South Central Region Board for the states of Texas, Oklahoma, and Louisana.
STARTER MESSED UP
Old Oct 24, 2009 | 06:19 PM
92_T-5's Avatar
Car: 92 Camaro T-5
Engine: tbi 305
Transmission: t-5
Axle/Gears: ?
STARTER MESSED UP
does anyone kno why my starter from mah 92 tbi t5 camaro is much smaller than the one in mah brothers iroc an mah brother rs?? does it have to do wit mine being standard transmission?? or no ??? need help ..miss drivin mah camaro =( . but try to replace it wit one from an irocz an ah rs camaro .
Old Oct 24, 2009 | 06:35 PM
antsZRS's Avatar
Car: 1990 Camaro ZRS
Engine: 350 SBC
Re: STARTER MESSED UP
the iroc has a bigger motor. needs more torque to start it. thas why its bigger. it should work but than again dont know if it will fit.
Old Oct 24, 2009 | 07:05 PM
92_T-5's Avatar
Car: 92 Camaro T-5
Engine: tbi 305
Transmission: t-5
Axle/Gears: ?
idk cuz i out in a rs one but still didnt bro
Old Oct 24, 2009 | 07:08 PM
antsZRS's Avatar
Engine: 350 SBC
than i would think it might be a different starter with different number of teeth. try to look up how many teeth your has compared to the others ones by the year. are you sure its the starter.
Old Oct 24, 2009 | 07:10 PM
92_T-5's Avatar
Car: 92 Camaro T-5
Engine: tbi 305
Transmission: t-5
Axle/Gears: ?
yup ... check battery an alternator .. no dim lights, windows go up quick . when i turn it on ... i cant turn it off or wont turn back on until two days .... so yea .
Old Oct 24, 2009 | 11:31 PM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Transmission: 4L80 4000, T56
Axle/Gears: 4.30 M12, 23.42 10 bolt
Talked to 92_T5 tanight, told him what is up.
For those that want to know, the T5 starter is smaller than the automatic starter. Now the T5 starter will work with the 700R4 or ANY other automatic, the automatic 700R starter is to big to fit in the bellhousing of the T5.
BUT, alas no worries, a T56 LT1 93-97 starter will work also. Which might even be cheaper.
Old Oct 25, 2009 | 06:30 PM
antsZRS's Avatar
Engine: 350 SBC
thanx zone for the info. really appreciate it.
Old Oct 25, 2009 | 07:14 PM
DrewsCam's Avatar
Car: 1991 Z28
Engine: 355 TPI
Axle/Gears: 9 bolt disc / 3:27
i'd change it out for a high torque mini starter.. they run about 75 bucks but are so much easier to install and require less amps to start the car which saves you money because your bat will last longer... thats all i put on mine... not to mention they weigh less and can clear the y pipe without having to drop it for installation.
Old Oct 25, 2009 | 07:21 PM
t-top havoc's Avatar
Car: '87 Camaro
Engine: '92 Carb'd 350
Axle/Gears: factory stock
Thanks for posting the info--good for ppl like me who are learning as we go! THANKS!
Old Oct 26, 2009 | 12:09 AM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Have you seen the LT1 starter? It is basically a ministarter.
Old Oct 26, 2009 | 12:29 AM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
http://cgi.ebay.com/ebaymotors/100-N...Q5fAccessories
Old Oct 27, 2009 | 11:43 PM
92_T-5's Avatar
Car: 92 Camaro T-5
Engine: tbi 305
Transmission: t-5
Axle/Gears: ?
thanks everyone ah got mahcar runnin today =) an gonna wash em tomorrow , clean inside, an run em . zones thanks for the help ! ah ended up takin mah starter to sum guy that rebuilt mah starter so far its runnin good !!
Old Oct 28, 2009 | 03:42 AM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Great man! Good to see it is not biggie to get it running again!
F-body-fan
Jan 12, 2023 01:49 PM
3rd gen money
Oct 11, 2019 09:57 PM
Ed1LE
Sep 30, 2018 09:14 AM
Bubbajones_ya
Oct 25, 2015 08:01 PM
SS-EXPRESS
Sep 28, 2015 09:14 AM
