Alternative Aftermarket Thirdgen A/C system???
Car: 1989 IROC Z-28
Engine: L98 350--modified
Transmission: 700 R4--modified
Axle/Gears: 4:10 Posi
Alternative Thirdgen A/C system???
I know for a fact that a lot of U don't have working A/C in your thirdgen for one reason or another. Some just they plain don't work and for whatever reason U have not had them fixed-- and some don't want to give up the extra H.P. they rob even if they are turned off.
I ran across an alternative A/C system here.....even though it's not a thirdgen in the picture, I also know how resourceful thirdgenners are and figure U can certainly adapt this to your thirdgen!
Car: 83 POS monte carlo 2015 chevy P/U
Engine: 92 5.7 tpi 5.3
Transmission: 700r4 6L60E
Axle/Gears: 2.42 too high
thats a good one,.. the best part is the generator,.. actually mounted to the trunk lid,... hahaha
i with the window unit blocking that mirror,.. i guess we know where the quarter panel damage came from.
thats a nicely modded tail light too
Car: 1987 GTA
Transmission: 4L60e
I can see the thought process now - get the AC fixed at the shop the right way for give or take $1000 if everything needs replacing or....buy $200 generator, and a $200 new AC (cheaper if they're used) and install it yourself. This may actually be something we see a thirdgener do seeing as how it's SO MUCH CHEAPER than doing it the right way.
Car: '86 T/A
Engine: 350/LT1 Intake
Transmission: 700R4 - Built
Axle/Gears: 4th gen 3.42
yeah, but I bet that window ac unit blows a HELL of alot colder than the normal stock AC which barely works even on a good day.
Car: 1989 IROC Z-28
BikeFarm
Aug 11, 2015 11:35 PM
db057
Aug 11, 2015 10:11 PM
that is classic...!!!!
