Photoship Wheel Swap Tutorial
Car: 04 Chevy Silverado 1500
Engine: V6
Axle/Gears: Stock
Photoshop Wheel Swap Tutorial
Mods if you Like this Wheel Swap Tutorial, You may make it a Sticky.
A few Things before we start:
-Make sure that the picture of the car and the picture of the rims are at relatively the same angle, makes it much easier.
-Try and take rims that are on a car, that way you get the Disc brakes and natural lighting to give it a realistic look
First, find your two Cars of choice. one picture being of the rims you want and the other of which you will be putting the rims on.
Then, goto the picture that you will be taking the rims from, grab your Magnetic Lasso Tool:
Cut around the rim with the Magnetic Lasso tool, make sure to get it as close as you can!
Next, go Ctrl+C to copy the rim that you selected, then goto the picture which you will be putting the rims on and Ctrl+V (paste) the rim onto that picture. The rim should be on a layer of its own:
Now while having the Layer of the rim selected, go Edit->Transform-> Distort You should end having it looking like this:*edit* Same Image used as above.
Now drag you can click and hold inside the rim, and drag it to the spot where you want to put the rim on, then simply adjust all sides by grabbing and moving the 4 dots at each end, untill the rim is fitted similar to where the other one was. Then hit the Enter button on your keyboard. Something like this:
Now the next part that most people forget is to get the rims to comprimise with the lighting and shadows of the picture. So still having the Layer of the rim selected, you can go
-Shift+Ctrl+B
-Shift+Ctrl+L
-Alt+Shift+Ctrl+L
-then Adjustments-> Brightness/Contrast for final Touches.*Do what looks best to you*
Now do the same process all over again for the Back Rim:
-Polygon select it from the rim picture
-Ctrl+C the rim, then Ctrl+V the rim in the car picture
-Edit->Transform->Distort the rim
-fit the rim on
-finish off with your final touches.
And the final Product comes out like this!
Let Me know what you think!
Credit Goes to
http://www.mx6.com/forums/showthread.php?t=74904
It was Borrowed.
-Shift+Ctrl+B
-Shift+Ctrl+L
-Alt+Shift+Ctrl+L
-fit the rim on
Credit Goes to
It was Borrowed.
Car: 1985 Camaro/89 Merkur XR4Ti
Engine: 5.0 305 LG4/2.3 Turbo (180hp/205tq)
Transmission: TH700R4 with Shift Improver Kit/T-9
Axle/Gears: 3.42LT1 Rear/3.64
Im gonna bump this, I think this should be stickied.
ambainb
04-25-2016 09:21 PM
1992 Trans Am
08-08-2015 08:16 PM
