Southern California Area Southern California Members.
Custom 4130 STB
Old Nov 28, 2003 | 03:29 PM
JERRYWHO's Avatar
Custom 4130 STB
All done ready to get power coated what do you think.
Jerry
Old Nov 28, 2003 | 06:07 PM
demonchild's Avatar
screw STB. That thing is f***in awesome. Its more like an engine compartment brace. also, i dont see bolt holes, how is it going to be installed?
Old Nov 28, 2003 | 07:26 PM
BretD 88GTA's Avatar
Car: Yes...
Engine: Last time I checked...
Transmission: See "Engine"...
Hokey smokes Jerry, that thing is practically a roll cage. What's the weight?
Old Nov 28, 2003 | 07:42 PM
JERRYWHO's Avatar
You don't miss a thing do you. The picture was taken before the mounting holes were drilled.
Jerry
Old Nov 28, 2003 | 07:46 PM
JERRYWHO's Avatar
14 1/4 lbs
Old Nov 29, 2003 | 02:33 PM
demonchild's Avatar
Jerry
i was just wondering if it was going to be welded in because that would make any work to the engine a pain in the A$$. looks great though and at 14 lbs i will probably really tighten up the front of the car. i wish i had a shop and the fabrication skills to do something like that. also, my grandfather gave me a welder if anyone wants to teach me to use it.
Old Nov 30, 2003 | 12:37 AM
Guest
Guest
Posts: n/a
Does it really need to be 4130? How about some aluminum instead? Not that 14lbs is all that heavy, but...
Old Nov 30, 2003 | 09:43 AM
Dwayne88IROC's Avatar
Car: Cars
Engine: SB
Transmission: manual
Axle/Gears: 9bolt
It looks like a spider!
I bet it holds like a black widow death grip.
So does the car handle like a F1 or Nascar.
Old Nov 30, 2003 | 12:54 PM
JERRYWHO's Avatar
No...But I have the ability to make them at very little extra cost over mild steel.
My cars have 4130 Chrome-Moly
S.T.B.
A-arms
K-Member
Subframe connectors
Torque arm
And a custom made 4130 Dana in the fab shop now.
I can make same S.T.B. in aluminum will be 12% lighter (1 3/4 lbs )
and will have less stiffness and more crack prone but the coolness factor will be much higher.
Now you have me wanting an aluminum one...maybe I will make one next week.
Jerry
Old Dec 1, 2003 | 11:40 PM
grafx's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Transmission: Pro-Built Automatic/Vigilante 2800
When will you have it installed?? I'd really like to see how it looks all bolted up!!
Fanatic1074
Oct 3, 2022 05:57 AM
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
91 SrS
Oct 7, 2015 04:32 PM
dusterbd
Sep 29, 2015 08:40 AM
