Southern California Area Southern California Members.
still being smog legal?
Old 05-19-2004, 05:36 PM
PsychoGTA's Avatar
I'm thinking about getting the BBS turbo system for my 92 GTA. My question is will I be able to pass the smog test. Will I get failed for the visual under the hood? Or will it put out smoke? Is it also possible to get a set-up for 600+ rwhp and still be smog legal? Are my goal's just a dream, unless if I move to another state? Oh ya is my car a Serpentine belt or v-belt.
http://www.bbsdesigns.net/cgi-local/...8b4+1085007902
Thanx
Peace Out,
PsychoGTA:lala:
Old 05-19-2004, 05:57 PM
CustomX's Avatar
Car: 90 irocz
Engine: 350tip
my guess is no, since the tech willsee a huge turbo ontop of the valve cover and then ask for a carb number
Old 05-19-2004, 06:41 PM
8T8IROC's Avatar
Car: Moving...
Engine: Running...
Transmission: Shifting...
I would say that you have a very difficult time with smog, but with the right connections I doubt it would be impossible.
Old 05-19-2004, 09:02 PM
Russ-So Cal's Avatar
There are no turbo set ups for our cars that are smog legal except the Turbo Trans Am, and that is only for 1987. If you want a blower, Vortech & Ati Pro Charger are smog legal.
Old 05-19-2004, 10:18 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Turbo Trans Am is 89, Russ.
You have a serpentine setup. That's 88 and newer, while the v-belt is 87 and older.
There used to be a Gale Banks turbo setup for thirdgens, but it is long since discontinued.
Old 05-19-2004, 10:23 PM
Thanks fr the correction Kevin. I know the TTA is the twentieth anniversary addition. I just keep thinking it ought to be the 20th anniversary of the birth of the Firebird 67-87. Instead it is the 20th anniversary of the birth of the TA?
Old 05-20-2004, 12:03 AM
Kevin91Z's Avatar
The Trans Am wasnt available until 1969, thats why its off by 2 years.
Old 05-22-2004, 10:53 PM
1BADDAM's Avatar
Car: 89 TA
Engine: 3.8 V6
Transmission: 2004R
And they still scratch their head and say "did this car come like this ?"
Just had mine smogged Friday, the retest The week before it failed. Both smog techs. at the test only asked the same question a week apart.
Old 05-24-2004, 12:06 PM
PsychoGTA's Avatar
Do you think I can get away with making a fake carb eo plate? Or do they write down the carb eo #'s to see if there right?
Peace Out,
PsychoGTA
Old 05-27-2004, 12:31 AM
Kevin91Z's Avatar
They have a big book of all the CARB EO numbers. If they doubt your mod, they will look it up. Again, it all comes down to how "smart" your smog tech is.
Old 06-01-2004, 10:27 PM
2_point8_boy's Avatar
Car: 1988 Camaro RS
Engine: 2.8L of Raw POWER!!!
Transmission: Stick Shift
Axle/Gears: 3.42's
we look them up on C.A.R.B's website, we do that for all E.O. numbers, regarless of what it's on. I think most test only shops do that (at least they should), and since most of our cars are H.E.P. we can't get by with much. I order to get past the E.O. thing, you would have to make a custom setup, that includes all of the original emissions equipment that came on the vehicle and have it pass an official I/M 240 test at your local referee station, at that point, as long as everything looked good and it passed the sniffer, then you will receive a BAR label that links your car to a list of legal mods that were done to it. That list is downloaded to the analyser vid the VID everytime you get checked, that way the tech know that you are good to go.
Old 06-02-2004, 02:07 PM
PsychoGTA's Avatar
Thanx for the info 2_point8_boy. Do you know where I can go to check where there is on by me? I'm gonna try going through a refree station, but first I'll do some research. Do you know where I can get some more info? Thanx a lot.
Peace Out,
PsychoGTA:lala:
Old 06-03-2004, 12:53 AM
Kevin91Z's Avatar
Your local referee station can be found at California's official smogcheck website at http://www.smogcheck.ca.gov/
Good luck getting anything that isnt 50-state legal passed them.
Old 06-03-2004, 10:25 AM
Car: 1988 Camaro RS
Axle/Gears: 3.42's
Right, they don't tend to pass anything that doesn't have an E.O. Number, but how do you think that companies get then. You can get a limited parts exemption done by them and not have to pay for the E.O. number. As long as everything that is original smog equipment came on the car, you usually can ge them to give it the OK, but it has to pass the I/M 240 test. It's a lot stricter test then the standard ASM that the state currently mandates, but it does give them a lot better idea of how the vehicles emissions really are. I'll see if I can get my car on the dyno today and run one so that you gus that have never seen one can take a look at the print out.
