South Central Classifieds for the South Central Region
F/S 2000 LS1 engine and manual trans w/wiring harness
Old Nov 10, 2008 | 08:22 PM
HuggerI-ROC's Avatar
Car: 99 Mystic Green Trans am
Engine: LS1: Heads, MS4 cam, bolt'ons
Transmission: Fully built T-56 w/Spec3 & Pro 5.0
Selling my whole set-up as I bought another car and
Will not be continuing with my other one for a while.
Everything in the picture is included as well as things not included in the picture.
PLEASE read what’s included before asking me if it is or not, some parts are not pictured.
I have listed what parts you will need to have a fully running engine also.
The wiring harness was modified by me(3rd time I’ve done this) and is now a fully stand alone harness, all unnecessary wires have been removed. All hook-up wires are fully label for an easy install. A/C was removed but I can reconnect the wires needed for it, if asked to. VATS has not been removed on the computer.
I am looking to get my moneys worth for this set-up/time and parts put into it
And also a local buyer – I will start my price at $3100
Any OTHER question anyone needs answering, call me at 281-413-4582 on my cell
I am located in Cypress TX 77429
I will not separate so please don’t ask
Included:
2000 engine block w/ 86k
2002 241 vette heads with vavle job, new seals, installed with all new bolts and metal head gaskets
2000 T-56 transmission with clutch/flywheel assembly w/86k
2000 modified wiring harness, all unnecessary wires removed, can make it w or wo A/C
2000 stock computer, manual trans
Low mile 18K stock springs and rockers
New GM high performance lifters
New LS2 water pump with gaskets
New LS6 oil pump
New LS2 timing sprockets and chain
stock hurst shifter w/ 6-speed white shifter ball
Starter
Stock balancer pulley
Valve covers
Alt bracket
A/C bracket
Trans mount and crossmember
Oil pan w/ pickup tube and tray
Coil packs and brackets
Fuel lines
Injectors
LS1 intake
LS1 Steam crossover pipe
Throttle body and sensors
Cam, thermostat, oil level sensors
Bolts bolt bolts
Parts you will need to make it run:
Pushrods
Injector ring seals
Alternator
A/C compressor
Parts I can also provide:
255lb walbro inline fuel pump with all needed fittings
clutch slave fitting in to a 3an Stainless steel line
3" in/out flowmaster y pipe
Autometer C2 gauges: tach, speedo, fuel, oil pre, water temp.
Dynomax welded race muffler 3" in/out
JR
Attached Thumbnails F/S 2000 LS1 engine and manual trans w/wiring harness-2000-eningtrans.jpg   F/S 2000 LS1 engine and manual trans w/wiring harness-2000-enginetrans2.jpg
Old Nov 10, 2008 | 08:57 PM
blue91z28cam's Avatar
Car: 1991 Camaro Z28
Engine: 305 LB9 5.0L
Axle/Gears: POSI 2.73
Re: F/S 2000 LS1 engine and manual trans w/wiring harness
if only you were selling this in a few months, I'd be all over it..
well if you still have it by next march..aggh its hopeless, Im sure you'll sell it by then..
Good luck on your sale and sorry for my small rant
-Fernando
Old Nov 10, 2008 | 10:05 PM
I've been trying to sell it for a few months now just over on LS1tech, just decided to post it here to see if i could get any bites.
Anyways I hope I can sell it soon too, as my DD need desperate attention and this would fix her right up.
Cheers, JR
Old Nov 19, 2008 | 04:17 AM
Lowering price to $2900.
Had to use the oil pan off this motor as I found out the one on my Trans am was cracked badly. still comes with the pick-up tube and tray.
Would like to sell it this month peeps
JR
Old Nov 21, 2008 | 01:43 AM
More problems, My DD Trans Am's Tranny just lost 3rd and 4th gear, damn autos , I will be using this manual tranny for the swap.
I will sell the motor with wiring and comp for $2000.
and if you want I can throw in a 4l60e that needs to be rebuilt with a lightly used Yank SS 3600 stall ($1000 new) for $550
Also if you buy the motor I will have the computer's VATS deleted, rear O2's deleted, and retuned and wire the harness for an automatic if you wish. all your choice guys.
Hurting for cash, PM ME NOW!! , JR
Old Dec 1, 2008 | 10:57 AM
Offers?
Old Dec 1, 2008 | 06:32 PM
Man I sure wish I had the money...I only got a couple hundred to my name so I can't offer any resonable offer yet...good luck with a sale though
Ps. What side of Houston do you live in?
Old Dec 1, 2008 | 07:52 PM
I'm on the Northwest side of Houston, in Cypress 77429 .
Got anything to trade?
looking for TA LS1 parts:
Double adjustable LCA
subframe connectors
spec stage 3 clutch
spec flywheel
Also like laptops and digital camcorders
It's so close to Christmas, I really want to sell this thing
Old Dec 2, 2008 | 10:27 PM
sorry man Ive got pretty much nothing to trade..Ive got a camcorder and thats about it...
Old Jan 24, 2009 | 06:30 PM
Dustin Fitch's Avatar
Car: 91 Firebird
Engine: 3.1
u ever sell that motor?
Old Jan 25, 2009 | 03:11 AM
Nope still have it lol
Old Jan 25, 2009 | 01:33 PM
Car: 91 Firebird
Engine: 3.1
pm sent
Old Jan 27, 2009 | 09:33 PM
Car: 91 Firebird
Engine: 3.1
Old Jan 28, 2009 | 11:41 AM
yevgenievich's Avatar
Car: numerous
Engine: ls1, others
Transmission: t56, others
Axle/Gears: 3.23 7.6"
did you go ahead and used the tranny for your trans am?
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
camaro11j
Sep 19, 2018 08:49 AM
jharrison5
Aug 19, 2015 05:53 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
