Anyone going to Tucson this weekend?
Car: 1987 IROC-Z / 1992 Corvette
Engine: 305 TPI / LT1
If I get my car fixed, I'll drive down on Sat. morning.
Is anyone else planning on going?
Car: Sexy
Engine: Stock
Transmission: Slipping
At least part of the reason azcamaro is coming to Tucson is to buy a couple parts from me, if some of you Phoenix people want to pick up the parts you're interested in, maybe you can work something out.
Car: 91z28 and 88 SC thats for sale,in the sig
Engine: 305 TPI soon 383 stroker or 327
Transmission: t-5
hey azcamaro,get the STB for me? ill give u the money for it,but i wont be able to go.
well I didn't get my car fixed
I have no idea what is wrong, so I'm taking it to my mechanic.
Should be fixed today. I'll drive down to Tucson tonight or tomorrow morning early.
CamaroStud1988 > np > I'll pm my cell #
I have no idea what is wrong, so I'm taking it to my mechanic.Should be fixed today. I'll drive down to Tucson tonight or tomorrow morning early.
Transmission: t-5
um,im a mechanic at a dealership,lol,whats wrong w/ ur car. whats it doing.
over heating > can't use my air
rad is good > no leaks > water is circulating through the system > don't see any leaking anywhere (except when I turn it off & the over flow tank over flows)??????????
I smitted a thread
https://www.thirdgen.org/techbb2/sho...hreadid=241797
29 views no replies
I smitted a thread
29 views no replies
Transmission: t-5
id say t-stat or the fans arent coming on, if u bring it over i can check it out for u,a t-stats like 10 bux.not hard to do at all. what kinda engine is it on? u got aim?
I'm getting ready to put in a new t-stat on now. New rad cap 3mo's ago. I'm going to chk it, make sure the seals aren't bad.
I got some pipe insulation @ hm depot. I read here somewhere, that there should be a gasket (don't remember if that's the term) btween the condenser & radiator.
It did't over heat driving to or from where the mechanic lives (about 15 mls). Drove freeway there & drove thru town back.
more later..........
cars 6cyl (173 eng) pretty much stock > just MSD ign\plug wires & blaster coil. Oh & K & N air fltr
No AIM > MSN
No AIM > MSN
Transmission: t-5
whatd the mechanic say... i ahve a v6 car,it overheated cause teh fans werent kicking on once, and it got hot for a while,like yours does cause the t-stat was sticking. the only gasket their should be, taht ull replaced will be between the tstat housing and block, but u can just use black silicone for it.good luck.
mechanic wasn't home
I replaced the t-stat last nite. Going to get TPS now & then to friends house. Her room mate said he'd help us swap out old > new TPS.
When done, still plan on cruisin' to Tucson.
Sebastian give me a call in a couple of hrs.
I replaced the t-stat last nite. Going to get TPS now & then to friends house. Her room mate said he'd help us swap out old > new TPS.When done, still plan on cruisin' to Tucson.
Ugh!!!!!!!!!
Got the TPS back in my car. My brother notices the grommet that’s on the end of the Mixture Control Solenoid is messed up. Calling around it’s not something that is an in stock item. They tried to sell me the whole MCS for $104.
Sorry Synapsis, there is no way I can come down now. PMing you.
Finally heard from my mechanic, he’s real busy….air cond repairs.
1˝ hrs later………..on the road again! Runnin’ good & the best part, I can run my air!!!!!!!!!!
Replaced t-stat & TPS + had to treasure hunt for the stinkin’ ( yeah I’ll say it now, STINKIN’ NO GOOD Grommet!!!!!!!!!!) The grommet turned out to be the worst part.
no green
Jan 9, 2016 09:22 PM