Old 06-03-2004, 02:25 PM
Mr.84TransAmer's Avatar
Car: '84 Trans Am; '88 GTA
Engine: Vortec 355ci TPI
Transmission: TH-700R4
How can they tell if a car has it's original smog equipment rather than, say, next year's model's smog equipment?
Old 06-04-2004, 10:35 AM
Car: 1988 Camaro RS
Axle/Gears: 3.42's
Various books that Smog Stations are required to have and the underhood emissions label. If the label is gone, then we look it up in the book. If the label doesn't match the application, then we consult the book. There are ways of figuring this stuff out that 90% of the people out there just don't understand.
Not targeting anyone here (most here know what's going on), but most people think that we simply stick the sniffer in the **** end of the car and run it, but the whole visual and functional thing is where we really find the problems, then people are pissed off because they pass emissions, but fail visually with a tampered emission system. Things are designed the way they are for a reason, not just because the engineers think it's fun, however sometimes, you wonder what kind of drugs they were on when they designed it.
Old 06-04-2004, 11:00 AM
PsychoGTA's Avatar
Hey 2_point8_boy got one last question for you. Will I pass visual with a cut-out in front of my cat? Thanx
Peace Out,
PsychoGTA
Old 06-05-2004, 12:25 AM
Kevin91Z's Avatar
No, you wont pass with a cut out in front of the cat. Technically, you're not supposed to have a cut out at all, since I think we're required to run mufflers. More specifically, the exhaust is supposed to exit behind the rear wheels. I dont know about those cars with side pipes.
Old 06-06-2004, 12:31 PM
Car: 1988 Camaro RS
Axle/Gears: 3.42's
Right, a cut-out before the cat will get you a nice big TAMPERED on the top of the VIR.
In California, we can't fail you for having a cut-out BEHIND the cat, that's a thing for the highway patrol or local police force to bust you on, not us. Leagally, the exhaust either has to exit either out the side of the car before the rear axle(side pipes) or dump anywhere behind the rear axle, and all vehicles are required to have a muffler.
Old 06-06-2004, 11:09 PM
Mikos_89's Avatar
Car: '89 GTA, '15 Camaro LS 6sp.
Engine: L98, LFX.
Transmission: 4L60, AY6.
Axle/Gears: 3.27's.
2_point8_boy,
What's the difference between the ASM and the I/M 240 test?
I thought the current smog test procedure (here in Cali) performed on the dynonometer/roller was the I/M 240 test. No?
Is there an even stricter test than the one they're using now?
Old 06-07-2004, 07:48 PM
Car: 1988 Camaro RS
Axle/Gears: 3.42's
Originally posted by Mikos_89
2_point8_boy,
The ASM test currently performed takes a car up to a constant 15mph @ 50% load and then to a constant 25mph @ 25% load. The idea is to "simulate" acceleration, hence the ASM which stands for "Acceleration Simulation Mode."
The I/M240 test is what the EPA uses to certify a car. The test last 4 minutes(240 seconds) and takes the car through various loads and speeds all the way from 15 mph to 55 mph. This test measures acceleration as well as deceleration emissions and is even tougher than the ASM test that we have.
Many states, including NY (if i remember right) use the I/M240 test, but what usually gives our test the misconception of being so hard is the fact that we also do a visual inspection of all the vehicle's emission equipment (intake tract, vacuum hoses, exhaust, etc...). Most other states just have the dyno test and that's it.
Unfortunatly, the way things are looking right now, we actually might be starting the I/M240 testing here in about 5 years. There have already been reports published stating that even after the start of the ASM testing and the introduction of the "Test-Only" program, California's Air still does not meet Federal standards. 2005 is the next time that an official study will be done, but with these currently published reports, it's not looking good.
For us, this shouldn't be too bad, since our cars were never certified at the I/M240 standard, the initial limits will be REALLY high until they see what our average numbers are, then they will be adjusted accordingly. People with newer cars('96+) are the ones that are gonna have the hardest time...especially 90's Nissan, Deawoo, Kia, Hyundai and Saturn owners.
jaridjohn
10-05-2015 07:01 AM
wstephan96
09-25-2015 04:28 PM
Quick Reply: still being smog legal?
