just changed the distributor any initial ideas. I did ensure the ignition module which came with the new distributor is plugged up.
Old May 20, 2026 | 06:29 PM
Engine: Lb9
Transmission: M20
Koeo power to the pink wire at icm from coil ?
Old May 20, 2026 | 06:45 PM
Car: 1988 GTA
what you mean that the other end of that doesn’t go to the air temp sensor in the plenum for the egr? I’m such a dumbass.
Old May 20, 2026 | 06:47 PM
Engine: Lb9
Transmission: M20
The plug in is the same for mat but that won’t power the icm
Old May 20, 2026 | 06:48 PM
Car: 1988 GTA
i need this **** color coded and like computer wires. They only fit where they are supposed to go. lol.
Old May 20, 2026 | 06:51 PM
Engine: Lb9
Transmission: M20
I’m think it is colored. Icm is pink and maybe white, mat is a pigtail tan and blk
Old May 20, 2026 | 06:54 PM
Car: 1988 GTA
This is the one that I had plugged into the icm. I’m assuming it plugs into the temp sensor.
Old May 20, 2026 | 06:56 PM
Engine: Lb9
Transmission: M20
Is it on a shorter pigtail, almost looks like yellow and blk for cts
Old May 20, 2026 | 07:00 PM
Car: 1988 GTA
This is what it runs to.
Old May 20, 2026 | 07:05 PM
Engine: Lb9
Transmission: M20
That’s mat under the plenum .
Old May 20, 2026 | 07:31 PM
Car: 1988 GTA
she started!!! Now what do I disconnect to set base timing?
Old May 20, 2026 | 07:52 PM
Engine: Lb9
Transmission: M20
The single wire tan blk next to the heater core
Old May 20, 2026 | 08:32 PM
Car: 1988 GTA
Got it timed to 6 deg before. What would keep my fans from running?
Old May 20, 2026 | 08:38 PM
Engine: Lb9
Transmission: M20
It’s been so long since I did a start tune it could be a fan switch tune setting , bad cts reading or bad ecm
or connection with prom. Does it go into diagnostic mode and blink a code 12 ?
Old May 20, 2026 | 08:39 PM
Engine: Lb9
Transmission: M20
Jumper the aldl a to b does the primary fan come on or are they running continuously?
Old May 20, 2026 | 09:16 PM
Car: 1988 GTA
Apparently I just didn’t let it get warm enough. They are working. Here are some data dumps. See anything crazy. This was with the car idling.
Old May 20, 2026 | 09:21 PM
Engine: Lb9
Transmission: M20
O2 not ready ? So I guess this isn’t cl, if you want to use tp rt in cl id be more than happy to view idle and driving.
Old May 20, 2026 | 09:24 PM
Car: 1988 GTA
This was from a snap-on modis edge scan tool.
what are cl and tp and all that?
by the way what’s your Venmo. You’ve been tons of help.
Old May 20, 2026 | 09:26 PM
Engine: Lb9
Transmission: M20
To tuner pro rt, cl closed loop like the o2 isn’t moving
Old May 20, 2026 | 09:28 PM
Car: 1988 GTA
I will get the data. Pm me your Venmo if you have one.
JimmyV14
Aug 18, 2019 05:16 PM
BahN
Jan 23, 2010 11:33 AM
breathment
May 30, 2003 08:01 PM
Mike89GTA
Dec 11, 2001 02:06 PM
rezinn
Jul 17, 2001 02:13 AM
