sd or maf how do you tell.
Old May 7, 2001 | 10:39 PM
richard_spiegel's Avatar
How do you tell the diff and what is better. Sorry so stuid of ?
Old May 7, 2001 | 10:41 PM
irocz's Avatar
Car: '87 IROC-Z
Engine: 406 Superram/DFI
Transmission: Auto BTE 3000 conv
what year is your car? If you have a maf then you'll have a sensor mounted in front of your throttle body with a 5wire harness plugged into it. SD uses a map sensor attached to the side of the plenum w/ a vacuum hose running into it.
Old May 7, 2001 | 10:45 PM
black5.7GTA's Avatar
MAF-1985-89
SD-1990-92
Old May 7, 2001 | 10:46 PM
IROCZTWENTYGR8's Avatar
Administrator
Car: Red 87 IROC-Z28 T-Top
Engine: 5.7 Tuned Port Injection
Transmission: 700R4 Auto
Axle/Gears: BW 9-Bolt 3.27
MAF: 85-89
SD: 90-92
Old May 7, 2001 | 10:52 PM
Administrator
Didn't know I posted the same thing.
[This message has been edited by IROCZTWENTYGR8 (edited May 07, 2001).]
Old May 7, 2001 | 11:59 PM
92 305 tpi auto ttop
Old May 8, 2001 | 12:29 AM
RARE-ROC-Z's Avatar
you have SD. it started in 1990 just like the other guys said!
Jarrad
1990 IROC-Z L98 350 TPI
TH-700R4
G92- 9 Bolt Borg-Warner 3.27gears
Bright Red Hardtop/ Grey Custom Interior
mods: AFPR, B&M megashifter-HD4ft cable, Underdrive Pulleys, Ported plenum, K&N's, Magnaflow muffler, Aluminum Driveshaft, Gutted Air Boxes w/ Ram Air, and more!!
soon to have new PAINT, and suspension work
DAILY DRIVER: 1991 S10 2.5L/5SPD -
Old May 8, 2001 | 12:51 AM
Kevin Irving's Avatar
Car: 1985 Trans Am
The question as to which is better is debatable, God knows it has been beaten to death here. Both have thier advantages and disadvantages. I like MAF, some others like SD, especially the guys who burn their own PROMS. Make the most of what you have, you'll be happy with either setup.
Kevin Irving
85 Trans Am WS-6, 305 TPI, custom burned '86 PROM with '87 "165"ECM, Accel Supercoil & 8.8 Wires, Rapidfire #2 @ .055", MSD 6AL, 1.6:1 Roller tipped rockers, Homemade AFPR, K&N cone, no airbox, Aluminum Driveshaft, Wonderbar, TB Coolant Bypass, Ported Plenum, Descreened MAF, Syclone Fuel Pump, JET Airfoil, Mobil 1 synth in all but transmission.
15.556 @ 86.65mph, Nov 10, 2000.... I know it sucks.. but it will get better!
http://www.geocities.com/transam85tpi/
Member - The Tidewater Trans Am Club, Norfolk VA http://www.geocities.com/ttacva/
Mark_ZZ3
May 24, 2018 01:02 PM
BumpaD82
Feb 26, 2016 02:57 PM
racereese
Oct 3, 2015 03:46 PM
Ikes 91Z
LSX and LTX Parts
Sep 13, 2015 09:03 AM
