Local Houston TX, if you going to swap
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Transmission: 4L80 4000, T56
Axle/Gears: 4.30 M12, 23.42 10 bolt
a LS1/2/anything into your cars, we have a solution to making things WAY easier!
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Re: Local Houston TX, if you going to swap
BTW, these are prototype pieces that will be soon available like mine or with power steering, using the OE alternator and PS pump makes life allot easier. Not to mention using the WAY easier to find truck water pump and lower pulley.
Car: 1989 Formula 350 LSX
Engine: 5.3, 234/228 cam
Transmission: Stage II 4L60e, Vigilante 3200
Will there be one for the stock AC compressor too!?
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
If you use the truck AC compressor that is actually smaller than the car compressor, yes, as long as there is room for it by the K member. This whole kit is oriented around the truck accessories that are WAY easier to find. Instead of finding a LS1, you can now get a 4.8/5.3/6.o from a truck and not have to worry about finding the F body accessories, and you can re use the stock alternator and power steering pump.
Nice! I didn't know the truck compressor would fit with the stock K member in the car, I was under the impression it was either 300 dollars for a billet braket to retain the stock one, or 400+ for a k-member to use the 4th gen stuff.
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
No, there is a kit that you use to cut out the spot where it hits and weld it in on the stock K member, think someone said it might fit with the Spohn motor mounts too.
Car: 02 SS
Engine: 408 TT (1108rw-93/m1)6700rpm
Transmission: TH400(slipping)
Axle/Gears: 12bolt/3.42(whines😠)
designed to work with truck ac compressor if ur kmember area will allow. uses stock truck bracket, tensioner and belt. fittings and lines are mostly gonna have to be custom. but the actual compressor and bracket are gm parts.
Car: 02 SS
also have in the works a budget oriented turbo system. designed to work with my swap parts. stainless or mild steel construction.
will fit under stock hood with efi ls manifold.
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
HEre is the PS setup we mocked last sunday:
Car: 1990 Camaro ZRS
Engine: 350 SBC
hey zone. how its going. you car look pretty sweet with the motor in it!!! i like how you put the msd on the intake. what intake it that.
on the other note. my car is done!! we finished the hood last night. just need some more tuning on the carb that well do this week. and i also gotta get the tags and insurnace! so hopefully next weekend i will be cruising!!!
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Great news man! Intake is a LS1 victor Jr from Edelbrock for the carb conversion on the GEN III motors.
Car: 02 SS
also working on procharger setup for ls 3rd gens and maybe turbo hotparts. pics coming
Car: 02 SS
this is a high mount t4 ive put together. still need refining. but allows up to 4in dp if remove ac box. but even with ac box can use 3.25 dp and t76 type turbos.
Car: 02 SS
few mo pix. sorry bout the small thumbs. gonna try to resize em. but u get the idea.
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Yea, i am trying to figure out how i will install my manifolds, which ones did you say to use for the turbo setup? Was it a truck and a car manifold?
Car: 02 SS
the manifold i got pictured is made from stainless. and use 98-02 stock manifold on driver side with 2.5 xover to the turbo manifold
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
There isnt anything? Vette, caddie, GTO ect manifold that would work?
Car: 02 SS
also i get around .5 between kmemebr and fbody pan. and almost .75 with truck pan. im gonna use the truck pan. for now. with those mounts and stock rubber inserts.
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Well, i was going to use the stock flange on the manifold and weld to that(where the stock exhaust pipe is). Actually use the pipe that comes on the manifold.
xbmx89
South Central Region
Oct 31, 2015 10:59 AM
AkDrifted
Aug 17, 2015 07:45 PM
