South West Region South West regional discussion board.
Power Window Tension Spring
Old Jan 28, 2006 | 10:50 PM
1Bad3rdGen's Avatar
Car: 92 Firebird Convert & 91 Camaro RS
Engine: 305 L03 TBI
Transmission: 700r4 & T5
Axle/Gears: Stock
Ok today i started replacing my power window motor on the passanger side. after drilling out the last rivet the window came down and the tension spring came out of its place. i try for hours to put the tension spring back on no luck. so i got tired and left that alone. i got the new motor on and ready to go. motor goes up and down fine. but my concern is this tension spring that i have in my trunk. how would i put it back. will it affect my motors life span. can anyone help out with this... i really appreciate it. Thanks
Old Jan 29, 2006 | 12:38 AM
3GTAs1TA1Z28's Avatar
Car: 85 87 87 91 92
Engine: 305 TPI 350 TPI 350 Carb
Transmission: B/W T-5 and 700R4
I never put the one back in the drivers side of my 92 GTA and it has been working great for atleast 4 years now...And on top of that it is faster than the passenger side that still has the spring...Maybe its just a fluke but no problems here
Old Jan 29, 2006 | 12:43 AM
1Bad3rdGen's Avatar
Engine: 305 L03 TBI
Axle/Gears: Stock
ok i figured it rolled down and up faster than my driver side... just want to make sure its not an important it must have... but ill keep the spring in case i have problems...
Old Jan 29, 2006 | 12:54 AM
Car: 85 87 87 91 92
That is probably a good idea I still have mine to....In a 5 gallon bucket along with all my spare nuts and bolts...LOL
Old Jan 29, 2006 | 01:05 AM
azvolfan's Avatar
Car: currently thirdgenless!!!
I never did get it back in my passenger side either. For the driver's side I replaced the window by drilling holes in the door right where the rivets are that hold in the motor. Then drilled out the motor rivets and the motor fell out without taking out the actuator. Do a search on the interior board if you need to do the other. Someone posted a template for drilling the holes needed. It was a breeze.
And I would recommend to anyone who needs to do this to leave the actuator in and do it with the template.
Old Feb 1, 2006 | 12:01 PM
TonyC's Avatar
Car: A Camaro
Engine: Weak
Transmission: Weaker
It's definitely tricky to get the spring back on but it can be done with an hour of swearing and cutting your hands up . If it starts giving you problems and you have to get it back in, let me know and I'll see if I can come help ya.
Old Feb 1, 2006 | 12:02 PM
TonyC's Avatar
Car: A Camaro
Engine: Weak
Old Feb 3, 2006 | 12:53 AM
1Bad3rdGen's Avatar
Engine: 305 L03 TBI
Axle/Gears: Stock
Thanks ill let you know if i have any problems.
Old Feb 3, 2006 | 08:37 PM
sgt0704's Avatar
Car: 91 camaro rs
Engine: 305 tbi
Transmission: 5 spd
Axle/Gears: what ever stock is
i got mine back in using a table vice and a long prybar.. a pain in the ***.. however, the window is still slower than the driver side, and i don't know why... maybe it needs some lube.. it just seems like the motor isn't fast or powerful enough.
Old Feb 3, 2006 | 08:38 PM
sgt0704's Avatar
Car: 91 camaro rs
Engine: 305 tbi
Transmission: 5 spd
is anyone one in here actually from yuma area?
Old Feb 3, 2006 | 08:40 PM
sgt0704's Avatar
Car: 91 camaro rs
Engine: 305 tbi
Transmission: 5 spd
or in yuma?
BRoss99
Aug 10, 2025 05:08 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
stalkier
Aug 21, 2015 01:54 AM
Dialed_In
Aug 20, 2015 01:45 PM
