help! NEED T.P.I 350, A.S.A.P. IN PHX.AREA
Car: '90 Camaro RS
Engine: 3.1 V-6
Transmission: 700R-4
Axle/Gears: Puny ones
I,M HOPING SOMEONE CAN HELP ME! MY DAILY-DRIVER '90 RS V-6'S TRANNY FINALLY GAVE UP, AND WHILE I HAVE BEEN BUILDING A NEW 700R4 (ALMOST DONE.) TO INSTALL WHEN I DO AN ENGINE SWAP, I WASNT PLANNING ON DOING THIS SO SOON. THERE IS A LOT OF STUFF I NEED BUT DONT HAVE. ANY ONE WHO HAS PARTS OR KNOWLEDGE (OR BOTH?) OF THIS SORT OF SWAP, I WOULD REALLY APPRECIATE IT. I HAVE A LOT OF QUESTIONS AND NOT A LOT OF ANSWERS... THE TUNED PORT 350 HAS BEEN HARDER TO FIND THAN I THOUGHT IT WOULD BE.
IF ANY OF YOU HAVE ANY LEADS ON THIS STUFF PLEASE CALL OR E-MAIL!
THANKS!
-JASON.
480-510-1055
elite_4automotive@yahoo.com
THANKS!
-JASON.
480-510-1055
Car: 92 RS, 87 IROC, 89 GTA
Engine: LO3, LB9, L98
Transmission: 700R4 X3
Axle/Gears: 2.70, 3.30, 3.27
Re: help! NEED T.P.I 350, A.S.A.P. IN PHX.AREA
i can find u the motor, how muich money to you have to spend on it? would you be interested in an LT1 instead?
Car: '90 Camaro RS
Engine: 3.1 V-6
I dont have a lot. not really that interested in a lt1. I was beginning to think no one replied to this message board. Any help you could give me would really be appreciated!
Car: '90 Camaro RS
Engine: 3.1 V-6
I dont know if u noticed but I also have my V-6 for sale if u know anyone who wants one. that gives me more money. I have a feeling its not going to be cheap... I have some side skirts for a 90 RS too and the back bumper cover + quarter extensions....
Car: 87 Firebird, 90 bird coming soon
Engine: 355 Chevy Vortec Heads TPI, LT1 inj
Axle/Gears: 2.77 posi 9-bolt
Will be able to help with the knowledge. Ask 92whitez28, I'm working with him on his car. Will be on later.
Car: '90 Camaro RS
Engine: 3.1 V-6
Thanks man, I really appreciate that! I really need to get this car back on the road! I know i'm going to need a new fuel pump among other things. getting that pump out is not easy!!! ( I refuse to cut a hole in the floor!) is there some kind of kit (or method) to put an inline pump in insted of the in-tank pump? I'm just worried that the cost will be so high... I'm a little far from u. (Wittmann).
Well, getting the tank out and back in is a chore, but I think it's worth it. I just did a carb to tpi swap in my bird and thought the whole thing was worth the time and energy. I used a 350 block from an 82 Caprice and the heads were off my 305 engine that came with the car. Don't cut the hole in the floor. There is no need to and it will take as much time to do it that way as it would to take the tank out to begin with. Here's what you will need to start:
350 block
small block chevy heads
(don't let people tell you that tpi won't work unless it's a "tpi" engine)
TPI intake with as much as you can get with it (sensors, harness, etc.)
-can be off 305 or 350, doesn't matter if it's a daily driver
-if you can get the ECM, get it (ECM is matched to injector impedance)
As long as you have a 700R4 that is shaped to fit the block you will be fine.
Get the wire diagram and vacuum diagram for the year set up you want to use.
Any hoses you can get new (most hoses don't cost that much) get.
- try not to do too much used rubber.
Get as much parts as you can for the year of system you are using so the parts will match up better and less problems. If you need any parts, let me know and I'll see what I have or help to get these parts for you.
