TEXAS statewide gathering SWAP MEET thread
Car: 89 rs, 86 Trans Am
Engine: RS-V6... Trans Am-LG4
Transmission: RS-T5... Trans Am 700r4
for all those planning on coming to the gathering... this is place to post for parts you need, or parts you have to sell.
If you ask somebody to haul parts all the way to Austin, please be serious about actually purchasing them.
I'll start... I could use a wonderbar and an airdam for an 89.
I might post some parts later I have for sale, butI don't have much.
I do have a nice drivers door with the electric window motor (glass included) I wouldn't mind selling--- $50
post away!
post away!
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
Re: TEXAS statewide gathering SWAP MEET thread
Edit: Not gonna be able to make it
. Last edited by travis401; Jun 23, 2010 at 11:25 PM.
i also have three trim rings for 14" rally wheels. $10 each, or $25 for all three
Car: 1984 Trans Am aero
Engine: 5.0 H.O. 305
Transmission: 5 speed manual
Is anyone looking for the t-top shades? I have a black set that I paid like 80 for and purchased another set as well. Let me know and I will bring them before they go up on ebay.
Car: 90' Firebird Formula 350
I have the following parts, and prices listed. The only think I wont stuff in the back of the bird is the engine block.
Eagle/TRW Balanced Rotating assembly
350 Crank p/n 103503480 $100
5.7 Forged I beam p/n 5700BPLW with TRW pistons pressed on. Piston p/n L2256F30 $350
Pistons do not have rings. TRW calls for p/n E-251K030
I upgraded to Scat forged bottom end components in the middle of the build up so these are just collecting dust.
LT1 Components:
PCM $75
Automatic trans Engine Wiring Harness $150
Short block assembly $150(main bearings siezed from no oil pressure, comes with crank, rods, pistons, oil pan, timing cover)
LT1 aluminum bare Heads $100(one side head is damaged, pm for details)
LT1 Port matched Intake $150
ASP underdrive crankshaft pulley/balancer p/n 945800 $100
LT1 Fuel Rail with stock injectors $75
Granatelli MAF p/n 350111 $175
GM 3.08:1 Ring and Pinion for a 10 bolt $75
LT1 Components:
PCM $75
Car: 85 Iroc
Engine: 305 LB9
I have a GM Eaton Posi from an 01 SS with 3.42 gears - $150
I have rear brake setup from the same 01 SS -$150
Car: 1992 Z28
Engine: Forged LS3
Transmission: T56 stage 2 clutch
Axle/Gears: 35 spline with 3.55 gears
I might need it for the 91 Z28 vert that I have................
Car: 85 Iroc
Engine: 305 LB9
Sounds good. I will throw it in a box and bring it with.
I have backing plates, rotors, calipers, cables, etc.
Car: 1992 Z28
Engine: Forged LS3
Car: 85 Iroc
Engine: 305 LB9
Car: 1991 z28
Engine: Turbo 310
Axle/Gears: D44
i need some screws(8 or so?) for the center console shifter plate for a camaro, the black ones with the torx(star) heads
i need a beechwood headliner (abs plastic is best), beechwood carpet, and NICE beechwood speaker covers
i need the weather stripping that goes on the back edges of both doors
i need the rear 1991 Z28 emblem for the bumper cover (bottom right)
Car: 1992 Z28
Engine: Forged LS3
Hello,
I will be needing a driver fender for 91 z28. And it would be great if it was red.
And it would be even better if it was for a 1991 z28 vert. The bracket is different that holds the fender on...........
Also
I am looking for 98-2002 f-body rear end, complete with brakes, & ebrake, ect.
I need one for sure, possibly two
Also
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
I will be bringing a few leftover STS units (Sequential Turn Signals) to the meet if anybody's interested. $50 cash.
Lou
Lou
LT1Formula
Nov 16, 2015 01:13 PM
