South Central Region Board for the states of Texas, Oklahoma, and Louisana.
Stuid question....
Old Aug 4, 2005 | 04:28 AM
SLP Addict's Avatar
Car: 85 Camaro
Transmission: 4l60
Stupid question....
Ok, anyone know how to open a hatch from the inside, like if theyres something you can pull, or anything to open the hatch, the hatch lock is mangled, and need to be able to open it to put a new lock in.
Old Aug 4, 2005 | 09:49 AM
SLP Addict's Avatar
Car: 85 Camaro
Transmission: 4l60
Ok, Thanks to 83Blackwidowz28, i was able to get it, He sent me a refrence picture. Well it wolnt let me upload the file, but pretty much, round section in back. Turn to the right and push up on your hatch.
Old Aug 4, 2005 | 09:56 AM
Wheel Spin's Avatar
Car: 89 Formula 350 (x 2)
Axle/Gears: BW 3.27
If the lock cylinder is mangled already, drill it out? About impossible to get to the mechanism from inside without cutting out an access in the plastic trim. My trim has two top screws that are covered up by the closed hatch. If you DO cut an access hole, you should be able to get to it ok, even though it is cramped back there. I doubt that trim piece is missing from many Pick-a-Part yards. Good Luck.
Well, I see I posted late. Glad you got it!
Old Aug 4, 2005 | 10:07 AM
SLP Addict's Avatar
Car: 85 Camaro
Transmission: 4l60
Heh, Luckily it was already taken out, and sitting in the back seat.
plstu
Sep 23, 2011 12:11 PM
surfertom
Brakes
May 7, 2006 05:51 PM
nblanchard
Aug 5, 2002 09:37 AM
richard_spiegel
May 8, 2001 12:51 AM