Chris
350 block
Chris
Car: 1988 IROC-Z
Engine: 305 E
Axle/Gears: Round ones
You can get a new crate 350 motor complete (except the intake manifold and carb) from midway chevy for around 1400.00 to 1600.00. I got mine two years ago from Midway nissan (across the street) for 1150.00 . they used to advertise wholesale parts in the phone book. They do not advertise that anymore, but the older employees that remenber it will still honor it.The engine runs great it was assembled in 1997 and dynoed and then created up. I only recommend that you dont put new engine too old transmission, (I had too replace the tranny two months later, They also have rebuilt 700R4, I got mine for 950.00)
Car: '90 Camaro RS
Engine: 3.1 V-6
birdtojag What do you think of a 383? Should I use a '87 or newer block if I'm going to build it. I may as well use a 4 bolt main block. It will be expensive if I have to put it all together (machine shop services...buying all the parts new and used reconditioned) I may have a harness and ECM (not sure if either any good) It came with my El-Camino, which had a tpi motor before I got it. Still need either a in-tank or in -line fuel pump. Which is better? Appreciate your help... Jason
Car: '90 Camaro RS
Engine: 3.1 V-6
Kellman3 That sounded great except that even after I buy the long block, I still need pulleys, sensors, accessories, complete 7pi intake, injectors, electronics, and ETC. This will get incredible expensive! I would like to do it that way but I'm having my transmission (got a V-8 case) and having my tranny rebuilt using a Hugh master racing kit. (still need a torque converter) I appreciate your help... Jason
Help! Really need these parts soon. Heard there was a car swap meet at Glendale College this weekend....Need these parts soon... Jason
Last edited by elite_4automoti; Mar 10, 2008 at 02:06 PM. Reason: Automerged Doublepost
Car: 1988 IROC-Z
Engine: 305 E
Car: '90 Camaro RS
Engine: 3.1 V-6
No, I dont have most of the brackets and pulleys that I will need. I am switching from A 3.1 V-6 to a T.P.I. 350 (or 383 if the cost is not too much more.) The a/c compressor will probably still work for me, but I dont know about anything else. I am really worried about the brackets. A while ago my power steering bracket broke completely off the engine shearin the bolt off in the water pump. I was able to get a new water pump, no problem, but the dealer wanted a fortune for the bracket! (something like 300.oo if I remember right) 3 weeks of searching the u-pull-it junkyards I finally found it! (20 bucks, go figure...) I called that number. They said wrong number. thanks for thinking of me, anyway. I am beginning to get really discouraged... I will press on,though.
Car: '90 Camaro RS
Engine: 3.1 V-6
anyone know anyone selling a 383 of 350, by any chance?
Oops! sorry. 383 OR 350!
Last edited by elite_4automoti; Mar 10, 2008 at 11:34 PM. Reason: Automerged Doublepost
Car: 1988 IROC-Z
Engine: 305 E
I have a neighbor(retired mechanic) that has a 350 long block complete with a carb It might fit your needs. i just got of work, I work nights I will ask him tommorrow if I can get up earlier enough then i will try to get back with you tommorrw night or the next day.
Car: '90 Camaro RS
Engine: 3.1 V-6
Thanks, I wouldnt need the carb or intake but if he has a good rebuildable core I might be interested.
Car: 1988 IROC-Z
Engine: 305 E
I talked with him yesterday about the 350. Without the carb and intake he would sell you the engine for 600.00, He said he would be intrested about your 6 cylinder so maybe you guys can work out a better deal
Car: '90 Camaro RS
Engine: 3.1 V-6
I appreciate the help. Right now I'm looking at a 6.0 LS-2 that a friend of a friend is selling complete with a t-56 tranny out of a wrecked GTO. the price is too good to be true so I'm having my friend check it out.( It's in L.A.) I'll let you know. I'm not sure if I would put the T-56 in my camaro or stay with my 700R4. Any thoughts?
if you decide to say with the 700R4, i will buy the T-56 >.> but i would stay with the T-56. also, if the LS2 falls through, i know of a 383 for sale, rated at over 400 HP
Car: '90 Camaro RS
Engine: 3.1 V-6
I wont forget. Yeah, I have been thinking of weather or not to put the T-56 in or not. Still not sure. this car is the one I like to drive to work and back so for rush hour traffic the auto would be nice (Although the guys at the tranny shop tell me the rebuilt unit is going to shift " VERY FIRM" whatever that means to them. To me that means I will have a constant case of whiplash!)
Jason.
Jason.
Car: '90 Camaro RS
Engine: 3.1 V-6
I started pulling my motor today. I went to the swap meet at G.C.C. today. That was kind of disappointing. there was a guy selling a pair of new headers & y-pipe for a L-98 for 250.00., but other than that not much. I think the hardest part of the swap is going to get the emissions equipment right.
FormulasOnly
Sep 10, 2015 09:07 PM
