LT1 ENGINE ARRIVED
Car: 1991 Camaro RS
Engine: THE LT1 SWAP SHALL BEGIN!!!!
Transmission: 700 R4
Axle/Gears: LSD! =(
LT1 ENGINE ARRIVED
Yes! finally it arrived this engine came out of a 1995 Impala SS, bought it for $1100.00. I will post pics of the computer tommorow!
Car: 1993 GMC Typhoon
Engine: 4.3 Turbo
Transmission: 4L60
Iron block, Iron heads..
not a bad building platform. What are the plans? changing anything on it?
Car: 1991 Camaro RS
Axle/Gears: LSD! =(
right now, I want to get everything set up and make the car running. then after I have everything properly installed I will save money for a 383 stroker kit and rebuild the engine and open up the heads a little, also change the fuel injectors and add headers..
Engine: 4.3 Turbo
Transmission: 4L60
you know, LT1 aluminum heads are pretty cheap, you might want to look at those. 58cc combustion chambers.. 10:5:1 compr.
nice engine, looks pretty clean from the pics
Car: 1990 Camaro RS
Engine: 305 TBI (L03)
Transmission: 700R4 (MD8)
Axle/Gears: 2.73 Open (GU2)
It does look nice, but didn't werent the LT1s from the Impalas way different than the ones from the F-bodies/Vettes? Smaller cam, more restrictive intake...... correct me if i'm wrong though.
Still a good engine and will be alot better than that L03.
Car: 1991 Camaro RS
Axle/Gears: LSD! =(
Car: 92 B4C/1LE CHP camaro 06 vette LS2,
Transmission: iroc, 700r4, auto
i think there will be a HUGE improvement in power over the L03. let us know how hard it is to actually get everything going.
Engine: 4.3 Turbo
Transmission: 4L60
you're thinking of the LT1's that were in the Buick Roadmasters.. they were called L99's .. Impala's were were the same as the F-bod's but got iron heads lower compression and i think a different cam.
the stock aluminum heads from the Fbody were 58cc's. Usually see them on ebay for 150$ for the pair.
Car: 1991 Camaro RS
Axle/Gears: LSD! =(
came from an 95 Impala SS
It has iron heads... but I didnt know those aluminum heads were so cheap in price, The guy I bought it from probably buys them from a chop shop..... but he said the aluminum heads will warp if you plan to race and put headers on this engine..... I think it will warp only with a turbo or something
Car: 2006 Tacoma X-Runner
Engine: 4.0L DOHC V6
Transmission: 6-Speed Manual
Axle/Gears: 3:15 LSD
I don't think so. There are a lot of motors out there with aluminum heads and iron blocks both boosted and not boosted with no warping of the heads. Aren't the blocks the same with the LT1s from both the Impalas, F-bodies, and Corvettes? My GSX has an aluminum head and iron block running a factory turbocharger with no problems. My old TA had aluminum heads and an iron block and it has no problem either with the warping of the heads. Senior Member
Car: 1990 Camaro RS
Originally Posted by trans87
I don't think so. There are a lot of motors out there with aluminum heads and iron blocks both boosted and not boosted with no warping of the heads. Aren't the blocks the same with the LT1s from both the Impalas, F-bodies, and Corvettes? My GSX has an aluminum head and iron block running a factory turbocharger with no problems. My old TA had aluminum heads and an iron block and it has no problem either with the warping of the heads.My Dad has one in Blue.... had to wait 3 months to get one. Those are really nice trucks though, although he has already had problems with the clutch and it popping out of gear.
Sorry to change the subject, but that is one good looking X-Runner.
I think Psycho you will have no problems with the LT1 aluminum heads. Only issue header wise I had were the bolts kept backing out the head causing the gasket to blow. No warping though unless you overheat the hell out of the engine. Thread Starter
Car: 1991 Camaro RS
Axle/Gears: LSD! =(
Originally Posted by BrandenCali
I would not stroke it.. I get the Alum heads though.. The crank the rods,pistons.. Some lightweight but heavy duty quality.. Good luck with it.. Should turn out nice for you..
why wouldn't you stroke it??? My ultimate plan now is to build my savings account to 3k so I may buy everything I need for this swap, just swap drivetrain not suspension :-p
