Southern California Area Southern California Members.
Problems with my 98 GMC Sierra
Old Nov 23, 2009 | 09:49 AM
z28gsxr's Avatar
Car: 91 RS Vert/98 Sierra9
Engine: 5.7/5.0
Transmission: 5spd/auto
Axle/Gears: 4th gen rear with 3.73
The truck has a 305 TBI Vortec motor. The problem started out in the desert after towing a few dirt bikes out there. Not sure if this matters but this is where the issue first began. My truck seems to have problems starting on cold mornings. Originally when the issue appeared i would have to crank it 3 times before it started. The first two times the idle would be at about 300 when trying to start and shut off then on the 3rd try it cranked right up as if nothing was wrong. I have since changed the gas filter, new plugs, new cap and rotor. After changing these parts the truck started up fine. But now it has progressively gotten worst. This morning I had to crank it about 10 times until it finally started. But once it starts I can turn it back off and it will crank right up without an issue. I can leave the truck parked at work all day long and it will crank right up when I get ready to go home 8 hrs later.
A friend of mine says it may be that my coil is going bad. Any other suggestions? Also there is no check engine light on.
Old Nov 23, 2009 | 01:22 PM
injdinjn's Avatar
Car: 1986 Grand Prix TPI
Transmission: 200 4R
Re: Problems with my 98 GMC Sierra
Does it smell gassy. It could be cold start flooding. or the cold start might not be engaging.
Old Nov 23, 2009 | 02:19 PM
z28gsxr's Avatar
Engine: 5.7/5.0
No it does not smell like gas. Cold start not engaging makes sense and sounds cheaper then bad fuel pump. How can I go about checking the cold start?
Old Nov 23, 2009 | 05:32 PM
godreject's Avatar
Car: 09 GSXR/88 iroc/91 RS B4C
Engine: 600cc/l5.7/5.7
Transmission: 6 speed/TH 350/auto
Axle/Gears: 45tooth rear?/3.23/3.42
check your fuel pressure, specially on those occasions when its hard to start, we've had to replace 2 pumps on an astro van and 1 on a suburban from what i've been told those pumps are usually bad. My brothers silverado does the same thing as your truck, it takes a few cranks to start when cold, so far it hasn't bothered him enough to spend 300 bucks on a replacement pump. i would check the fuel pressure though
Old Nov 24, 2009 | 09:14 AM
z28gsxr's Avatar
Engine: 5.7/5.0
Today I cycled the key on and off about 5 times and would let the fuel pump prime each time. Then I finally went to start it and it cranked over without an issue.
Old Nov 24, 2009 | 10:45 AM
Russ-So Cal's Avatar
Check also for a leaking injector. I think you fuel system should stay full of fuel when it is shut off.
Old Nov 25, 2009 | 03:37 AM
cleanz_28's Avatar
Car: 1987 Chevrolet Camaro
Engine: Vtec Killer
Transmission: the kind that loses Hondas in 1st.
Axle/Gears: the kind that turn the wheels
sound like fuel pressure, check the relay too...
BTW I got that engine u sold me to run... Its a very stout 305, I tossed in some 24lb injectors with a afpr and the underdrive pully that was attached on there. That sucker really revs up. I really want to thank you for selling me that engine.
Old Nov 26, 2009 | 09:40 AM
z28gsxr's Avatar
Engine: 5.7/5.0
Nice Remind me which engine you bought? I remember dropping off a lb9 motor in pasadena but that was through craigslist. Or did you buy an l03 from me?
pjsparts
Oct 29, 2025 06:39 PM
88rscamar0
Sep 23, 2015 09:08 PM
383cam
Sep 9, 2015 06:01 AM
andy74
Sep 3, 2015 08:41 AM
greenyone
Sep 2, 2015 03:39 PM
