Need a machine shop/engine builder
Car: 1988 Camaro Convertible
Engine: 355
Hi Guys,
I need someone who can do the work on the block for me, and heck wouldnt mind them throwing together the TPI setup I am putting together.
Who's the best around, both quality and price.
Don or Kevin if you guys have the time let me know... I think I have crossed to the dark side and want the 383 now
still need the block, but I am wanting a 87+ roller block, 2 bolt splayed to a 4 bolt, and would like to throw an ATI supercharger on for posterity.
James
James
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
383
If you're building a "383" you need the best flowing intake system you can get your hands on (read extrude honed Super Ram) 58mm throttle body etc.
Just a little heads up for ya!
Engine: 355
Hi Don,
Accell Base
AS&M runners
52mm tb
afr heads 190's
compucam 2032
1.6RR
9:1 (haven't figured out whether using the pistons or the heads to obatin that)
that is just the base of things that I was thinking of going with...
What do you think?
Accell Base
AS&M runners
52mm tb
afr heads 190's
compucam 2032
1.6RR
What do you think?
Engine: 355
How strong do you think?
Also will you have some time to maybe work on an engine? I've heard you have been real busy lately.
James
James
[How strong do you think? ]
As strong or stronger than kevin's (318hp 420 tq @ RW's)
AFR's flow better than his ported L98's
z28venezuela
Oct 24, 2015 08:15 PM
bigjay89gta
Oct 15, 2015 08:04 AM
