South Central Region Board for the states of Texas, Oklahoma, and Louisana.
Nice increase in gas mileage!!!
Old Jan 18, 2008 | 12:20 AM
1bad91Z's Avatar
Car: Faster
Engine: Than
Transmission: You!
Over the last few months, I've been averaging close to 19 MPG in the city with the red Z. I just finished the first full tank of gas after installing a MSD Blaster GM coil and a set of March performance billet underdrive pullies (crank and alternator). I just averaged 20.73 MPG in the city and that was even stepping on the gas (having fun) half of the time!! I might be able to squeeze a little more if I baby the car for the duration of the whole tank! Oh, and the adder power was a noticable difference too!
Just thought I'd share.....
Old Jan 18, 2008 | 03:26 AM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Transmission: 4L80 4000, T56
Axle/Gears: 4.30 M12, 23.42 10 bolt
Re: Nice increase in gas mileage!!!
LOL, i have noticed mine is better....when i keep my foot out of it!!!!!
Old Jan 18, 2008 | 08:49 PM
DENN_SHAH's Avatar
Car: 83 POS monte carlo 2015 chevy P/U
Engine: 92 5.7 tpi 5.3
Transmission: 700r4 6L60E
Axle/Gears: 2.42 too high
thats pretty good Mike. on my Monte i got 17.7 MPG out of my last tank.
are you playing with hiway mode on it?
Old Jan 18, 2008 | 09:06 PM
yevgenievich's Avatar
Car: numerous
Engine: ls1, others
Transmission: t56, others
Axle/Gears: 3.23 7.6"
That's better than what my stealth is getting. I need to get into chip burning on my bird. I started on making a cable to start data logging.
Old Jan 19, 2008 | 10:39 PM
1bad91Z's Avatar
Car: Faster
Engine: Than
Transmission: You!
I left highway mode alone and just tweaked the hell out of VE until I had 128's across the board at all RPM's below 3,500 rpms, then tweaked PE for WOT.
Old Jan 20, 2008 | 04:38 PM
DENN_SHAH's Avatar
there may be another mile or 2 in yours' with hiway mode, it helped me some. i never got to 128 across the board, i hit 126 ~131 & stopped tuning. i need injectors so i figured that was good enough.
right now my wideband reads good at idle in open loop, but when it goes into closed loop it goes rich.
if i ever get off my butt & have my AutoProm fixed i want to try open loop idle in AUJP V4.
Old Jan 20, 2008 | 06:57 PM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
well i don't do alot of city driving . i have the same coil , M.S.D. 8.5 wires , AC stock plugs , M.S.D. cap & rotor , 1.52 roller tip rockers , flowtech headers , 3'' flowmaster exhaust , hybrid T.P.I./T.B.I. inlet system with K&N inside and lid . on the road from s.miss. to san antonio and to tampa i have got as high as 29+ M.P.G. . by the way syn. lube all the way , trans. T.5 , rear 3.08 , use cruise when possible . found it hard to believe the first time or two . after 3rd. trip , love it . P.S. no E.C.M. or chips MODS .
Old Jan 21, 2008 | 12:42 AM
1bad91Z's Avatar
Car: Faster
Engine: Than
Transmission: You!
That's pretty good for a 305 TBI, but the motor in the red Z makes atleast 360 HP at the flywheel! It takes more fuel to run the motor in it.
The last time I hooked up a LM-1 to the black car, I found that when the car was in highway mode, it was WAY too lean ( 16-17:1), even after tweaking it a bit. I usually just disable that stuff, including all the add-a-timing tables and just fine tune VE and the main spark advance tables (beefed up of course), then tune PE last. It made the wide-band happier doing it that way. I didn't want to lean the crap out of it too much and burn a piston....
Old Jan 21, 2008 | 02:42 PM
Sonar_un's Avatar
Car: '86 T/A
Engine: 350/LT1 Intake
Transmission: 700R4 - Built
Axle/Gears: 4th gen 3.42
I manage to get 17 or so MPG out of my car (highway) and it is tuned to a perfect 128blm across the board.
The car enters highway mode and everything, no idea why mileage is so crappy. I really need to hook it up to a wideband and tune for a higher FR.
Old Jan 21, 2008 | 09:55 PM
DENN_SHAH's Avatar
Mike, i understand about not wanting to burn a piston. at the level of power your at it would be too easy to cook the motor.
with mine dead stock its not too much of a worry for me, as long as im not getting into lean misfire im ok.
that kind of power makes your 20.7 MPG city even more impressive, very nice
Sonar, something has to be off, you should be getting way better than 17 hiway.
if i remember right, you just have bolt on mods, right?
my best hiway so far was 29.7. my last road trip i was down some, i only got about 26.5. but i did drive a little faster most of the way, around 80. and i did spend about 20 minutes up around 100~110.
Old Jan 22, 2008 | 12:21 AM
aldixie's Avatar
Car: 1991 RS Camaro Convertible
I'm averaging around 20MPG in my vert, 22 on a good day. Have a new Chevron station opened up on spencer selling gas at $2.63 a gallon so filled up and had some fun yesterday.
Alex
Old Jan 22, 2008 | 07:22 AM
Sonar_un's Avatar
Car: '86 T/A
I am envious of you people and your high mileage. I am not exactly sure why I don't get good mileage. I wish I could say more, but I have picked through this car with a fine tooth comb. It has always just had very bad mileage. The car doesn't even get close to passing emissions testing due to it being incredibly rich. Though, like I said, 128blm across the board.
Old Jan 22, 2008 | 08:03 AM
Car: numerous
Engine: ls1, others
i thought i was getting bad millage. I get about 16 in the city and 23 on the highway. I really need a tune up, because if i can ~30 on highway on my firebird, there is no point on taking stealth to the road trips.
customblackbird
Aug 15, 2021 10:16 PM
Vintageracer
Jan 10, 2020 05:33 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
FreeSpirit
Aug 29, 2015 05:47 PM
InfinityShade
Aug 22, 2015 08:00 PM
