Southern California Area Southern California Members.
Took the car to the track
Old Nov 15, 2007 | 10:57 PM
InsaneIROC's Avatar
Car: 89 1LE IROC Z28
Engine: 364 Ci Ls2
Transmission: Mn12 T56
Axle/Gears: Borg Warner 9 Bolt With 3.70 Gears
I got off work early today and took the Camaro to Irwindale it went 7.30 at 105 MPH it has alot more in it I have to get it to hook .
Old Nov 15, 2007 | 11:35 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
Re: Took the car to the track
Excellent times. With the power you are making getting it to the ground will require some effort. There goes Vincent and Allen.
105mph is just slightly less than I do in the 1/4 mile. Need the particulars on the motor. Hope to see it at the Christmas dinner. Allen
Old Nov 16, 2007 | 01:50 AM
JulieGTA's Avatar
Car: 1991 GTA
Engine: 350 tPI
Axle/Gears: 342
Wow! Cool!
Old Nov 16, 2007 | 10:19 AM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
With an all out 383 w/Super ram he is in a league of his own
I'm sure Dwayne would love to take hin on
Nice going guy!
Old Nov 16, 2007 | 12:37 PM
JERRYWHO's Avatar
Good job that's a 11.30 to 11.50 in the 1/4.
What was your 60ft and 330ft times.
Jerry
Old Nov 16, 2007 | 12:46 PM
JERRYWHO's Avatar
hold on, are you sure 105 mph that's 10.80 speed in the 1/8 can you post a picture of the time slip.
Jerry
I have some 28x10 Hoosier slicks mounted that will fit your car if you want to try them let me know next time you go to Irwindale and i will bring them out.
Old Nov 16, 2007 | 06:20 PM
Agent13's Avatar
Car: 1983 Daytona Trans Am
Engine: LG4
Was there nitrous involved?
Old Nov 16, 2007 | 07:34 PM
VincentZ28's Avatar
Car: 1990 G92 IROC Z Miniram
Engine: 388cu 6.4 Liters
Transmission: G-Force T5
Axle/Gears: 3.73 Gears
I want proof damn it. Proof is in the pudding. No props til then!
Old Nov 16, 2007 | 07:48 PM
BobItzaboy's Avatar
Thats frikin moving- and making up a whole lotta ground at the big end.
If this is true, you are looking at a low 10 second car.
We were just up there a few weeks back running a Vintage drag Ghia in the Bug-in that does that capable of a 7.30 once we get the linelock and the 2stage box in it. It just clicked a 7.45 @ 88 lifting in third to about 2/3rds pedal not to break out of the 7.42 dial. This car bites hard too. You have got to be spinning bigtime off the line to make that time with that MPH.
The best weve done in this thing is a 7.34 @ 93 and that was a bad bogg of the line with way too much traction and in 3 runs after 20 years of sitting.http://www.youtube.com/watch?v=8dD3mnsoTGw
Old Nov 16, 2007 | 10:14 PM
InsaneIROC's Avatar
Engine: 364 Ci Ls2
HAHA I never said it was the IROC lol I just got a 68 with a 496 stroker and a tunnel ram . Im still working on porting my intake for the IROC I should be done by the first . Hay don I need a y pipe .
Old Nov 16, 2007 | 10:37 PM
Car: 1989 GTA
Engine: 369 TPI
Whew. Looks like we got a reprieve.
Old Nov 16, 2007 | 10:57 PM
InsaneIROC's Avatar
Engine: 364 Ci Ls2
I knew that would stir the pot a little.
Old Nov 17, 2007 | 09:53 AM
Dyno Don's Avatar
No problem
Old Nov 17, 2007 | 11:20 AM
injdinjn's Avatar
Car: 1986 Grand Prix TPI
Transmission: 200 4R
LOL
Bring it in Dec
Old Nov 17, 2007 | 10:54 PM
InsaneIROC's Avatar
Engine: 364 Ci Ls2
Originally Posted by Dyno Don
No problem
Dual cats the 02 sensor is not in the header you need to put it in the y pipe.
Old Dec 1, 2007 | 10:51 PM
BLWR PWR's Avatar
Car: 89 IROC
Engine: Built 383, Vortech SC
Transmission: Pro-Built 700R4
Axle/Gears: Dana 44, True Trac, 3.54
7.78@92mph. 3000ft. Madras Dragstrip, Oregon. Hi Don, Kevin, Russ, all you"oldtimers." Bring it on Dwayne!. Jeff
Old Dec 1, 2007 | 11:35 PM
Russ-So Cal's Avatar
Hey Jeff, good to hear from you again. Come on by the So Cal board sometime and say hello. Have you hooked up with any of the third gen guys in the Cascade Crew? How do you like Bend? If I remember correctly, your in the Southeastern dry part of the state aren't you?
specialized
Jun 18, 2022 09:26 AM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Reddeath210
Oct 6, 2015 08:20 AM
Linson
Aug 21, 2015 02:12 PM
kyleb24
Aug 15, 2015 08:24 AM
