South West Region South West regional discussion board.
one of you should know...
Old 08-01-2005, 04:11 PM
  #51
AZ406TPI's Avatar
Car: 1986 IROC-Z/28
Engine: 406 CID SBC
Transmission: 700R4 A4
yea, thats the 1
Old 08-02-2005, 08:48 PM
  #52
SchwarzCamaroRS's Avatar
hmmm, sounds sweet, and i gotta get the new fans though, my single 1700cfm isnt cuttin it... and the AC still overheats the car... wtf??
Old 08-02-2005, 09:43 PM
  #53
Moderator/TGO Supporter
Duck's Avatar
Car: 87 IROC 92 Z-28 91 Ragtop
Engine: 5.7
Transmission: 700-r4
The AC condensor sits completely in front of the radiator and besides reducing airflow, gets hot when the AC is on and transfers to the radiator. Since you have a new radiator, there probably isn't a bunch of leaves and junk between the two units, like most cars.
If the car overheats in traffic, just turn on the heater full-blast, the additional cooling may prevent an inopportune boil-over [of the engine, that is].
Some good examples of using airflow restriction as a temperature tool are trucks in the artic winter, running around with zip flaps covering the radiator fronts.
Old 08-03-2005, 03:14 AM
  #54
i wanna do the opposite of that... my car USED to run cool even with the stock radiator... never really that cool with the AC on, but now its a monster radiator compared to the stock one... i was thinkin of just using a 3600cfm single fan my roommate has in storage somewhere... i think that might do the trick...
Old 08-03-2005, 09:21 AM
  #55
Duck's Avatar
Engine: 5.7
What kind of radiator did you install and what are the specs?
Old 08-03-2005, 09:38 PM
  #56
azvolfan's Avatar
Car: currently thirdgenless!!!
Dave,
It was nice and cool out today (Wednesday). How did your can run? Hot or cold?
Old 08-04-2005, 04:24 AM
  #57
duck - its a summit 2 core aluminum 17.25" X 26.5" core with a 1700 cfm autozone fan
bill, its runnin cool in the daytime without AC on, but the AC spells death for the temp gague... it just keeps goin up. And if i get in some traffic, the needle likes to rise... even with the fan on and AC off...
Old 08-04-2005, 05:07 PM
  #58
azvolfan's Avatar
Well the first possible problem I see is that our cars use a 31x19 radiator. Might the radiator be too small?
Old 08-04-2005, 07:34 PM
  #59
TonyC's Avatar
Car: A Camaro
Engine: Weak
Transmission: Weaker
Dave what fan setup do you have? You listed the CFM rating so I'm assuming it's aftermarket. I had some problems with running hot with the A/C on with a single fan, but I switched to dual fans and haven't had a problem since. They come on progressively, one fan at like 180* and the other when the A/C turns on or at something like 200*. Keep in mind that your temp guage could be off. If you have an ALDL setup, ride around with your laptop to see what the temp REALLY gets up to. My temp guage and the actual temp have never really jived well.
Old 08-04-2005, 07:36 PM
  #60
TonyC's Avatar
Car: A Camaro
Engine: Weak
Nevermind, actually read the thread . Dual fans would prolly help out especially in the PHX heat
Old 08-04-2005, 11:17 PM
  #61
azvolfan's Avatar
My mechanic said my temp gauge is off 10* is the upper ranges.
Old 08-05-2005, 12:24 AM
  #62
well, then summit's measurements are off cuz its A LOT bigger than stock... its like 3/4" wider and at least 1" taller than my OEM one...
Old 08-05-2005, 06:26 PM
  #63
azvolfan's Avatar
I actually never measured the stock radiator. I'm just going on all of the aftermarket replacements I see call for a 31x19.
Old 08-06-2005, 02:46 AM
  #64
yeah, they all do, but if the summit measurements are correct, then a 31X19 WILL NOT FIT... lol, i had a hell of a time fittin mine in there... haha
Old 08-06-2005, 06:47 PM
  #65
Synapsis's Avatar
Car: Sexy
Engine: Stock
Transmission: Slipping
Yeah, there's no way a 31" radiator would fit in there:
Sorry for the large pic, had to keep the tape measure in focus.
Old 08-07-2005, 01:46 AM
  #66
oh, whered u get ur radiator hold down doohickey... i need one... mine is kinda just sittin there... its got a couple shotty brackets i fabbed up REAL quick with some strips of metal and pliers...
Old 08-07-2005, 06:55 AM
  #67
Synapsis's Avatar
Car: Sexy
Engine: Stock
I made it.
Old 08-07-2005, 12:53 PM
  #68
yeargh.... how much would you charge for somethin like that?
Old 08-07-2005, 10:37 PM
  #69
Synapsis's Avatar
Car: Sexy
Engine: Stock
Probably around 75 bucks.
Old 08-08-2005, 03:35 AM
  #70
hmmm... maybe when ive got some extra dough, ill send ya a pm... haha
Old 08-08-2005, 03:29 PM
  #71
CaptPicardsZ28's Avatar
Car: NCC-1701-D (docked in AZ)
Engine: impulse drive
Transmission: fusion reactors
Axle/Gears: Rescued from the Borg by my crew
Is it for a griffin 31X19? If so I am interested and will buy one. How did it affect the fan mount?
Old 08-08-2005, 03:49 PM
  #72
Synapsis's Avatar
Car: Sexy
Engine: Stock
Yeah, that's the radiator in the pic. I made it for a stock dual fan system, it moved the fans back a little bit. You might have to clearance one of the fan arms a little to fit behind a stock wonder bar.
If you need fan mounts for something other than stock duals, I'll need measurements.
Old 08-09-2005, 02:52 AM
  #73
Right now I have the stock single fan with the stock shroud. I had to cut the end of the shroud back a little. I also used shims to keep the fan from rubbing. I do want to switch to aftermarket duals but am having trouble finding out which ones will give me the least fitment problems on my griffin.
Old 08-30-2005, 11:56 PM
  #74
when you figure it out, let me know, im gunna go duals too... that SPAL setup looks good, i think i might try that when i get the money...
hmmm... do you think This Fan will fit on This Radiator if i mount it over the endtanks?
Old 09-08-2005, 03:24 PM
  #75
bump!
luvofjah
08-29-2015 08:33 PM
CORV3TT3
08-23-2015 11:26 AM
[-sLaYeR-]
07-26-2002 11:39 AM
Xenodrgn
10-22-2001 12:26 PM
Xenodrgn
10-22-2001 10:33 AM
Quick Reply: one of you should know...
