South Central Region Board for the states of Texas, Oklahoma, and Louisana.
SES light came on.
Old Jan 17, 2005 | 11:06 AM
Dr.NickRiviera's Avatar
Car: 1987 Trans Am
Engine: tree-fiddy
SES light came on.
Does anyone one know of an Autozone or any place that can pull codes? I got a SES light on my way to work. Turned the car off turned it back on and it went away.
It's to nut numbing cold to sit outside and jack with the car right now and I'm just hoping to find someone that can do it.
Car was running fine. before and after the SES.
Old Jan 17, 2005 | 12:28 PM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
You can pull the codes yourself, using the ALDL connector and a paper clip. Refer to your Chilton's or Haynes manual on computer diagnostics.
Even though the light is not on anymore, the code will be stored in the memory so you will pull it.
Lou
Old Jan 17, 2005 | 01:54 PM
Car: 1987 Trans Am
Engine: tree-fiddy
WEll i think i figured it out. I had reset the tming this weekend( disconnected the brown wire) so i might be getting the code from this. I'm gonna disconnect the battery when i go home and see if it clears it. If not I'll give the paper clip thing a try.
Old Jan 17, 2005 | 08:02 PM
raceb8's Avatar
Car: 89 rs
Engine: 355
Transmission: th350
Axle/Gears: 4.56 posi
if the light comes back on after re-setting the ecm, ican check it for you if you can get by lute riley honda in richardson.pm me or e-mail and i'll give you particulars.
Old Jan 17, 2005 | 08:30 PM
Car: 1987 Trans Am
Engine: tree-fiddy
Well on the way home from work it didn't come back on.
Lute Riley Honda is a few blocks from my house., but with my work schedule i'm not in this part of town most of the day. except on the weekends.
Old Jan 18, 2005 | 07:10 PM
raceb8's Avatar
Car: 89 rs
Engine: 355
Transmission: th350
well, i normally work 6 a.m. to 4 p.m. Mon.-Fri. i'm there every other sat. from 7a.m. to 5 p.m. if you have any more problems with it, give me a shout!
-matt
Old Jan 19, 2005 | 09:27 AM
Car: 1987 Trans Am
Engine: tree-fiddy
OK, well it came back on on my way to work.
raceb8, how about I bring it by tomorrow morning.
Old Jan 19, 2005 | 10:07 AM
vernw's Avatar
Car: 91 Formula WS6 (Black, T-Tops)
Engine: 383 MiniRam (529 HP, 519 TQ - DD2K)
Transmission: Built '97 T56, Pro 5.0, CF-DF
Axle/Gears: 4.11 posi Ford 9"
Or you could swing by my place later this evening if you prefer....
Old Jan 19, 2005 | 11:24 AM
Car: 1987 Trans Am
Engine: tree-fiddy
Whatever works. I'll email you.
Old Jan 19, 2005 | 07:56 PM
raceb8's Avatar
Car: 89 rs
Engine: 355
Transmission: th350
sure, i'll be there at 6 am on thursday. if you do want to bring it by, just come into service & ask for matt. i'm in the bottom shop on the right side, red mac toolbox with racing stickers all over it.(there,s also a black civic si on my lift).
Old Jan 19, 2005 | 09:44 PM
Car: 1987 Trans Am
Engine: tree-fiddy
Thanks matt, but got it figured out. Took itover to vernw's and found it to be a code 32/EGR problem. So i'll check the little hoses and stuff that a part of it. See if any of them came loose or what not, if that's not it i guess i'll be replacing the egr valve.
Old Jan 20, 2005 | 04:57 AM
raceb8's Avatar
Car: 89 rs
Engine: 355
Transmission: th350
you might also want to check the intake ports under the egr valve. they can carbon-up & cause egr problems. if they are, try running a coat hanger (or other suitable wire) through the ports, then follow with some carb cleaner. she'll smoke for a few after you start'er up, but this will usually get those ports clean.
Old Jan 21, 2005 | 01:54 AM
Rock90rs's Avatar
Car: 92 RS/90' vette
Engine: Heads/cam/miniram/blah blah blah..
Transmission: T5/700!
Axle/Gears: 3.08
I was going to say 32 before i even saw your post about it. If all else fails when you have things apart,.... pull the egr off the manifold and run some carb cleaner through it, (probably loaded with carbon) give the diaphram a little movement as well. This always fixed my egr woes. Just an FYI.
Old Jan 21, 2005 | 10:19 AM
Car: 1987 Trans Am
Engine: tree-fiddy
well i got it fixed. The hose that goes from the EGR solinoid to the TB had come off. Running liek a champ, well as good as it can now. lol
eightsixseven
Dec 16, 2024 01:50 PM
pigpete
Exterior Parts Wanted
Aug 15, 2015 07:56 AM
stalkier
Aug 13, 2015 12:59 PM
tnrednneck
Aug 13, 2015 08:57 AM
Omega
Aug 10, 2015 12:46 PM
