motor swap??
Car: 90 T/A GTA
Engine: 350 tpi
motor swap??
what would be a good motor swap? It would have to be smog legal and be somewhat easy to put in. THe main thing i am worried about is the smog issue. From what i have heard and read so far i'm thinking the LT1. Because i can get it cheap. and i also need tranny to go along with it. thanks guys
If you put in a Lt1, you have to install the wiring harness to match the engine, and you'll need to use the later model computer as well. If you just want to do an engine swap and be smog legal, you need to look at a 350. The ZZ4 technically doesn't have a smog legal cam, but with tpi and a custom chip, they will pass.
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Your first concerns are how much money do you have, and how much power do you want? Then we can worry about smog.
Car: 90 T/A GTA
Engine: 350 tpi
well i'm looking for something with decent power. just something that have like 300hp and 300ft or so. yeah i know that on the lt1 i would need the wiring harness it's like $350 from painless wiring.
A tuned port engine would be at that power level easily, be a lot cheaper and easier than an LT1 swap, and you can keep your current tranny. However you wont have the "cool" factor of the LT1 engine.
Car: 90 T/A GTA
Engine: 350 tpi
well i should change the tranny to. Both the motor and tranny have 172,000 miles on them. HOw much wiring would be involved in putting in a 350 tpi in?
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
I can repin your harness for $200 like I did mine. Works great! You then just need a TPI set up and 7730 computer. And the 350 0f course. I have a 350 roller throttle body motor and trans available now. (T-5 manual)
Car: 1986 Trans Am
Engine: 305 LB9 TPI
Transmission: 700-R4
ok d00d go to http://www.tacreationsusa.com . they got a selection of engines with wiring harnes and everything needed very cheap, but they are used. What isn't though? hope this helps you. about $1500 for all of it
Car: 90 T/A GTA
Engine: 350 tpi
hey don how much for the motor? i think i am going to call Thomas at H.O.C. to see if he has any 350 tpi's in. Don can you give me a ruff estimate of how much you would charge me to swap the 350 and the new tranny in. thanks guys
