South Central Region Board for the states of Texas, Oklahoma, and Louisana.
Texans!!!!!
Old Aug 26, 2009 | 08:34 PM
OceanBlue85's Avatar
Car: 1985 Camaro Sport Coupe
Engine: V8, 5.0L, 305, 4BL Carb
Transmission: Original
Axle/Gears: Original
Texans!!!!!
Lets meet Sep 13 at a BWW to watch the Texans play their first Season game!
Old Aug 26, 2009 | 10:52 PM
esc's Avatar
esc
Car: '82 Camaro 11.7@121
Engine: 377
Transmission: 400
Axle/Gears: Dana 44 / 3.31:1
Re: Texans!!!!!
Last time I checked,there were a bunch of BWW's. Which one do you have in mind?
Old Aug 27, 2009 | 07:53 AM
irocdee's Avatar
Car: 1986 Iroc-z camero
Engine: modified 305
Transmission: manuel T5
Axle/Gears: stock
Re: Texans!!!!!
ILL BE THERE JUST SEND ME THE ADDRESS
Old Aug 27, 2009 | 08:25 AM
Re: Texans!!!!!
Well, I didnt want to put a specific BWW, because I wanted to get us to agree on one, to be fair , not just closest to me.
Old Aug 27, 2009 | 08:37 AM
irocdee's Avatar
Axle/Gears: stock
Re: Texans!!!!!
Y DONT WE MEET UP AT ONE CLOSE TO THE STADIUM.
Old Aug 27, 2009 | 08:42 AM
esc's Avatar
esc
Engine: 377
Transmission: 400
Re: Texans!!!!!
Fair Enough.
This one is pretty centrally located..even if parking isn't great:
Phone: 713-521-1100
2525 Rice Boulevard
Houston, TX 77005-3220
That is where Houston-f-body used to meet every Thursday (for $0.25 wings) back in the day. But I suppose "Central" depends on who is going.
Old Aug 27, 2009 | 02:11 PM
Re: Texans!!!!!
If that is where F-Body use to meet then we should stick to it, I could be there early to see about parking, where we can try to park together, and reserve some seats. If we can get a good response to this meet, then I could call asap and reserve some spots and probably parking.
Old Aug 27, 2009 | 04:28 PM
DrewsCam's Avatar
Car: 1991 Z28
Engine: 355 TPI
Axle/Gears: 9 bolt disc / 3:27
Re: Texans!!!!!
still down for about another 3 wks or so... sorry boys..
Old Aug 27, 2009 | 04:56 PM
esc's Avatar
esc
Engine: 377
Transmission: 400
Re: Texans!!!!!
I just checked my calendar and 9-13 is out for me also.
Sorry about that.
Old Aug 28, 2009 | 04:04 PM
irocdee's Avatar
Axle/Gears: stock
Re: Texans!!!!!
well i should b there.
Old Aug 29, 2009 | 09:01 AM
Re: Texans!!!!!
Cool I will be there as well.
Old Aug 30, 2009 | 01:43 AM
DrewsCam's Avatar
Car: 1991 Z28
Engine: 355 TPI
Re: Texans!!!!!
man found out yesterday that my motor is NEW... bout crapped my pants... got some pictures of the motor being built by the guy I bought it from and the block was brand spanking new... old block was bad or something to that effect... I gotta get this car up and running to make it to some events... oh and it would be nice to actually drive it lol
Old Aug 30, 2009 | 10:41 AM
Re: Texans!!!!!
That is crazy, well just give me a heads up when you want some help.
Old Sep 1, 2009 | 08:48 PM
DrewsCam's Avatar
Car: 1991 Z28
Engine: 355 TPI
Re: Texans!!!!!
Hey Blue what are you up to this coming Sat... I'm tired of my car sitting on jack stands... You ever change out valve springs without pulling the heads??? This is the list I have left
1- valve springs
2- valve covers
3- repair electrical
4- replace tranny pan gasket
5- new tranny pan bolts and adjust cable
6- install y pipe
7- install smog and hoses
I think thats it to get her running again. I'm going to pull the intake port and polish it and strip the wheels... I also have some rust that I have to cut out and replace..
Old Sep 1, 2009 | 09:43 PM
one92rs's Avatar
Car: SOLD!!!!!
Re: Texans!!!!!
do you own an air compressor? and do you own a compression gauge? if not it will be hard to change springs. if you do it will be easy.
Old Sep 1, 2009 | 10:03 PM
DrewsCam's Avatar
Car: 1991 Z28
Engine: 355 TPI
Re: Texans!!!!!
I have both yet never changed out valve spring before... I'll be the first to say.. I'm not too sure about doing it but I have to try inorder to save 480 bucks the hot rod shop wanted to charge me.. I'm going to buy the valve spring compressor this week... y you wanna help lance?
Old Sep 2, 2009 | 08:18 PM
esc's Avatar
esc
Engine: 377
Transmission: 400
Re: Texans!!!!!
With the right valve spring compressor tool, it is a piece of cake.
With a cheesy tool it will be a PITA.
SofaKingdon turned me on to the "right" tool.
http://www.summitracing.com/parts/SUM-906784/
I didn't use a compressor or compression gauge either. I put each cylinder at TDC when I was working on it.
Old Sep 2, 2009 | 08:53 PM
DrewsCam's Avatar
Car: 1991 Z28
Engine: 355 TPI
Re: Texans!!!!!
how do you prevent the valves from dropping into the cyclinder if you don't use an air compressor? do you just turn the motor til both the valves are closed and then change the springs?
Old Sep 2, 2009 | 10:33 PM
esc's Avatar
esc
Engine: 377
Transmission: 400
Re: Texans!!!!!
Exactly. At TDC there is nowhere for the valve to go.
That tool not only lets you push the lever from any direction (360*), but it also locks in place. Like most things, with the right tool, it is easy. That IS the right tool.
Old Sep 5, 2009 | 11:57 PM
DrewsCam's Avatar
Car: 1991 Z28
Engine: 355 TPI
Re: Texans!!!!!
nice I'm going to start them next weekend hopefully it will go smoothly... Could use some help because I've never done them before but not saying I'm not willing to give it the old whole hearted try... Oh I'm posting some parts off my current car i'm not going to use if anyone wants them.. should be a tach and black out tail light covers
ligerzero5621
Aug 17, 2012 10:50 PM
Chuck
Apr 2, 2012 04:26 PM
cerberus
Dec 14, 2011 01:32 PM
Reid Fleming
25
Nov 16, 2008 09:14 PM
Texan25
Nov 15, 2007 09:55 PM
