South West Region South West regional discussion board.
Need help fixing Dimmer switch and now tilt mechanism..
Old Nov 22, 2005 | 05:21 PM
BigWhiteGTP's Avatar
Car: 1994 Trans Am
Has anyone fixed these before? I would think it would be easier to remove the metal around the tilt gears and bright/turn/wiper switch, but I don't think it comes off.
Anyone have any free time this weekend to help me out?
-Kevin
Old Nov 22, 2005 | 06:12 PM
Duck's Avatar
Moderator/TGO Supporter
Car: 87 IROC 92 Z-28 91 Ragtop
Engine: 5.7
Transmission: 700-r4
Re: Need help fixing Dimmer switch and now tilt mechanism..
-Kevin
Here's the fixit file link for the tilt wheel. Just DL the PDF. I can help this weekend, you buy the transportation!
http://www.geocities.com/luckyducky_96701/
The dimmer problem is most likely due to wear in the nylon bushing that needs to be adjusted for. The process is well-documented on TGO. You may also opt to install a foot switch like I did on the '92, merely because I like them.
Be warned that taking apart the column and getting it backtogether correctly is very complex, mostly due to all the parts being strange and fitting together in odd ways. Approach it calmly, knowing it will be done in stages over a day or two as frustration builds to the boiling point. Garages want $100-200 to do the job, but patience and valium will see it through...
Old Nov 22, 2005 | 06:54 PM
FrankenT/A's Avatar
Car: Trans Am
I'll help you out
**Forgot to add, I have a spare dimmer mechanism if you need it**
Old Nov 22, 2005 | 07:39 PM
Car: 1994 Trans Am
I don't even see where to remove the cover. Thanks for the link, I'll check it out later.
Old Nov 26, 2005 | 12:51 PM
jandl22's Avatar
Car: 82 White Stock Camaro
Engine: 2.5 151 TBI
Transmission: 4 Speed Manual
Hey Kevin,
I have a spare tilt column in my back yard that I will not use. If you need any parts let me know you can have them for basically the shipping.
Lawrence
Old Nov 26, 2005 | 07:17 PM
Car: 1994 Trans Am
Lawrence, how hard is it to replace the whole steering column?
Old Nov 26, 2005 | 07:26 PM
jandl22's Avatar
Engine: 2.5 151 TBI
I wish I could tell you, I was going to try it and I chickened out. Sorry Kevin.
Lawrence
Old Nov 27, 2005 | 01:38 AM
Duck's Avatar
Engine: 5.7
...how hard is it to replace the whole steering column?
It's an easy job. You'll need to switch the ignition key cylinder though.
Ghettobird52
Jul 5, 2024 11:18 PM
Dkelz313
Apr 7, 2016 10:38 PM
The_Phoenix
Feb 4, 2016 07:10 AM
86IROC112
Aug 17, 2015 02:00 PM
Fronzizzle
Aug 9, 2015 01:15 PM
