Tranny cooler lines...
Car: '89 GTA, '15 Camaro LS 6sp.
Engine: L98, LFX.
Transmission: 4L60, AY6.
Axle/Gears: 3.27's.
The original tranny cooler lines on my GTA got all messed up after removing the tranny to get the front oil-pump seal/bearing replaced.
I went to a couple of junkyards, but I couldn't any decent cooler lines. People either cut the lines when they remove the engine/trannies or they're in much worse condition than the lines I already have.
Since new pipe would look alot better and the hex fittings wouldn't be all rounded off like used pipe, I went to a few autoparts places to see if I can find sticks of preflared 5/16" tubing. Unfortunately, the only 5/16" tubing I can find are sticks of shiny steel galvanized pipe with gold zinc oxide fittings. WTF?
Does anyone here know where I can find sticks of pre-flared 5/16" tubing in "green/gray" galvanized steel with 1/2" black-oxide fittings like the original pipe? If so, is there perhaps a (Gates?) part no. for this particular item?
Axle/Gears: 3.45, 3.27, 3.27
I have a spare set of the tranny cooler lines available.
Lon
Lon
Engine: L98, LFX.
Axle/Gears: 3.27's.
Lon,
If possible, can you describe the condition of the spare set of lines you have available?
Thanks.
Thanks.
I'll dig them out tomorrow and snap a picture of them.
Lon
Lon
Sorry I can't help you after all. I was cleaning the lines and found out the shorter of the pair has a crack near the lower radiator connector. Trash day is tomorrow. Out they go.
Lon
Lon
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
I have several good sets.
Please dont get **** with me as I don't have time for pictures or making them look nice.
Engine: L98, LFX.
Axle/Gears: 3.27's.
Thanks for trying Lon.
Don,
Will you be at the shop the week after X-mas? Or, will you be going on vacation or something?? Just curious.
Don,
Not to get "****" but you could go to Fine Lines Inc.
http://finelinesinc.com/catalog/index.php?cPath=270_301
Car: 92 B4C/1LE CHP camaro 06 vette LS2,
Transmission: iroc, 700r4, auto
i've got a few sets of them on parts cars. you would have to come to bakersfield and pull them. email is ron09517@aol.com
TinnMann2
Canadian Region
16
Jun 18, 2017 05:10 PM
