I need help or goodbye to camaro =(
Car: 1984 Camaro Z28
Engine: 305 H.O
well my 84 camaro is over heating and i pretty much replaced the cooling system and when i got tired of it overheating i took into a shop and sure enough its a head gasket the weird thing is.. is that there were absolutely no sighns of it so im just giving it a shot and reaching out there for somone who wants to help replace my head gasket i know how to work on cars but never really took off the top half and dont want to screw it up... if no one wants to help then im gonna have to trade it for something horrible like a rice burner of sorts
i live in san diego so PLEASE if u can help me out that would be great
i live in san diego so PLEASE if u can help me out that would be great Banned
Car: 85 IROC-Z
Engine: magflatoVE
Axle/Gears: 9" 411
Re: I need help or goodbye to camaro =(
i would say good bye Camaro and hello rice burner.....J/K
where are you located in SD? I live in north county
Engine: 305 H.O
i live in clairemont off the 52 its easy to get here from the 5,805 and 15 u willing to help? do u know how long it takes to replace it?
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
A head gasket swap is a pain in the butt in the car. And there arent a lot of us in San Diego.
Engine: 305 H.O
yeah i know i mean i can pay a mobile mechanic to do it but i dont know how well their work is ya know? so im doing the best i can for my car without paying $1665 for it cause im financially screwed right now only have a couple hundred so im thinking about just puting in some steel seal to repair the leak i know i know theres no such thing as a mechanic in a bottle but its all i can do without frying my motor every day it it hurts cause its my daily driver
and ive looked and searched for hours on steel eal and i guess it happens to work for well over 3,000 miles with no problems at all
and ive looked and searched for hours on steel eal and i guess it happens to work for well over 3,000 miles with no problems at all Re: I need help or goodbye to camaro =(
I've put the block sealer in a Ford that was using a lot of water for a friend who didn't want to spend a ton of money on an F-150 with 220,000 miles on the "clock." It is a polymer. You flush all of the antifreeze out of your engine including the heater core, empty the can into the cooling system and top off with water, bring the engine up to temperature with the heat on, and run the engine for 1/2 hour. Drain the cooling system and let sit over night with the radiator cap off to let the air in to "cure" the stuff. It may or may not completely seal a leaking head gasket, but it should slow the leak to where you only need to add coolant once a week. You will need to run antifreeze, because our cars run at a normal temp that will boil plain water out of the cooling system without something in there to raise the boiling point. It is not a permanent fix, but it could buy you enough time to save for the head gasket job, or to get a new motor to swap in.
Car: 90 IROC-Z
Engine: Lsa
Transmission: M6
Axle/Gears: 9" spooled 3.70
I had a major external head gasket leak on my 350 olds and used the small bottle for $6. Still run it like that no problem. Trending Topics
Engine: 305 H.O
well i found a mechanic who will charge me $100 a head so $200 and i also know somone who works at a machine shop that builds heads so i dont need to pay any money to get new ones or resurface these.... all i would be paying is $200 plus materials
Car: 85 IROC-Z
Engine: magflatoVE
Axle/Gears: 9" 411
you can do it yourself. it is very easy to do, and does not take more than a day.
Car: 1986 Grand Prix TPI
Transmission: 200 4R
You need a book because of the sequence required to torque the head bolts back on.
Its a bitch of a job, esp without pulling the motor. Thats why most do a complete rebuild as a head job is 70% of the work.
I dont recommend it for a beginner unless you have experienced help to watch over you.
Car: 1982' camaro Z/28
Engine: lt-1 out of a 95' impala ss
Transmission: viper spec t-56
Axle/Gears: Ford 9in 3.90 gears
have a spare book lying around but the prob is i live in riverside.
Engine: 305 H.O
well im just gonna get rid of my baby unfortunately
just bought 05 F250 so im just gonna get rid of the camaro sucks
just bought 05 F250 so im just gonna get rid of the camaro sucks Member
Car: '84 Trans Am; '88 GTA
Engine: Vortec 355ci TPI
Transmission: TH-700R4
The guy who's working on my engine swap might be able to help you out. He's a mobile mechanic and he does head gaskets.
http://inlandempire.craigslist.org/aos/997948884.html
84z96L31vortec
Aug 20, 2017 12:16 AM
