South West Region South West regional discussion board.
VATS help
Old Jun 30, 2005 | 11:47 PM
Abanda's Avatar
VATS help
Ok so i have a 91 firebird formula with the antitheft system that uses that chip in the key to start. well i got in a very small fender bender and now my car wont start. I did a dianostic and it told me that my Vats control relay is bad. I have a small diagram that tells me that i connects directly to the ECM but i still cant find it. anyone that has ever worked with this or can help me find this and can offer some help will be great thanks
Old Jul 1, 2005 | 01:17 AM
CaptPicardsZ28's Avatar
Car: NCC-1701-D (docked in AZ)
Engine: impulse drive
Transmission: fusion reactors
Axle/Gears: Rescued from the Borg by my crew
Re: VATS help
I can't help you on that one but I know Trickster can. He has all the schematics and can probably tell you how to fix it too. Give him a PM...
Old Jul 1, 2005 | 02:31 AM
Synapsis's Avatar
Car: Sexy
Engine: Stock
Transmission: Slipping
Follow the wire from B6, my son. Your salvation lies at the end of it's path.
10 bucks says it's under the driver's side of the dash somewhere. Not that it helps much. Apparently it's a dark blue wire.
Old Jul 1, 2005 | 02:32 AM
Synapsis's Avatar
Car: Sexy
Engine: Stock
Oh, and if you burn your own chips for the ECM, you can shut it off there too so you can at least drive the car.
Old Jul 3, 2005 | 12:15 AM
Abanda's Avatar
more help
ok well i have multiple diagrams showing me the electrical lines that run in an out of the ECM and the Vats control module. the thing is I cant find the vats control module. I dont really know what to llok for because I am new to this car repair stuff and I dont know what it would look like. All i know is that it has a blue wire coming out of it that connects it to the ECM. other then that I am lost.
Old Jul 3, 2005 | 02:17 AM
Re: more help
Here's some help. I used the search button...
https://www.thirdgen.org/techbb2/sho...ht=vats+module
Old Jul 4, 2005 | 04:24 PM
Abanda's Avatar
Thanks Capt
yeah i know i should have used the search but at the time of these last posts, my search button wasnt letting me search for anything. Just recently did it become avaliable to me again. thanks for your help it is greatly appreciated.
Old Jul 4, 2005 | 05:51 PM
Re: Thanks Capt
Your welcome...only told you I used the search cuz I didnt want to take credit for something I didnt know.
Old Jul 4, 2005 | 08:51 PM
90RS305's Avatar
Car: 96 Silverado/99 Suburban
Engine: 700 cubic inches of 'Muican Awesome
Transmission: 4L80/4L60
Axle/Gears: Chunky/Clunky
Re: Re: Thanks Capt
Old Jul 6, 2005 | 09:32 PM
mrt89rs's Avatar
From: Tucson AZ where the 3k ft of elevation kills your time
Car: 89 camaro rs
Engine: 383 .06 over
Transmission: th350
Axle/Gears: 3.73 10 bolt
I take it you found it already if not,
The relay for the starter cut off should be behind the plastic (kick panel i think its called) cover on the driver side. You will see a black tape that covers the bolts that hold the driver door to your car. Take that tape off and the relay should be right there.
Thats where it was at for my 89 camaro rs that came stock with a lo3. when i swiched to carb I took the ecm out and was not able to start the car after words so I traced the problem to that relay. I cut the small green and black wire I think(it's been like three years) and ran it to a swicth then a wire to a ground, and that is now my starter kill swicth
Old Jul 8, 2005 | 03:17 PM
Abanda's Avatar
OK finally i got my bird running again. It turned out to be the small white wires that are in the ignition. One of them was cut and barely holding on. I reconnected it by sodering it together and boom instant life! Thanks for everyones help.
RS Reaper
Oct 17, 2018 07:52 PM
djmarch
May 8, 2016 11:32 AM
AmorgetRS
Sep 28, 2015 09:33 PM
86White_T/A305
Sep 21, 2015 05:28 PM
Winchester1094
Sep 15, 2015 09:48 AM
