Guess what guys.. the Dyno Of My Car wrong.. Also now i have ABS light on
To all of you who saw the dyno chart on my 2001 T/A, remember how crazy it was? Not smooth or flat? I was concerned that there was something wrong with the car or maybe it wasn't broken in yet, but after looking more closely i'm sure it's the Dyno...
MY HP and TORQUE cross at like 4300RPMS... I bet if everyone else looks at there is will cross around 5250.. It is impossible for HP NOT to equal torque at 5250...
ALso, remember how the second run my car dynoed at 700HP? I think they were just having some problems..
Final thing.. Every since i left the dyno my ABS INOP light has been on.. wonder if they shorted something or accidentally disconnected something... i've never had that light before..
damn the luck
Shane
p.s.
nice meeting all you guys
Shane Buss 92 Firebird 355, Holley 800 Double Pumper Carb, Vortec 1.94/1.50 Heads (Ported,Polished,Milled .025), 10:1 Comp Ratio, Cam Specs 224/234 498/520, 1.6 Roller Rockers, Hooker Headers, Flowmaster, !Cat, 3.73 Posi, Msd 6A Ignition Cyb. Speedo box, Single Plane Intake
http://users.ev1.net/~sdbuss/index.html
Note all girls on web page are x's, and will be removed when i get more time
WEIAND SUPERCHARGER REMOVED
2001 LS1 Trans AM A4. Bone Stock. 3.23 Rear End
damn the luck
Shane
p.s.
http://208.238.17.66/ls1forum/Forum1/HTML/008192.html
they said abs inop is normal because of rear tires spinning and front not.. said it will clear up.. i've driven 300 miles since then and it is stll on.. maybe a pcm reset is necessary
<font face="Verdana, Arial" size="2">Originally posted by ShaneBuss:
how weird.. dude i'm pissed about it.. yesterday it rained a little and my tires LOCKED UP when i had to stop really quick.. nearly caused me to wreck..</font>
they said abs inop is normal because of rear tires spinning and front not.. said it will clear up.. i've driven 300 miles since then and it is stll on.. maybe a pcm reset is necessary</font>
Car: 1987 Trans Am
Axle/Gears: 10 Bolt SLP Torsen, 3.73 ratio
About that dyno, my hp/torque crosses at about 3250. Not sure if someting was up, but I honestly don't believe that my car even if 305 TPI is running 150 HP and 235 FT-LB torque. Hell, the first of the second 2 runs the ID10T running the dyno, somehow found I had 79.6 HP and 155.0 Ft-LBS torque WTF?! I already am planning on looking for a "second opionion"....another dyno elsewhere. If I beat ya too it, I'll let ya know, otherwise if you go elsewhere and dyno, let me know what you find!
Personally I think they broke it w/ that twin turbo Camaro!!! They probably just tried to compensate for it, and guess adjusted it. Hell nitrous only adding 15 HP to a car?! Something was wrong!
Corry
Corry Lazarowitz
clazarow@voicenet.com
clazarowitz@hotmail.com
1987 Pontiac Trans AM (GTA?) 350 TPI
SLP 1 3/4" headers, 3" cat back (stock cat
MSD ignition.
MSD Blaster SS coil.
3.73 Rear end gears
Accell 8.8 Wires
Bosh +4 Spark Plugs (Don't know if they really help but hell!)
Holley AFPR
Race Built Automatic trans ('vette servo, shift kit, tightly packed clutches)--just needs titanium gears now!
Newly gutted cat (the car gutted it's own cat!)
Hypertech Chip (Just found out I had it! :eek
More soon when funds are avail...
[This message has been edited by Corry (edited April 22, 2001).]
Corry
Corry Lazarowitz
MSD ignition.
3.73 Rear end gears
Accell 8.8 Wires
Holley AFPR
Car: 92 Camaro RS
I don't know guys. My numbers were right on. They showed a 10hp increase from the last time I dynoed and the runs were consistent. Now for Corry's car, that thing is having some serious issues, and it wouldn't suprise me if it actually was running bad enough to get that low of figures. Now the thing about the nitrous only adding 15hp to jake's car was because not the same guy was spraying it into the throttle body and it's not like bolting an actual kit on the car. Plus, the bottle was empty the second time he tried to spray on jake's car, so it probably just didn't put much into the motor and that's why it only got 15.
Well here's the thing.. it is IMPOSSIBLE for HP and TORQUE not to cross at 5250.. bottom line...
I have never seen a dyno where they didn't...
Even the dyno sheet they gave me of the heads/cam ls1 was smooth and crossed at 5250.. I honestly think they had something mis calibrated... Some guys on Ls1.com dynoed the same day (about 3:30) and were complaining about the lines crossing at like 3500... Horsepower=(Torque * RPM)/5250.. if 5250 is RPM then HP MUST EQUAL TORQUE.
Hey guys i'm an idiot.. got to looking at my dyno chart again... the lines do not intersect at 5250 because the SCALES are different.. HP scale is from 100 to 300 and torque is from 210 to 320... if you look at the actual values, they are = at 5250.. duh
I was somewhat happy with my results. Eventhough my car hit the speed limiter at 4500rpms, it still got 251rwhp/296rwtq. Not too bad for a stock A4 car.
89' Iroc-Z
ZZ3 short block-355 TPI ZZ9 cam
NOS 150 shot.
blah...blah...blah..
95' T-56, 6-speed
99' Z' rearend w/ 4.10's
1997 black Trans AM
LT1, A4, basically stock.
13.87 on the G-tech
89' Iroc-Z
NOS 150 shot.
95' T-56, 6-speed
1997 black Trans AM
13.87 on the G-tech
On the nitrous my car put out an extra 50rwhp so I dont think it was that messed up seeing that Jake's car is speed density and it doesn't pick up the nitrous as well as MAF.
87' TPI 305 5-speed Z28, Bolt ons, weld wheels, front runners, complete audio system, cowl hood, custom paint with phantom racing stripes
http://www.blazeracing.com
colton_carlson
Mar 8, 2019 12:21 PM
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
