HELP!!!! I dropped a bolt into the intake
Old Dec 10, 2001 | 07:06 PM
Mike89GTA's Avatar
DAMN DAMN DAMN!!! I knew this would happen. I was working on my Super Ram and a bolt went down the runner. I didn't see it but I heard it, and there's a little bit of teflon from the bolt in the top of the runner. What should I do?? I have a magnet but it's not powerful at all (a refrigerator door magnet). I just hope it didn't go all the way to the head. I looked down there with a mirror and I might see something but it's hard to tell. What should I do? I really don't feel like taking apart my whole intake and possibly heads. btw, the engine is at #1 cylinder firing (was installing distributor) and the bolt went into #5 cylinder.
Thanks again guys
[This message has been edited by Mike89GTA (edited December 10, 2001).]
Old Dec 10, 2001 | 07:58 PM
Fbird88's Avatar
Car: 1988 Firebird
Engine: GM Performance Parts 350 HO
Axle/Gears: :(
You could try using one of those telescopic magnets from an auto parts store. That little thing has helped me out with problems like this countless times. Just be careful not to snap it in the runner.
[This message has been edited by Fbird88 (edited December 10, 2001).]
Old Dec 10, 2001 | 08:38 PM
jethro's Avatar
Another trick is to take the magnet off the holder they sell at the auto parts place, thread or clamp it in place onto a piece of flexible rubber hose, and snake it down the runner, it will follow its contours and u can pull it up... pls post a follow up, K?
I am sure this will work, but I want to hear how it goes, thanks.
Jethro
1987 IROC Z 13.92 and 1.92 60' street tires stock engine
Old Dec 10, 2001 | 09:21 PM
Mike89GTA's Avatar
DAMN, looks like my intake manifold bolts are made out of some wierd metal, because I tried one on my magnet and it doesn't stick at all. I took the runners off and the manifold is empty, which means the bolt went into the head ((( DAMN To make things worse, I looked at the #5 cylinder and the intake valve is open, so it could have gone into the cylinder. At least I have my parent's car to drive to work, so I can mess around with this..
-Black 89 GTA, t-tops, 5 speed
-355 cubic inches
-Edelbrock Performer Centerbolt heads with 10.4:1 compression (#6085)
-LT4 Hot Cam with 1.6 rr's
-SLP 1 3/4" Headers
-Accel Super Ram, stock throttle body
-dual cats with Flowmaster Y-pipe and single outlet Flowmaster cat-back
-Scat cast crank
-roller timing chain
-SLP CAI
-EST poly A-arm bushings, sway bar end links, transmission mount
-Alston sub frame connectors
https://www.thirdgen.org/newdesign/movies/index.shtml
Old Dec 11, 2001 | 12:27 AM
Fbird88's Avatar
Car: 1988 Firebird
Axle/Gears: :(
Could you maybe try to pull it out through the spark plug hole?
Old Dec 11, 2001 | 04:18 AM
ViciousZ's Avatar
Car: 91 camaro
Engine: 383
Ummm, intake bolts are pretty big. I seriously doubt it worked it's way around the valve into the cylinder. Guess you'll find out when you pull the intake.
91 Z28
Come see The Vicious...
Old Dec 11, 2001 | 09:08 AM
99Hawk120's Avatar
Car: 1999 Pontiac T/A Firehawk
Engine: ***'s Engine
It's probably sitting in the intake port of the head.
Old Dec 11, 2001 | 10:08 AM
Mike89GTA's Avatar
I took the intake manifold off and it was sitting right there. Whew.
Old Dec 11, 2001 | 02:06 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
<font face="Verdana, Arial" size="2">Originally posted by Mike89GTA:
DAMN, looks like my intake manifold bolts are made out of some wierd metal, because I tried one on my magnet and it doesn't stick at all.</font>
Commonly called "stainless" steel, more correctly corrosion resistant steel or CRES. Sometimes the threads will be magnetic if cold rolled, but typically not enough to actually lift the bolt with a magnet.
Not so weird, really...
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R4, 2300 stall TC. Ported World 305 heads, Crane PowerMax 2050 cam. ZZ3/4 intake, oil pump, pan & baffle. Accel HEI SuperCoil & module. Hooker 2055 headers, 3" Catco cat & 3" catback w/dual-opposite Flowmaster 80. 2.93 limited slip. Spohn SFCs waiting to be installed. AMSOIL syn lubes bumper-to-bumper. Daily year-round driver. Best ET, speed TBD...
57 Bel Air, my 1st car. '66 396, 9.7:1 forged TRWs, Weiand Action+, Holley 750VS w/4150 conversion, GK 270 cam, Magnum rockers, Jacobs Omnipack, 1-3/4" Hedders & 3" Warlocks, TH400 w/TCI Sat Night Special conv & Trans-Scat shift kit, MegaShifter, 3.08 8.2" 10-bolt w/Powertrax, AMSOIL syn lubes bumper-to-bumper. Idles smooth @ 700 RPM in D. Best 15.02/95.06 @ 5800' Bandimere (corrected 13.93/102.4 @ sea level).
Terrell351
Jun 13, 2021 01:13 PM
evilstuie
Jan 9, 2020 08:29 PM
LT1Formula
20
Nov 14, 2015 12:02 AM
Elliswon
Aug 10, 2015 12:33 PM
