South Central Region Board for the states of Texas, Oklahoma, and Louisana.
Looking for a TPI setup
Old May 7, 2008 | 09:55 PM
Texas92's Avatar
I'm looking for a TPI setup to change out my 92 RS it has a 305 TBI how hard is it to change out can you guys help
Old May 8, 2008 | 07:59 AM
esc's Avatar
esc
Car: '82 Camaro 11.7@121
Engine: 377
Transmission: 400
Axle/Gears: Dana 44 / 3.31:1
Re: Looking for a TPI setup
AlDixie did that swap recently.
If I remember correctly he repinned the origional wiring harness to work with a TPI computer. But he could tell you a lot more than I can.
Do you have any of the parts yet?
Old May 8, 2008 | 08:14 AM
91 camaro racer's Avatar
Car: 91camaro rs,2014 silverado 5.3L
Engine: 5.7Lcarb,5.3L
Transmission: 700-r4, 6L80
Axle/Gears: strange 3.73's
i don't have a complete set-up but i have some parts. what all do you still need?
Old May 8, 2008 | 08:18 AM
aldixie's Avatar
Car: 1991 RS Camaro Convertible
Yes I repinned my TBI Harness to work with the TPI speed density setup. Its fairly easy to do. I still have all of the information. Requires you to lengthen a couple of the sensor wires and of course add the extra injector connectors.
Quite happy to pass the information on.
Alex
Old May 8, 2008 | 08:27 AM
soultron's Avatar
Car: 87 trans am
Axle/Gears: 3.42 SLP rear
I'd like that info too, if possible.
Old May 8, 2008 | 06:39 PM
Texas92's Avatar
Yes please can you send me the info at talsma2007@yahoo.com also does it matter what year i get the tpi off of and will it end up being speed densty or maf. thanks justin
Old May 8, 2008 | 07:19 PM
aldixie's Avatar
Late 90 thru 92 is speed density, easy to tell just look for the 9th cold start injector on the drivers side of the manifold. If it has it then its MAF, the MAF is more forgiving is your using a bigger cam. I used a speed density setup, there are a couple of guy's on here who can do you custom proms if you use the speed density and want a more radical cam. The only other change to do on the TBI engine is you need to change the knock sensor as its different between the TBI and TPI. Also to get the electronic speedo working you have to put a jumper wire from the VSS (speed sensor)I'll gather all my info and email to it to you.
It also helps if you have the factory manual, I should be able to scan in the required pages this weekend.
Alex
Old May 8, 2008 | 07:24 PM
Texas92's Avatar
91 racer what tpi parts do you have
Old May 8, 2008 | 07:51 PM
aldixie's Avatar
PM me an email address and I'll send it to you. Its all in a word document.
Alex
stalkier
Dec 6, 2015 11:25 PM
gta90
Sep 15, 2015 04:00 PM
masonta
Aug 31, 2015 10:14 PM
Sanjay
Aug 12, 2015 03:41 PM
squiggy2
Aug 9, 2015 09:30 PM
