South Central Classifieds for the South Central Region
In need of Window piece
Old Apr 28, 2010 | 09:00 AM
Transam.82's Avatar
Car: '82 Trans Am
Engine: 388 5.7L V8
Transmission: T-10
I'm not sure what its called, but attached to the door, and seals between the door, window and car. My driver side dry-rotted and I'm looking for a new one. Anyone have an extra or know where I can find them? It for an '82 T/A.
Old Apr 28, 2010 | 09:49 AM
esc's Avatar
esc
Car: '82 Camaro 11.7@121
Engine: 377
Transmission: 400
Axle/Gears: Dana 44 / 3.31:1
Re: In need of Window piece
I'm not clear as to what you are asking for. Where EXACTLY does it go?
A picture would help.
Old Apr 29, 2010 | 03:53 PM
Transam.82's Avatar
Car: '82 Trans Am
Engine: 388 5.7L V8
Transmission: T-10
It goes in the door at the font of the window. completing the seal between the car frame, door and window. I will have pictures up soon, computer doesn't want to upload them.
Old Apr 29, 2010 | 04:55 PM
Transam.82's Avatar
Car: '82 Trans Am
Engine: 388 5.7L V8
Transmission: T-10
Here are 2 pictures of where it should be.
Attached Thumbnails In need of Window piece-2010-04-28-08.50.29.jpg   In need of Window piece-2010-04-28-08.50.19.jpg
Old Apr 30, 2010 | 06:10 AM
esc's Avatar
esc
Engine: 377
Transmission: 400
Oh, you need the "triangle" at the front of the glass. I don't know what it is called either.
But I am interested in how one would go about replacing it.
Old Apr 30, 2010 | 11:45 AM
Transam.82's Avatar
Car: '82 Trans Am
Engine: 388 5.7L V8
Transmission: T-10
Yea, sorry I should have said triangle. It appears to be bolted on the inside of the door, which is where mine dry-rotted. I still have part of it inside the door its self. An this piece also guides the window, and that came out with it.
Old Apr 30, 2010 | 11:57 PM
DrewsCam's Avatar
Car: 1991 Z28
Engine: 355 TPI
Axle/Gears: 9 bolt disc / 3:27
its not fun to replace but you should look up jupiter on here he's parting out a camaro and you can grab it from him..
Old May 1, 2010 | 12:31 AM
Scorpner's Avatar
Car: 85 SC, 86 Berlinetta
Engine: V6, V8
Transmission: 700r4, 700r4
IIRC, the early years are different so you may want to verify what year you need. I think they're most commonly called window or door triangles and you should easily find them from someone parting out a car of similar year or searching under window or door triangle.
Old May 1, 2010 | 05:20 PM
Transam.82's Avatar
Car: '82 Trans Am
Engine: 388 5.7L V8
Transmission: T-10
Ok, thanks! I will check around, I don't find a lot of '82-83 part outs.
Old May 1, 2010 | 07:46 PM
Scorpner's Avatar
Engine: V6, V8
Oh, sorry, I forgot to say to use the search engine here to see if you can find some early Thirdgens being parted out.
Old May 1, 2010 | 08:34 PM
esc's Avatar
esc
Engine: 377
Transmission: 400
Thats a bummer, I have a couple of doors off of a '92 I parted out. I was thinking about pulling those triangles off for my car. But if they wont fit...
Maybe I'll have to transplant the eniter doors. Except they are power doors and I don't have power anything in my car. I'll probably diseect the '92 doors and see for myself if the parts will fit.
Old May 3, 2010 | 04:21 PM
DrewsCam's Avatar
Car: 1991 Z28
Engine: 355 TPI
you sure that they don't fit the 82-83... i had an 82 z28 and swapped the triangles from an 88 and they fit fine if i remember correctly... i'll have to look it up
Old May 3, 2010 | 06:28 PM
92_T-5's Avatar
Car: 92 Camaro T-5
Engine: tbi 305
Transmission: t-5
Axle/Gears: ?
custom lol
Old May 5, 2010 | 01:59 PM
3rdgenparts's Avatar
On Probation
Engine: LU5 305 CROSSFIRE
Transmission: TH-350
Axle/Gears: Limited Slip 3:23
I specialize in nothing but '82-84 Firerbirds out of Oklahoma.Let me know if you need anything in the future
FYI,Those window triangle trim's are IMPOSSIBLE to find in nice shape out of 82-84 cars
Dave
Old May 6, 2010 | 09:12 AM
Jupiter's Avatar
Car: 82 Trans Am
Engine: 383
Axle/Gears: Built 4th gen 3.42 posi/disc
I have an 88 Formula parts car and i will check those out later this week when i
get to the shop. I don't believe those are any diff then what is on our 82 T/A's.
Am sure the window rubber on the triangles will be dry rotted but that is a
replacement part from Classic Industries GM part # G1220 RH and G1221 LH for
$78.95 and $80.95 respectively. They also carry a pair of reproductions part #
K3195 $29.95 a pair.
The parts are listed for 1982-1992 which is another indicator they are probably
all the same from 82-92.
P.S. those triangles are called 'Window Corner Filler' the rubber molding on it is called 'Window Corner Filler Weatherstrip'
Old May 6, 2010 | 09:32 AM
ILLIROC89's Avatar
Car: 89 Iroc 78 z-28
Engine: 350 tpi
Axle/Gears: 2.77:1
I have a pair in good shape, off a 86 Iroc. Send me a E-Mail address and I can send you some pictures. Take $20.00 plus shipping
Old May 9, 2010 | 10:20 AM
Scorpner's Avatar
Engine: V6, V8
https://www.thirdgen.org/forums/exte...triangles.html
Old Sep 4, 2010 | 07:38 AM
rwelte's Avatar
Engine: 5.0 Litres H.O.
Transmission: 5-Speed Manual
Sorry for reviving this old thread.
I got these 'Window Corner Filler Weatherstrips' from rockauto.com for replacing the cracked ones on my 1984 Z28 H.O.
Can one of you tell me the right procedure for replacing them? Do I have to remove the filler assembly first? Do the weatherstrips have to be glued somehow onto the filler assembly?
Many thanks for helping.
Greetings from Switzerland,
Roland
gteatr6
Interior Parts Wanted
Sep 10, 2015 09:55 PM
Fronzizzle
Sep 8, 2015 12:10 PM
scottmoyer
Sep 7, 2015 07:06 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
