Southern California Area Southern California Members.
Some quick questions...
Old Dec 27, 2002 | 12:42 AM
trans87's Avatar
Car: 2006 Tacoma X-Runner
Engine: 4.0L DOHC V6
Transmission: 6-Speed Manual
Axle/Gears: 3:15 LSD
What's the most I should pay for a used working 350 ECM from a 1987 GTA? Also what size injectors would I need for a 350? Is $150 too much for new Bosch injectors rated at 21lbs?
Old Dec 27, 2002 | 01:33 AM
IROC-Z5.7TPI's Avatar
Car: 88 IROC-Z
Engine: 5.7 TPI
Transmission: 700 R-4
I think that about 1 billion dollars would sound good , and if you like the price ill sell you mine, i think i live close by.
Old Dec 27, 2002 | 02:01 AM
rezinn's Avatar
Not sure about the ecm, but they cost like 150 new iirc. Decent deal on the injectors if they're new.
Old Dec 27, 2002 | 10:33 AM
james_85Z28's Avatar
Car: 2003 Porsche C4S
Engine: 3.6L
Transmission: 6-speed Manual
305 and 350 MAF TPI ECMs are the same (86-89). The only difference is the chip, and even the greatest difference in the chip is the injector constant.
Old Dec 27, 2002 | 06:50 PM
BretD 88GTA's Avatar
Car: Yes...
Engine: Last time I checked...
Transmission: See "Engine"...
Re: Some quick questions...
That's a really good price for new injectors. Are they Ford SVO injectors or similar to the original GM Bosch injectors?
Old Dec 27, 2002 | 11:32 PM
trans87's Avatar
Re: Re: Some quick questions...
They are Ford SVO brand new 21 lbs injectors. I am holding out though for some used 24lbs 4th gen ones that will be cheaper. And the ECM I was mistaken about so I just need to get or have reburned my chip for that.
Old Dec 28, 2002 | 01:50 PM
Car: Yes...
Re: Re: Re: Some quick questions...
For 24# injectors you'll have to get a new chip. The car will run ruch if you don't.
Old Dec 28, 2002 | 08:04 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
He already has me doing his chips.
F-body-fan
Jan 12, 2023 01:49 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
meeklay812
Oct 1, 2015 03:46 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
3.8TransAM
Sep 27, 2015 08:37 PM
