pinion angle anyone?
Car: Faster
Engine: Than
Transmission: You!
U need a small angle finder. Set it on top of the rear end's center chunk where the torque arm bolts to. Set it to - 2 degrees for best launching. All you need to know is how to turn a wrench to adjust the torque arm to achieve the negative 2 degrees.
However, I strongly recommend having an adjustable torque arm and a drive-on lift before you attempt this!
Car: 1989 IROC Z-28
Engine: L98 350--modified
Transmission: 700 R4--modified
Axle/Gears: 4:10 Posi
C
I've got the lift, sort of. don't have the adj. torque arm. thats why I don't think its off, but I want to check everything.
Car: 84Z28
Engine: 0.030 over 10.25:1 dart heads 350
Transmission: T 5 W.C. now
Axle/Gears: 3.73:1
Originally posted by Zap Racing
Would pinion angle cause a vibration?
Car: Faster
Engine: Than
Transmission: You!
Possibly due to the angle of the u-joints during rotation (but highly unlikely). You can "safely" according to random-tech go upto - 4* without problems.
You vibration is most likely a bad driveshaft and or u-joint.
The stock tq arm makes the pinion angle 0* (I think).
You wont notice any better sixty ft with an adjustable tq arm until you change pinion angle to -2* (where most aftermarket adj. tq arm mfg's recommend).
Hope that helps.
Hope that helps.
Car: 1986 Irocz- Houstons Fastest Street
Engine: 408 LS1 w/ 2 stage
Transmission: Turbo 350
Axle/Gears: 3:73,3850 lbs , best of 9.92 @ 138
Originally posted by TexasLT1
ok, so then will a -3* pinion angle cause a vibration?
didn't think it would. I think I traced it to a jounce bumper on the top of the T-56 that was smashed against the trans tunnel. haven't taken it out on the road yet to see.
Car: 91 Formula WS6 (Black, T-Tops)
Engine: 383 MiniRam (529 HP, 519 TQ - DD2K)
Transmission: Built '97 T56, Pro 5.0, CF-DF
Axle/Gears: 4.11 posi Ford 9"
Hope you don't mind my jumping in here with a question (if you do, just tell me to buzz off)....
I've tried adjusting my Ford 9" the following way: I put the angle finder on the tranny yoke to the driveshaft, recorded one angle, then moved to the diffy yoke and read the angle again. The I adjusted my BMR torque arm until it was pointing downward one to two degrees less reading than the tranny yoke did. That way the diff was pointing downward 1 to 2 degrees more than the tranny yoke.
If the way I explained it makes sense, does this sound like a legit way to set this -1 to -2 degree pinion angle?
Oooooooohhhh, I LIKE that idea!!!!!
THANKS!!!
THANKS!!!
dimented24x7
Sep 17, 2015 06:58 AM
